Will not work when pushed
SOURCE: why does my preco treadmill keep saying calibrating lift?
1) Under cover the main motor or in your instruction manual, there are section for calibration.
2) I recommend that you do it, in accordance with the instructions.
3) If you do not have owner manual go to website: www. precor.com
go to customer service, then parts& manual give your model, etc and download for free. you can go too for free www. iconservice.com with the same procedure.
sincerely.
Good luck, G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA.
1( Adjust the Reed switch, clean and tight the wires connector very well
see the diagram.
1A) Tight the ribbon cables from keypads very well, and clean
2) Run after you fix it the software calibration for diagnose and troubleshooting, and fix it.
See the block diagram
SOURCE: hello im getting a startup error
I think you either have a bad motor control board or a bad lift control board
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
Press the "ENTER" button three times to access the treadmill's error log.
Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
Dear Sir:
Please try with this Reset system for Code:
To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
If you need further assistance, please reach me. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
