Question about Boating
Fuel gage not reading properly
The fuel gage reads full and I have taken out the sending unit and checked it and it seems to work freely. After I put it back in the tank the gage read empty but after I put in about 6 gal. of gas it jumped to full.
I repalced the sending unit a while back could it be that the float is too short or the wrong unit.
    Champion:
  • 207 Answers
Yes it could be you need to check the depth of your tank and then measure the sending unit to see if is going to the bottom it should be about a 1/4 inch from the bottom if that is good change the gauge
Posted on Jun 27, 2009
Fuel guage wont read
The wire to the sender in the fuel tank is shorted. If it was open or disconnected it would read full.
Feb 12, 2014 | 1989 Chevrolet C1500
Fuel gauge gmc
It could be a loose connection on the gauge or the fuel sending unit.
The fuel sending unit can get worn and have breaks in the contact area that is used to determine float position to send the fuel level reading to the gauge.
I suspect that you have problem with the fuel sending unit considering that the light is on. I am assuming that the light that is on is the "low fuel light". Check your connections at the sending unit if the connections are secure then I would suggest replacing the fuel sending unit.
Jul 04, 2013 | Cars & Trucks
Fuel gage stays on full
sounds like a bad fuel sending unit, the fuel level float is not reading the proper amount of fuel in the tank, replace the fuel level sensor (sending unit). hope this helps
Sep 08, 2012 | 2000 Buick Century
Fuel Gage reading full all the time
Sound like a problem with the fuel sending unit, this device generally is attached at fuel pump module.
Jul 06, 2012 | 1997 GMC Sonoma
Fuel guage not working
Testing the fuel gage requires accessing the harness from the fuel pump and grounding the yellow / white wire with 160 ohms resistance this should cause the gage to read full, and with the circuit open you should have the gage reading empty. If the gage works in this order then the likely failure is the sending unit in the tank , and will require replacement.
May 30, 2010 | 1999 Ford Expedition
Fuel gauge not give proper reading.. register full
Sorry to say,but the fuel sending unit is the problem,the fuel tank will have to be lowered out of the vehicle to replace the unit.If the fuel sending unit is not available by itself you will have to replace the whole fuel pump assembley.
Oct 14, 2009 | 1999 Buick Regal
1996 Plymouth Grand Voyager Fuel Gage issue
It sounds like the fuel level sending unit located on the fuel pump is malfunctioning. The solution for this is to have it replaced. You can do this yourself but I wouldn't recommend it as the vehicle needs to be lifted and the fuel tank needs to be dropped out. This can be preformed for about 100-150 in most shops.
Jan 20, 2009 | 1996 Plymouth Voyager
Fuel Level Gage Reads Incorrect
sending unit in tank is bad need to drop tank and install new.
Jan 01, 2009 | 1997 Volvo 850
Gas gauge not woking properly gas tank only accepts a little gas
a fuel sending unit seems to be the most popular solution. the part is about $40. I think the labor is what's going to kill you.
Nov 21, 2008 | 2006 GMC Envoy
1987 ford Bronco II fuel gage doesn't work-reads empty all time
I need to know if the other gauges are accurate. There is a voltage regulator mounted on the back side of the dash that can go bad and often does, that will make the other gauges inaccurate also.
Nov 10, 2008 | 1987 Ford Bronco II
Boating Logo
93 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
