Question about E-Machines eMachines Desktop PC
Tower has no power not even the fan - E-Machines eMachines Desktop PC
  • 81 Answers
Be sure all power outlets are turned on, and the power cable is inserted properly into the computer.
Posted on Jun 16, 2009
Tower Overheats and shuts off
having built more than a coupe myself fans do fail and should never sound like they are laboring. but adding a second or third is not a bad idea.
Sep 28, 2017 | Dell XPS 200 PC Desktop
How do I clean a Hawaiian Breeze tower fan?
All Equipments has a provisions for servicing even for cleaning only.
Jun 18, 2011 | Tower Aloha Breeze Fan
How to fix my computer PC so noisy
check the noise location.
It could be the internal fan or it could be the CD/DVD drive making noise.
You probably have to open the case/Tower to check what is causing the noise. If it is a fan make sure it is not obstructing with any wire and then close the tower carefully.
It could be the SMPS( switched mode power supply ) the power supply of the computer. SMPS is the box inside the tower where the power cable of the computer gets connected.
Try to check if that is making noise or not .. If it is get that replaced.
If it is a CD/DVD ??
check if the noise comes when the CD is in or it comes even if it is empty.
Both cases the CD/dvd drive needs repair.
Try the steps above and let me know if you have any other question.
May 10, 2010 | Sony VGC-LT32E PC Desktop
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
Grinding noise in tower
Grinding noise in tower If everything on your computer is working fine then it is probaly a fan put your ear in the back of your tower near the power cord and see if you can hear the grinding noise better if you can then your power supply's fan is going out if not its probally one of the inside fans in your tower open up your tower and see if you can find which fan it is if you dont want to do this you should probaly get a tech to look at it it's a pretty cheap fix and it can save your computer from heat dammage
Nov 07, 2009 | Computers & Internet
FTT-R tower fan would oscillate but the fan would not run.
You might have a stripped gear in the tower where it oscillates. Hope this helps!
Jul 14, 2009 | Black & Decker BDTF1010B Tower Fan
Dell Precision 670 Workstation REALLY LOUD and NOISY
It could be due to a failture of either the SMPS fan (Power Supply), the system cooling fan or the Videocard fan... Now checking the power Supply fan issue is easy... Take a toothpick {wooden} n insert it between the fan fins at the back of your tower... This is the fan that is visible from the back of your tower... Now if the noise stops then it is the SMPS fan issue
If it still persists then do the same procedure with the CPU fan located on the inside of the tower.. this is a bit tricky but you seem tech saavy enough to do so but anyways this is the link for a step by step procedure of getting inside your desktop
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/index.htm
The third case is the Graphics Card... now there is no way we can say this with certainty but you can do this... remove all connections from the back of the tower.. remove the graphics card, connect just the power chord n start back up... if the noise is gone then the Video Card is the culprit.. REMEMBER TO REMOVE POWER CHORD ALL TIMES YOU OPEN THE TOWER N BE VERY VERY CAREFUL N FOLLOW THE MANUAL  :-)
Feb 12, 2009 | Dell Precision Workstation 670 PC Desktop
My computer keeps rebooting and will not even let me start it up in safe mode.I blew the dust out of it and it restarted and let me into the desk top for about 5 minutes but then shut down before I had a...
Constant rebooting of a computer can be cause by alot of reason the most common for this is due to oevrheating, to check if this is a overheating problem try to open the case of the tower and put a electric fan in front of the tower to coll it down then power ON thecomputer and if it booted up fine with a electric fan blowing on the tower we're sure that you need to add some colling device on the computer tower, But if still do the same thing the problem here is the power supply unit it needs a replacement already....
Oct 22, 2008 | HP Media Center PC 873n (P9875A#ABA) PC...
My tower won't turn on. I checked and it is plugeged in to a working outlet... the screen light is on and even one light on the tower is on -- but when I press the on button NOTHING happens.
hi ,
you can try this solution
unplug all cables , powerflee the system by pressing the start button for 30 sec , release it then replugg all the cables and check wheather it is working or not , secondly check wheather the powers supply fan on the back of tower is working or not, still it doesnt work turn off the tower and unplugg the tower and then openthe tower , check all cables and reset the RAM on the mother board ...you can try this basic troubleshooting , it will help u... waiting for response
May 20, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
53 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
