Question about KitchenAid KEHC379 Electric Double Oven
I was going to use the microwave then the light flickered and went out, now when i use it I get a "Door" message and it wont start. It;s a Kitchen Aid KEHC379
  • 1 more comment
  • samuel_corte Jun 15, 2009
    I did that before posting, sorry but it still gives me the same error.
    Thanks though!
  • samuel_corte Jun 16, 2009
    I guess the next obvious question is how do i check that? Do i remove the face?.. not sure.
    Thank you i did hard reset it and that didn't work. I may need to get someone to service the unit since i dont know were the sensor.
  • 749 Answers
Make shure the door is properly closed if it is it looks the the doors sensor is not fully working, you will have to the the sensor replaced, try hard resetting it , unplug it for 30mins and try again.
Posted on Jun 16, 2009
  • Muzzammil Ishfaq
    Muzzammil Ishfaq Jun 16, 2009
    That will be a good idea
  • 378 Answers
Check door switch it maybe dirty, no contact or maybe your door not properly close.
Posted on Jun 15, 2009
  • Darial Jr Lasaria
    Darial Jr Lasaria Jun 16, 2009
    okay check the wiring to the door switch.
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Microwave displays Door message
check the micro switches in the door , one is bad
Jun 18, 2009 | Ovens
KitchenAid Superba Microwave/Oven, Microway Door message
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Dec 20, 2008 | Ovens
Built in Convection Microwave Oven KBHS109SSS
no reset buton persay but fuses and control boards. MICROWAVES emit and store HIGH VOLTAGE nad should only be access and repaired by trained proffessionals. NO JOKE HIGH VOLTAGE. like your DEAD VOLTAGE
Nov 20, 2008 | KitchenAid Architect Series KEMC308KSS...
KitchenAid KEMC308KSS02 Microwave Error
The micorwave oven light does not work and when I push start, the word DOOR shows on the screen and beeps 3 times. The oven will not start.
Jun 14, 2008 | KitchenAid KEMC308 Electric Double Oven
KEMC308KBL01
send me am e mail at b4829@yahoo.com with the model number
May 31, 2008 | KitchenAid Architect Series KEMC308KSS...
Siemens microwave oven HB86k.70b
I have the same problem, have you found out the cause?
Regards
May 04, 2008 | Ovens
Microwave oven works while door is open
no there are three safety switches that control that the one that lets the magnetron run will blow the fuse if its bad you have a stuck door switch but there are recalls on some microwaves check here http://www.recalls.gov/ and here http://www.sears.com/shc/s/nb_10153_12605_NB_CSrecalls?adCell=AF or go to panasonic to find out other than that you need to replace a door switch let me know if i can be of further assistance
Mar 28, 2008 | Ovens
Kitchenaid builtin microwave oven # Kemc307KSS
I'm posting this as a solution after I went through several different web sites to and trial & error to fix my "DOOR" error code problem.
The original question I submitted can be summarized: I need to replace the 15A interlock fuse. Can you point me to a manual that describes where this fuse is and how to replace it?
Here's the answer for the KitchenAid KEMC308K series.
1) The service manual is behind the control panel on the left hand side. For my built-in, I turned off the power and removed the oven from the cabinet, exposing the sheet metal shroud. Remove the top piece and there on the left hand side is the service manual.
2) The manual indicates the fuse is in the right rear of the microwave. This is correct, but it is actually accessible through the right side.
As long as I slogged though this, I thought some other people would like to know how to solve the "door" error problem. It could be caused by a faulty control panel, but before going there, the check the switches and fuse in the door interlock circuit. Check this link for a discussion: http://www.gallawa.com/microtech/switch.html
Repair steps:
Remove the rear sheet metal shroud and you see nothing but the back and side of the microwave. Remove the right sheet metal shroud and expose the right side of the microwave. This panel has a bunch of warnings, heed them. However, the are missing one: SHARP EDGES. Think about putting tape on the exposed sheet metal edges. Remove the panel and expose the "guts" of the microwave: Rectifier, wave guide, magnetron, capacitor, and such. The interlock fuse is next to the capacitor contacts. Safely discharge the capacitor (method described in numerous places via google search and the link http://www.gallawa.com/microtech/safety.html ).
After the capacitor is discharged, remove the fuse, verify it is blown using an ohm meter (ceramic fuse - you can't see inside). The fuse is actually (despite what the tech manual says) a 20A 250V fuse. Available at radio shack in a pack of 4 for $2.99. Install the new fuse.
As long as you have this much done, may as well ensure that the microswitches still work. Remove the contacts from the microswitch. There are 2 close to each other. From the 3rd contact to these, one should open when the other should be closed. Ensure that this is true and that when the switch is depressed, the state reverses (the contact that was open is now close & connects to the common). Do this for both door-closed sensing microswitches and replace the wiring to the microswitches. Replace all the microwave side panels and the sheet metal shroud. Turn on the breaker and hopefully, as it was on mine, the "DOOR" error message is gone and it starts up normally.
Oh, when the power comes on the unit runs a self test, lots of blinking lights followed by a power-failure error code when the power comes on. I think it was pf .d=30. Hit cancel and it goes away.
So, this is a pain to do b/c there are about 40 sheet metal screws to deal with and one has to be careful discharging the cap. Pulling the oven out of the cabinet was the hardest part. I build a table at the same height and just slid the entire unit right onto my "work table." If I had to do it again, I'd have the entire thing done in under 30 minutes.
Hope this helps someone else!
sb
Jan 25, 2008 | KitchenAid Architect Series KEMC308KSS...
KitchenAid KEHC379 Electric Double Oven Logo
64 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Jim Goldsmith
Jim Goldsmith
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
