Question about Toshiba Satellite Computers & Internet
Bios black screen
Toshiba L755-S5306 Windows 7 PC Screen Froze while installing Toshiba pushed software updates for BIOS. Upon forced reboot all I have is black screen although battery, HD power seems to come on. Recovery disk boot does not work either. Does Toshiba has any liability in creating this mess? Many customers have same problem on this model while installing this update.
  • Toshiba Master
  • 384 Answers
Did You Check to See If Memory is in correctly ?you might have dislodged them by accident please check this !! Can you get back into bios there must be a reason for the black screen like Memory is the computer beeping ? What you can do is use a friends laptop or computer and create a recovery disc on there computer then put that disc into your laptop or you can borrow there windows disc.
Boot Manager:
Windows failed to start. A recent hardware of software change might be the cause. To fix the problem:
1.Insert your Windows installation disc and restart the computer.
2.Choose your language settings, and then click "Next".
3.Click "Repair your computer."
If you do not have this disc, contact your system administrator or computer manufacturer for assistance.
Status: 0xc000000f
Info: The boot selection failed because a required device is inaccessible.
(more Info Please)
Posted on Sep 18, 2017
mastersaintx
  • 928 Answers
SOURCE: Acer One zg5 - updates now wont boot up
Right after the BIOS or POST keep pressing F8 do you get the option to go into safe mode?
Posted on Feb 07, 2009
  • 10 Answers
SOURCE: sudden power off of Dell Studio 1558
Check the BIOS for PC Health settings. It is possible that you have put a low value for "Critical Temperature", which makes the Laptop to turn off.
Posted on Mar 07, 2010
Testimonial: "Yes, this has been helpful. This could be an important clue. I wonder, however, why it would not turn off every 30 minutes throughout the day then. "
PuterCare
  • 226 Answers
SOURCE: dv6000 will not startup ,Black screen , hd isnit being accessed
When you first turn the laptop on is there a HP splash screen? Can you enter the BIOS (normally by tapping F2 or Del key). If so then it would seem the BIOS updated OK. If when you turn it on there is nothing the BIOS flash probably went wrong and the machine will need a new BIOS flash chip installed.
If you can access BIOS then it may be a simple problem that the new BIOS reverted to default values. The most common issue would be the boot mode of the HDD. Look through the BIOS menus and there should be an option for boot which will say AHCI/IDE/Compatibility. Try changing it to another option, save and exit BIOS and see if that helps. Try this for each option.
Alternatively tap F8 continuously when you turn the laptop on and see if the advanced boot menu appears, if it does try selecting Safe mode with networking.
Finally to test if the HDD is actually working, try downloading Hiren's BootCD and boot to it. Then run some HDD diagnostics to see if the HDD is operating correctly.
Hope this helps,
www.PuterCare.com
Posted on Jul 08, 2010
  • 8909 Answers
SOURCE: I've installed Windows 7 on my Toshiba Satellite
This laptop came with either XP or Vista on it and if you wish to use Win7 32 or 64bit you must install all of the drivers and preferably make a fresh install. There is only one video driver that will work!
To gain access to the correct drivers, go to Toshiba.com and log your laptop in. The web site will advise you on which drivers you require.
I feel sure that that is the only problem you have that is giving you this headache.
Don't forget unless you load 64bit Win7 you may not be able to utilize more that 2048 Mb of memory.
Posted on Dec 22, 2010
technolust
  • 340 Answers
SOURCE: need to update bios toshiba satellite c660,using ubuntu live dvd, will not boot hard drive, all normal recovery options used up
Hi There,
There are currently no easy ways to update a bios through linux at all - including live cd's. Your best bet is to make a bios update USB stick (or floppy depending on the age of the computer)
Here's a link to those instructions:
http://www.biosflash.com/e/bios-boot-usb-stick.htm
Alternatively, speaking from my own experience with a similar situation, you can take the hard drive out, use it in place of the usb stick, boot from it, update your bios, and go from there.
Posted on Jun 06, 2012
Testimonial: "Matt, exactly what I have been searching for, I am well advanced in years so will take me a while to configure this, I found the update OK but was a problem choosing the utility. WELL DONE & MANY THANKS Jim"
Toshiba c55t-a5222 bios update, after reboot no screen
Did it at anytime lose power during updating? If so, motherboard was damaged and needs replaced. Otherwise, try to boot into'Safe Mode with Networking' and if it turns on, immediately re-install your graphics (video) driver. See this link for instructions on booting in to safe mode on a Toshiba: http://forums.toshiba.com/t5/Windows-7-Knowledge-Base/How-To-Start-your-Windows-7-computer-in-Safe-Mode/ta-p/272525
Feb 01, 2014 | Computers & Internet
Black screen on laptop after bios update
You might have had an impartial bios flash, which is bad. There isnt much you can do other than have Toshiba fix it or replace the system board
Dec 22, 2013 | Toshiba Satellite A135-S7403, A135-S7404,...
Installed wrong update bios for Toshiba Satellite L300D
You may have killed your laptop. BIOS have little to do with an OS like Windows, Linux, etc. The display issue is the culprit. Using another computer go to Toshiba website a get the current BIOS for your laptop. Are you able to access the BIOS at all? (press Del during bootup? to enter the Config screen (looks like DOS)
Mar 25, 2013 | Toshiba Satellite L300D-ST3501 Notebook
How to stop constant beeping on bootup after BIOS update and Windows 7 installation?
I know when I flash my bios a lot of things go through my mind until it is over because the last thing i want to see is the computer shutdown. To answer your question it is possible the update you received may have had errors in the files causing the computer to go on a beeping rampage.The only thing I can suggest is contact Toshiba's customer and technical support system to try and get answers.
Mar 12, 2012 | Toshiba Satellite Computers & Internet
Hi i was working on my TOSHIBA SATELLITE A660-13Q and it was freezing then after i restarted the machine it gave me a message saying that ( Your computer has recover from a fatal error check for solution...
Yep. U had a software issue initially - there was nada wrong with your bios. Apparently, the bios update did not go well and now you have a piece of junk on our hands. Without a proper working bios no computer will boot up. And on a laptop the bios chip is usu.ally soldered on the motherboard so it cannot be readily removed and replaced.
Time to go shopping.
Mar 11, 2017 | Toshiba Satellite A660 Series Notebook
Hi i have a toshiba l300d laptop,the screen wont come on,the laptop powers up,yesterday i updated windows 7 32bit to service pack1,installed epson printer drivers from there website,the laptop came with...
On the motherboard you can remove or short the battery backup of the CMOS (the chip that holds the software part, which is called the BIOS). This will reset the BIOS to factory defaults.
Jul 17, 2011 | Computers & Internet
My laptop screen is blue with horizantal lines. After I installed a graphics card driver everything went fine, but the next day the laptop's display started acting weird. So I turned off the laptop and...
The OS-loading screen is a stong indicator that thee is nothing wrog with your hardware, but it is a driver issue. You need to press F8 as your computer starts up and enter SAFE-MODE.
Windows 7
Using the F8 Method:
  1. Restart your computer.
  2. When the computer starts you will see your computer's hardware being listed. When you see this information start to gently tap the F8 key on your keyboard repeatedly until you are presented with the Windows 7 Advanced Boot Options screen as shown in the image below.
    Figure 11. Windows 7 Advanced Boot Options screen
  3. Using the arrow keys, select the Safe Mode option you want.
  4. Then press the enter key on your keyboard to boot into Windows 7 Safe Mode.
  5. When Windows starts you will be at a typical logon screen. Logon to your computer and Windows 7 will enter Safe mode.
  6. Do whatever tasks you require, and when you are done, reboot to go back into normal mode.
In safe-mode remove & delete the drivers you installed. If you can, revert to your old driver set.
Jan 06, 2011 | Computers & Internet
Changing BIOS priority on toshiba satelite 5005-s504
as i recall, ntloader is software for the OS load, after hardware boot, so you already passed up your chance to enter bios, which you realize. i used to have a toshiba laptop, was it the delete key or F2 to enter BIOS? try delete, and make sure youre pressing it from restart like once a second as it's booting to make sure you hit it in the windows of time it's looking for key presses before it's time to load the operating system. you'll be fine. it's just unnerving to be locked out like that...
Feb 01, 2009 | Toshiba Satellite 5005-S504 Notebook
On my toshiba laptop A215-S4767 the screen just goes black. I have to pull battery and reboot. Some article I read said something about bios but with no further details.
yes... a common problem with Toshiba...
you DO need to go to the Toshiba website... look for the support and drivers section.....
Match up your make/model from their choices.... and Download/ Install the WinPhlash BIOS Update It will Stop The Random Black Screens and Blank Freezes...
Nov 20, 2008 | Toshiba Satellite A215-S4767 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
