Question about Cub Cadet Street Sign- tractor lawn riding mower parts
I have a 2160 cub cadet mower and i just recieved a new clutch for it . what holds the out side houstnh from spinning. i did not take this thing apart.my tractor is the early serial number
  • 155 Answers
There should be a locater pin where it bolts on and a hole or slot on the outer edge
Posted on Jul 27, 2009
LT1046 cub cadet blown clutch..what caused this with new Pto switchpto switch froze..replaced it still will not engage blades.what could blow the new clutch
Are you sure it's blown? Run two jumper wires from the battery or power side of the starter solenoid and energize the clutch. If it energizes and clicks, that's eliminated. Did you blow any fuses?
Jun 16, 2016 | Cub Cadet Garden
What keeps the clutch from spinning ?
there should be a slot on clutch that slide on stud
Sep 05, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
PTO clutch making a loud clicking noise.
I really need some more info from you...but here are a few things you should check? Since it clicks with or without the belt...it has to be an electrical issue! Check the switch, look for broken wiring, or loose connections. Another thing it might cause this is the battery or the charging system! If there is not enough voltage to hold the clutch engaged or what it is getting is shorting out then that would be your culprit! I hope this helps! "Be Easy!" Neighborsboy
If you need further help, reach me via phone at https://www.6ya.com/expert/greg_012fb269876eb4b0
May 04, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
2160 cub cadet that wont start.hot spark to the plugs
You've solved for some of the equation. Spark. Fuel. Air.....all in the proper sequence. Now, what condition are the plugs ? I'd change them out if they have any wetness to them. Check your fuses as well. Another thing is the 'safety switches' - located in seat, on parking brake, etc. One of these could have come undone or gone bad/loose wire. I'm thinking the latter....
Jun 20, 2009 | Cub Cadet Street Sign- tractor lawn riding...
I need to replace the pto clutch on my cub cadet 2160, how do I remove the outside bolt? it turns with the engine
best way is to use an impact gun. second way would be to use a pipe wrench on the shaft if theres room. use some liquid wrench to loosen it up too
Jun 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 2160 PTO problem
How do you disconnect the reverse safety switch on a cub cadet 2160... where is it located?
Jun 01, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
167 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
