Question about Jetway Computers & Internet
P4X400dap 478 vt8235.
Jetway p4X400dap 478 vt8235.
the board powers up but get no display or dvd rom or hdd activity
    Genius:
  • 1,019 Answers
this sounds like a bios problem, faulty/corrupt.
try removing the cmos battery for 10 seconds, replace then re-boot.
If this does,nt work suspect faulty Power-Supply-Unit. Motherboard. Ram Or CPU.
Mike @ Compurepair.
Posted on Jun 15, 2009
MSI 760Gm-p23 version 3 Fx Desktop athlon II 640 cpu ,deskstar 500 gig 7200 3.5" sata II 16 MB cache hdd, mushkin 8 gig pc3-10600 essential ram, LG L49-8020 oem sata dvd rom post no issue but wont boo
make sure that the cables are right and are good make sure that the power cables are in the dvd and hard drive two cables to each one for board and one to power supply each
Mar 06, 2013 | MSI 760Gm-p23 Fx Desktop Motherboard Amd...
Wi-max light deep blue Power and charging and battery light blue-white HDD light blinking
Make sure your dvd rom does not contain a disk.
Your system checks your dvd rom drive first for a bootable disk.
A blinking HDD light is normal during boot up.
Feb 06, 2013 | Toshiba Satellite Computers & Internet
Of jetway's MAGIC INSTALL CD
I can't get you a copy of that CD but I can tell you where to get all the drivers, Bios, Utilities, and manual from:
http://www.jetway.com.tw/jw/download_show.asp?productid=P4MFM#
I hope it helps!
Jun 12, 2012 | Jetway P4MFM VIA P4M266 Socket 478 mATX MB...
Power not up
1) Please make sure that the HDD IDE cable is plugged in properly on both ends. It is a 40 pin female cord which should be seated on IDE channel 1 on the motherboard.
2) Make sure that all the CD/DVD drives are on IDE 2 or on SATA
3) Make sure taht the Jumper setting on the back of the HDD is set to MASTER
4) Login to bios and make see if you can find the HDD from the IDE drives menu. I am sure you will. From Boot menu select the NATIVE mode that will activate both the SATA and the IDE channels. Select HDD as second boot device.
Feb 01, 2012 | Intel Gigabyte GA-8I845PE-RZ 845PE chipset...
My sound device is not workin i need a sound driver of VT8235 chipset of jetway mother board
http://www.viaarena.com/default.aspx?PageID=420&OSID=1&CatID=1010&SubCatID=104 hello, this link will get you the audio driver vt8235 chipset, i also recomend the 4 in one driver for the chipset. i got all my via drivers at the via arena for my jetway motherboard. make sure it i enabled in the system bios, should be by default. so good luck! and if you need more help with it-reply. please rate this solution, thank you.
Apr 17, 2009 | Computers & Internet
Hoe to install the mother board
first install the processor. then the mother board places in the casing. screw it up. then add ram, hdd, dvd rom. at last connected the power cable, restart cable, hdd light, power light.
Jan 20, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
My motherboard vt8235 I cant figure witch order they go
i'm guessing your talking about your power LED, HDD LED, reset button etc.? Look closely on the board, there are small hints printed on it. eg... pwr, reset, spkr etc. and on the colored wires, there ought to be printed reset, power etc. just match them and plug them in. you can't do too much damage if they are wrong.
Jan 04, 2009 | Computers & Internet
Matching memory
Supported RAM Technology: DDR SDRAM
RAM Installed ( Max ): 0 MB / 2 GB (max)
Supported RAM Speed: PC2100, PC1600.
If you have already replace it and its working good. not to worry about that.
Nov 30, 2008 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Dead compaq laptop, no boot activity
Larnold..Sounding like you need to check the LCD Power Inverter Circuit board.. this is located inside the screen a long rectangular circuit board that sends power to the screen backlight & Display Panel.. Could also be a Bad Backlight.. Try Booting it.. Hold it up to a light and look closely at the screen.. If you see a faint image but no light, it is the Backlight, if Just Black No Activity then its most likely the Power Inverter, OR a Bad Video Card.. You can test the VIDEO by Connecting the laptop to a Computer Monitor or similar with the laptops VGA Serial port.. then Use your function Key and Switch to 2nd Display.....(one of your F keys.. ).. If it Shows up on another screen, Its a Display problem and not the video card... Hope This Helps alittle.. Cheers
Jun 02, 2008 | HP Compaq Presario V6000T Notebook
Computers & Internet Logo
250 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Iqbal Husain
Iqbal Husain
Starnley Johnwells
Starnley Johnwells
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
