Question about Panasonic CT-36D31 36" TV
High Pitched Noise, No Picture, Need To unplug to make it stop
My TV is doing the same types of things that another member said was happening to their 42".  I am under the impression that it is the horizontal output transistor and transformer based on a previous posting. (thank you techman).  My real question now is,
Where can I find these parts so that I can make this repair?
My car is too small to take this TV anywhere and I feel my only worthwhile option is to make this repair myself.
  • 537 Answers
Re: High Pitched Noise, No Picture, Need To unplug to...
It is probably easier to take it somewhere to have it fixed as you will spend hours and still might not fix it correctly.
You need schematics for your TV.
If you really need sources for these parts, you might be able to find them from digikey, mouser or newark electronics.
Look on this link for more repair hints for HOTs
Posted on Oct 31, 2007
0 characters
3 Points
Same problem, high pitched noise over regular sound and no pictur
No guarantees with this diagnosis. But it sounds like an HT ( high tension) leak This is often caused by the lead becoming partly unplugged ( being bumped or moved) and because of dust buildup it arcs making a high pitched hissing whistle.Ther lamp may also have been affected by the HT leak. The safest option for you is to call a service technician to it, as opening it up could cosntitute a a danger to the unskilled.
Aug 12, 2009 | RCA HD56W58 56" TV
When my rca 36F530 tv is plugged in it makes a high pitched buzzing noise picture does not come on
There is a short circuit in the high voltage circuit. the transformer who helps to create the high voltage or his power transistor is damage. replacement needed. the repair is not expensive, because the parts are average repair. Ask for an estimate.
May 01, 2009 | RCA 36F530T 36" TV
High pitch
I have never heard a tube make noise when there is a good picture. Anyway, the noise has to be a transformer ringing or oscilating. They make a high pitched squeal when they have a loose winding or their cover is loose. You probably won't be able to feel or see anything loose on these transformers The power supply switching transformer is the first to look at. Take a hot glue gun and just cover the thing...especially at the base of it. The next (and only other) one is the horizontal drive transformer.It is located close to the high voltage transformer( biggest thing on board and usually in back or corner of the PCB.This one wont squeal) The horizontal drive transformer is about the size of a large marble and is encased in a black plastic cover. Cover it with hot glue also.
If you take the back off you will probably be able to localize where the squeal is coming from. You will probably need a signal to hear the noise also. After you find where it is coming from UNPLUG the set before doing any hot gluing!!!!
If you 're not up to this procedure take it to a technician. Your tube is not going bad and the set is definitly worth repair. Simple fix!! Good Luck!!
Oct 03, 2008 | Sharp 32SC26B 32" TV
Loud sound, No TV Picture
Power supply needs to be replaced - common problem with these tv"s
Sep 18, 2008 | RCA 32F531T 32" TV
Sanyo tv making high pitch noise from loose cable connector
The noise is coming from the fly-back transformer. By moving the cable connector you move the main board. Unplug the TV and remove the back. The transformer has a red wire going to a rubber cup at the top of the picture tube. Looking at the transformer you will see a dough nut shape with a metal piece going through it .. Drive some tooth picks between the dough nut and the metal core. That should reduce or stop the ringing.
Apr 21, 2008 | Sanyo DS31520 31" TV
Stopped working and squealing sound
Your set is shorted circuit condition. The power supply is making the noise. Unfortunately almost any of the hi current circuits will do this. If picture went out 1st look for video or hi voltage problems.
Jan 11, 2008 | RCA 32F531T 32" TV
RCA 27r410t 27" won't turn on,just makes high pitch noise
that high pitch is comming from the flyback replace the flyback and the HOT.and you will restore back the life of your tv.good luck.
Jun 04, 2007 | RCA 27R410T 27" TV
High Pitched Noise
most high pitch noise comes from the anode conection on the picture tube thats connected to the flyback anode cap thats mean there is a high voltage leak,to stop the noise you can discharge the high voltage take off the cap and clean with alcohol.if the noise will have to put some red or clear silicone both the cap and tube stick together leave to dry for about 2 to 4 hrs.this will eliminate the leaking.good luck.
Jun 11, 2007 | Toshiba 27A41 27" TV
TV won't stay turned on, no picture, started making high pitched noise
That high pitched noise you're hearing is the power supply telling you that it has too much of a load on it and lowered its operating frequency which in effect cuts its output way down! Normally you don't hear any thing since the power supply operates at a frequency that's beyond human hearing. In an RCA this indicates more than likely that your horizontal output transistor is shorted and this short was caused by the flyback transformer shorting. This is a common happening with RCA's You'd need to take to a tv shop and have it checked out. Stargazer
Jan 28, 2007 | RCA F27650 27" TV
Sanyo DS31520- high pitched whine, picture is fine
sounds like bad solder connections on ground of the inputs radioshack has a cheep solred gun and solder make sure set is unpluged
Dec 03, 2006 | Sanyo DS31520 31" TV
Panasonic CT-36D31 36" TV Logo
37 people viewed this question
Top Panasonic Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Panasonic Standard (CRT) Television Expert? Answer questions, earn points and help others
