Question about Dell Inspiron B130 Notebook
Where is the CMOS battery located on my B130 & can I replace it?
    Genius:
  • 1,019 Answers
your cmos battery will be located on the motherboard.
They differ in location from model to model.
Some are underneath the keyboard, usually a blue package with 2 wires connecting to motherboard.
Others are located on the bottom of the motherboard, if you can,t see it by removing the bottom covers, ram et,c. then you need to do a part or complete strip down.
Most cmos batterys are replaceable.
Mike @ Compurepair.
Posted on Jun 15, 2009
    Scholar:
  • 94 Answers
Most likely it is located on the laptop's motherboard. If you find it: Usually there's a little level on one side, if you just press it out away frmo the battery, the battery will pop up out of the slot.
How do i replace a cmos battery in my hp compaq nc2400
I was unable to locate your specific laptop this might ge you some in sight in what to look for and how to remove cmos battery remember some cmos batteries are soldered in
RTC battery replacement procedure on Compaq HP Mini 110 netbook & clear CMOS http://www.youtube.com/watch?v=P_cxAireIsw
Feb 26, 2013 | HP Compaq nc2400 Notebook
HP Compaq 6710b - where is the CMOS battery located
The CMOS battery is located at the mother board of the PC. You will need to open the cover of the PC to replace it.
Nov 14, 2012 | Compaq Armada M700 Notebook
Cmos battery error failure
The CMOS (BIOS) battery keeps the computer'a comfiguration and the Date & Time settings in the CMOS (BIOS) chip in its memory. When the CMOS (BIOS) battery is flat these configuration information is lost.
Replace the CMOS battery with a new one, in most cases this battery is a lithium 3 volt battery type CR2032 and it is coin size battery 18mm in dia.(check it to make sure the type of battery is installed on your motherboard).
When you replace this battery then go into the BIOS and set the Date & Time etc.
Jan 26, 2012 | Intel DG31PR Motherboard
Bios Lock with this error code 55LXQF1-595B
sir
remove CMOS battery then shoting two cmos connection
Oct 08, 2011 | Dell Inspiron 1525 Notebook
I can't access my dell inspirion b130 notebook because the bios is pasworded
Please remove the battery on the motherboard. For this you will have to remove the plates that are there on the bottom of the laptop. Remove them one by one to locate the battery. It is a button cell about one inch in diameter. Remove it for a minute or so and then replace it. Replace the cover and screw it up tight. And do not pass words in future as we all tend to forget them sooner or later.
May 19, 2011 | Dell Inspiron B130 Notebook
Is it possible to reset a motherboard?
you can reset motherboard bios & back to its default settings by jumpering the CMOS battery terminal.BE SURE TO TURN OFF PC OR DETTACH POWER CABLE IN DOING THIS STEPS.
all u have to do is take out your cmos battery that is located in your motherboard & jumper the positive & negative terminal of the cmos battery by using a metal like screw.make sure your PC is not turned on or pull out the power cable of the cpu to avoid damage to the motherboard.
some mother boards have pins to reset its motherboard bios. just transfer the jumper to its reset location commonly it has only 3 pins.
Jan 29, 2011 | IBM 6574 PC 300GL 61H2470 (61H2646)...
Has power but wont boot up at all inspiron b130 notebook, was working fine 4 days ago ,
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Nov 15, 2009 | Dell Inspiron B130 Notebook
Where is the location of the Cmos battery for my
You really need a service manual to try & locate the CMOS battery. With laptops the CMOS battery can be different on each model. These are often located on the motherboard below the keyboard, but a service manual should help you.
Nov 01, 2009 | Acer TravelMate 240 Notebook
My clock wont update. every time I turn it on, it hasn't moved since last time it was turned off. The battery is charged and good.
Sounds like you need to replace the CMOS battery. It's the round silver battery that looks like a watch battery.
Hope this helps.
Sep 18, 2009 | Dell Inspiron B130 Notebook
Dell Inspiron B130 Notebook Logo
209 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
