Question about Sony Computers & Internet
I have spilt coffee over my Sony Vaio PCG-FX501 and now it will not boot. I would like to try to repair it but don't know where to start. Can anyone help please?
    President:
  • 2,187 Answers
You may have caused a short inside, what you may do is clean out the board with cleaning solution for electrical appliances. These are solutions without any water contents. I think they have high concentrations alcohol in it. Once the board is clean you may see the extent of the damage. Blown out components. I hope they are within the removable parts, like the memory or the hard drive which can be replaced. Otherwise the entire system might be broken.
Posted on Jun 15, 2009
    Scholar:
  • 94 Answers
If you've spilled sugary liquids over electronic devices, the most common problem is power supply. The power is not getting through to your laptop. Try taking out all the power supplyl; ac power cord, battery, and any other external devices (ipods, usb cables, etc.) Next, dry out your laptop. The most effective way, for me at least, is to open your laptop so that the keyboard and screen is perpendicular to each other Then, turn it upside down and let it hang over the desk. This way the keyboard part is resting upside down, while the flat surface is resting on your desk while the screen hangs over the edge
I have a Sony Vaio PCG-505FX. It's using Windows XP Professional. We just found it while clearing out some cupboards and it hasn't been used in ages. There are two accounts on the log-in screen,...
some how get a windows bootable dvd.insert it and and start booting from dvd on the while do a full system format too.install a fresh version of windows.
goodluck
Sep 04, 2011 | Sony Vaio PCG 505FX Laptop AC Adapter,...
Hello. I have Sony Vaio PCG-5426. And I can't reinstall windows on that machine. I have out CD-ROM "II FreeCom" and i try to reinstall with that. In BIOS menu I acces for first boot drive...
you shouldn't need to have to press f9 to boot from cd rom if you have it set in the bios as the first boot device , are you sure the copy of windows on cd that you have is bootable. Try booting from the disc on another laptop or pc and see if you can start it
Another option to try is to boot from a usb drive
instructions on how to do that are here
http://www.xtremesystems.org/forums/showthread.php?t=118576
once you have booted to usb you should be able to access the cd rom
depending on what version of windows you are trying to install you will need to run different programs.
you could also install vista or windows 7 to usb drive and install it from that, it is much quicker than installing from cd/dvd you would need to be able to boot from usb to start with though
how to install vista or windows 7 from usb instructions can be found here
http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
please vote for me if you found any of this useful
Feb 20, 2011 | Sony VAIO PCG-5212 PCG-5426 PCG-551L...
I have a sony vaio pcg. it powers on and does nothing else. the 2 little cooling fans come on but the hard drive doesn't run and screen won't come on. can anyone help me out. thanks
Its possible that you already have a bad hard drive. It may have crashed. Your system will not boot without the hard drive running. The computer will keep on trying to look for the Hard drive that's probably why it looks like its doing nothing. Bring your machine to sony and have them fix it. If you know how to open up your Vaio, try to check the Hard drive connection and see it its loose, if its not loose. its time to replace the hard drive.
I hope this helps. Thanks and have a nice day.
- HotRatchet
Dec 14, 2009 | Sony VAIO PCG-K35 Notebook
Sony Vaio PCG-6L7P unable to boot. Unable to load
HARDWARE PROBLEM, TRY TO RESET THE BIOS OR REMOVE THE REMOVABLE DISK CD/DVD ROOM, THEN USE EXTERNAL
Jun 26, 2009 | Sony Computers & Internet
Upgrade memory - computer now won't turn on or boot
Follow this link to do it,
http://support.vaio.sony.co.uk/tutorials/memory/memory.asp?m=2108&site=voe_en_GB_cons
Hope this helps
TC and Cheers!!!!!!!!!!!!!
May 29, 2009 | Sony VAIO PCG-K35 Notebook
Drivers for keyboard funtionof Sony VAIO PCG-GR300P
You can try using and typing :" driver VAIO PCG-GR300P " ( ex: using : google search ) there is many alternative web to dowlnload driver for you
Jan 30, 2009 | Sony Laptop Keyboard 1-477-006-21 for VAIO...
Booting problems.
try right click desktop go to properties/display setting check that display is set properly go to advanced settings check out there if everything OK go to control panel/device drivers uninstall video drivers reboot it should boot with standard vga drivers check if display is OK then try loading your proper video drivers
Jul 27, 2008 | Sony (B99860307) for VAIO PCG-K series...
Pcg-fxa49 won't boot
Could be it needs the DC jack resoldered or replaced. (Sounds like its trying to start off dead battery).. These arent to bad to do compared to others weve repaired. Good luck!
Jan 29, 2008 | Sony Vaio PCG-FXA Series AMD (A8058677A)...
Sony Vaio not Booting
Have you tried booting with a windows cd, and then running a disk check?
Dec 18, 2007 | Sony VAIO PCG-K25 Notebook
Computers & Internet Logo
180 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
