Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE refrig side by side 7-8 yrs old will not freeze frig not cold
Freezer not freezing only 32 degress, noticed this am not keeping stuff frozen fridge is not very cold either, please help. thanks. mk
  • 19 Answers
Generally, This would be a sealed system problem. An inefficient compressor or low refrigerant. If you notice a build up of frost on the freezer panel it might be a defrost problem, but, I am leaning towards an inefficient compressor.
Posted on Jun 15, 2009
I have a frigidaire side by side #FSC23LR5JM2 that is not keeping cool enough. Age is aprox 1.5 yrs. Noticed the problem over a couple of days. Turned the temp cooler by 2 numbers in the frig and freezer,...
if the freezers staying cold but not the refrige section,then its the damper vent door between the freezer and refrige section thats either frozen shut or the damper door motor is bad or without power,if nothings cold as in freezer and refrigerator sections,then its the ptc overload & relay on the compressor thats bad,unplug the ptc overload & relay off the side of the compressor and obtain an exact replacement and plug in the new replacement and it will again cool
Mar 23, 2011 | Frigidaire FRS3R5EMB Side by Side...
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Hi, My Amana Refirg is about 30 years old-refrig on bottom freezer w/ice maker on top. The ice maker was skipping and would not stop by raising the arm. Consequently is ceased, now however the freezer is...
do you see alot of frost on the rear panel of the frzer if so it has failed to defrost and repair is req or do a manual defrost until a tech can get to you if no frost sorry sounds like you have a weak tired compressor or leak of freon and being 30 yrs old it is not cost effective to repair this item....
Aug 19, 2009 | Amana Refrigerators
Our ge refrig runs constantly,freezer is freezing but the refrig is not cooling. I cleaned the dust and dirt out of the bottom and back of refrig.
See if the fan in side the frig is working It mite be on the freezer side If the fan is not working it will not blow the cold air in to the frig side
Jul 12, 2009 | Refrigerators
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezing in frig.
Check the air dampers at the bottom of the fresh food section.They may have been moved to a open position. If so close them up some.
Otherwise the cold control thermostat may need to be replaced.
Mar 21, 2009 | GE GSS25SGMBS Side by Side Refrigerator
GE Profile not keeping items cold or frozen
Does'nt sound like your compressor.sounds like you may have frost build up,and the tubes may be partially blocked.Try defrosting the whole unit.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 21, 2009 | Refrigerators
Freezer cold refrig warm
4 yr old sears side by side...not cold in freeze or frig side
May 21, 2008 | Frigidaire FRS26ZSG
Food freezing in frig
Go to the link below and the choose line 22 and click it. That link page helps identify most common problems you may have with your refrigerator, Thanks Sea Breeze.
 http://www.applianceaid.com/refrigerator.html
Sep 11, 2007 | GE Profile PSI23NCR Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
333 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
