Question about Maytag SAV4655A Top Load Washer
How to replace the brake pads on a Myatg Washer sav515deww
Pieces fell from th\e bottom of our washer, I looked them up and found out they where the brake pads !! Wow, I think it is the overload that my wife does when washing.
Anyways, I would be grateful if you can show me how to replace the pads, I took the front washer cover off so I am somewhat close.
thank you for your help
Ed
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 211 Answers
Searspartsdirect.com just input your model number. Look at the figures to find the part needed and order.
Posted on Sep 22, 2017
    Top Expert:
  • Maytag Master
  • 46,069 Answers
Check YouTube for something similar.
SOURCE: Maytag Top Load Washer # MAV6057AWW
I have a Maytag model #MAV6057AWW and I believe the lid switch has failed. I have removed the lid switch but I have no way of knowing if the switch is indeed bad and do not own any type of continuity tester but was wanting to use jumper wires on the plug from the wiring harness to the switch to bypass the switch. There are four labeled contact: Neutral; Line; Motor; Machine, on the switch contact (male side of plug). What would I jump on the corresponding side of the female side of (wiring harness) to safely bypass this switch.
The reason I believe it is the lid switch is because the machine failed to operate immediately after the lid being dropped closed.
Posted on Jan 13, 2008
Karthik316
  • 187 Answers
SOURCE: Loud clicking during spin cycle = Maytag washer PAVT234AWW
Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion....
Posted on Jul 20, 2009
TheMobilian
  • 8220 Answers
SOURCE: how to replace belt on washer sav515deww
Nothing to it. No tools needed. Just tip the washer back and place the belt on the pulleys. The motor is spring loaded place the belt on the pump and motor first then ease the belt around the main pulley. Have a MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 05, 2009
  • 11 Answers
SOURCE: My lid switch went out on my maytag atlantis
Very good reference can be found here... www.applianceaid.com/atlantis.html
Best wishes,
Bondo
Posted on Nov 12, 2009
kvhappliance
  • 218 Answers
SOURCE: F20 ERROR ON MAYTAG FRONT LOAD WASHER
Is it filling with water?
Posted on Mar 20, 2010
During wash cycle of my Maytag Legacy SAV515DEWW, tub moves freely and after spin cycle, tub keeps spinning for a while.
Maytag has a drum brake located on the bottom of yor machine. You need to remove the brake and clean it up or perhaps replace the device.
Google Maytag washer drum brake for several "how to"sites
Nov 30, 2014 | Maytag Washing Machines
My maytag washer is shaking violently on the rinse cycle
I am currently having the same issue with my Maytag A482. Not sure if you have found a fix yet, or if you have replaced your washer. My washer runs fine until it nears the end of the cycle, when it begins to spin and shake violently, enough to loosen the leveling feet and rock back and forth. I pulled the front panel of the machine off (two screws near the base in the front, and two clips at the top) and ran a load through it. It ran fine until the end, when the machine started shaking violently. I did notice a few small pieces of roundish felt looking material sitting on the bottom, which after some research looks like it may be the damper pad. I found these online:
Damper pad 203956
Replacement Damper 203725 for MAYTAG Laundry Appliances A482
I am hoping this will resolve the issue, I will order them this afternoon and install them once they arrive. I really hate to replace such a good washer with a new high efficiency unit, which all seem to have terrible reviews after a few months/year of use.
Aug 25, 2014 | Maytag Washing Machines
Paddle axle fell out the bottom on the pan while washing.
I looked through the manual for this unit and you need a more comprehensive parts drawing showing the drive details. They do not have this kind of detail on line, my advice is to contact them directly by phone.
http://cart.russellhobbs.com/consumer-services/warranty.aspx?sid=BreadmanUS
Nov 10, 2013 | Breadman TR2200C Ultimate Bread Maker
Replace belt on Matag washer SAV515DEww
save your money this is one major lemon, bearing goes bad in all of these pos
Feb 16, 2013 | Maytag SAV515DE Top Load Washer
Washer does not spin but makes loud clicking noise?
sounds like you could have a problem with your basket drive tube,around the clutch brake area! my machine would not spin and i found out the bottom of the basket drive tube had been ground off by the thrust washer which resulted in the clip that holds the brake release arm fell off and broke the 2 little pins on the brake release arm and it would not disengage the brake to allow the basket to spin, i bought a used basket drive tube and a new clutch ,installed and unit works fine now,,,so take a look also check your motor coupling see if it is broken ,,, and 1 more thing ,up under your agitator is the basket drive block sometimes it shears off the notches on the top of your drive tube!
Feb 17, 2010 | Kenmore 24032\24036 Top Load Washer
The spin cycle is not working. I already replaced the clutch assembly. Still, it did not wrok.
when you replaced the clutch did you look at the bottom of your basket drive tube to see if it was worn down,also the white plastic brake release arm could have the 2 little lineup pins broken off, or your drive block could be worn out,it is under your agitator,,,,,i found out on my machine that the bottom of the basket drive tube has a brass t post and the thrust washer had worn it off completely,the clip that holds the brake release arm fell off and broke those 2 little fingers off the arm,,,,,,i had to buy a used basket drive tube installed it with a new clutch and now the spin cycle works fine !! give it a good look at
Feb 15, 2010 | Kenmore Washing Machines
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
How to replace belt on washer sav515deww
Sep 05, 2009 | Maytag SAV515DE Top Load Washer
Maytag Washer, SAV571EEWW
yes if the pads are damaged it will spin in agitation. Pads are easily replaced.
Nov 17, 2007 | Maytag SAV571EEWW Washer
Spinning during all cycle
depending on how handy you are, replacement of the brake pads can be a real pain. As an experienced technician I specialized in Amana/Speed Queen for a while. I recommend you call a service man to replace the brakes. Its worth your while and your fingers.
Jun 04, 2007 | Amana NAV2330AW Top Load Washer
Maytag SAV4655A Top Load Washer Logo
110 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
