Question about Brother MFC-8440 All-In-One Laser Printer
Front cover release button broken. where can I get a replacement?
    President:
  • 3,085 Answers
Unfortunately Brother will not sell parts to end users. You will have to call a Brother service Center
Posted on Jun 16, 2009
Dell photo 966 streaked copies
Turn off the printer and open its front cover.
Press and hold the "Continue" button. While holding it down, turn the printer on. The power LED light will now start flashing. Once it stops flashing, release the "Continue" button and close the front cover.
Press the "Cancel" button four times in a row.
Press and hold the "Continue" button. The front panel lights will now start flashing. When they stop, release the button.
Turn the printer off and then turn it on again
Mercedes Custom Parts
Jun 06, 2012 | Dell Photo 966 All In One Print Copy Fax
I changed the toner and still all the 4 buttons are all lit. And I can not print anything.
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
CautionReset the drum counter only when you replaced the drum unit with a new one.
Sep 09, 2010 | Brother HL 5140 Laser Printer
1992 mercury cougar broken glove box latch. How
you will have to pry it open and then replace the latch.good luck
Mar 01, 2010 | 1989 Mercury Grand Marquis
Has stopped taking pictures. It will focus and act like it is ready to shoot, but with or without the flash, does not photograph. Everything else seems to be working fine, screen, modes, power, zoom......
Sounds like the tip of the shutter release button has worn off. It's merely a tiny plastic nib that breaks off quite easily and commonly. Replacement of the shutter button is relatively easy. There's a fellow that sells them on ebay, although he's expensive. An inexpensive alternative would be to find a broken A510-570 ebay camera with other issues that you bid at low cost to scavenge this part.
To replace it, you'll need to gently remove the front cover, and push the old release button out from the inside. Cover it with your hand, as it will pop out with a spring. Then merely insert the new button and spring, they just pop in place.
Here's an example disassembly of a similar A560. Also please read this warning on flash capacitor shock, as your camera can really zap you if you're not careful.
Dec 22, 2009 | Canon PowerShot A510 Digital Camera
Lower button - Start Minute Plus, does not return. Spring broken?
you have a bad spring and micro limit switch. You need to pull the cover in the front in order to remove that.
Jul 28, 2009 | Sharp Microwave Ovens
How do I reset the Drum counter on a Brother HL-5140?
Caution! Reset the drum counter only when you replace the drum unit with a new one.
To reset the Drum Counter:
1. Press the cover release button and then open the front cover of the printer.
2. Press and hold down the 'Go' button until all four LEDs are lit. Once all four LEDs are lit, release the 'Go' button.
3. Close the front cover. Make sure that the Drum LED is now off.
Jul 16, 2009 | Brother HL 5140 Laser Printer
BMW X 3 Panoramic sun roof initialization.
title says X5, but description says X3. i'll explain for an X5, but X3 with the pano should be the same. and i'll explain function of the roof, not reprogramming.
button is located on the panel at the top near the front & center windshield. its the switch on the far left on this panel. its a switch that not only toggles, but also slides forward & back.
with your finger in front of the button, slide it back & release. this will make the cover slide back and store revealing the sun roof. you know have 2 options (tilt the sunroof up or open the roof completely).
to tilt it up, press up on the rear of the button and release. the rear of both roofs will pop up. to close, push up and release the front of the button or slide the switch forward.
to slide it open completely, repeat what you did to open the protective cover (slide the switch from front to back). the roof will open completely and stow out of the way. to close, slide the switch forward and release. pano roof will now close.
to close the cover, slide the switch forward again.
neat trick: if you want to tilt the sunroof open without opening the protective cover, press up on the rear of the button (when the cover is closed) and release. the cover will separate in the middle exposing about a 2-3 inch mesh, then tilts the sunroof open. to close, push the button forward again.
also, if you are above a certain speed (can't remember what it is off hand) with the sunroof open or tilted, it will close automatically, then perform the neat trick on its own to keep air coming in.
one last trick: if you want to open the windows and sunroof from outside, press & hold the unlock button (forward button on the key) and you will see the windows go down, then the roof will open to vent. releasing the button will stop the motion of the windows & roof.
hope this answered what you were asking.
Jan 27, 2009 | 2005 BMW X5
Broken front release fascia button. How do I fix it?
only thing i can think of is contact alpine and get a replacement part of find the broken clip and try to glue it stereo parts are hard to fix because the componenent are plastic usaully .
Dec 30, 2008 | Alpine CDA-9851 CD Player
Brother printer HL 5250 DN. The drum light was flashes and I have replaced the drum kit and toner cartridge.
Brother Drum Reset Instructions
The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
Dec 05, 2008 | Brother HL-2070N Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
37 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
