Question about HP Photosmart C6180 All-In-One InkJet Printer
HP6180 Printer. I keep getting an error message, Ink cartridge em
I keep getting an error message, Ink cartridge empty, to print in colour install the following cartridges : Magenta.
I have replaced the cartridge bit it continues to give me the same error message. So I replaced it again, thinking that it may be faulty.
When I do a test page all colours work, I have also cleaned the heads....help me
    Genius:
  • 1,019 Answers
some cartridges are charged up ( have a chip fitted to them )
If the chip is not charged to tell the printer it,s full of ink. this will cause the problem.
have you tried. unplugging the printer from the mains. then powering it back up.
also try using the printers own software to add new cartridges et,c.
you could also try re-installing the printers drivers/software if you have it,s instalation disk.
Mike @ Compurepair.
Posted on Jun 15, 2009
Ho do i know which ink cartridge is low
Hi
the easiest way is to send a print job to printer. If any cartridge is empty, the printer should refuse to print and display an error message. This should indicate which cartridge is empty/not recognised - with a red X above the empty colour. Another way is to go to 'printer properties' then 'maintenance' page and click on 'Status monitor' button.
Hope this helps & good luck with it.
Oct 03, 2014 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Does the canon pixma ip1200 need both the black and the colour cartridges in to print ?
You need both cartridges. It is a paradox that you need both cartridges to even scan on the mfp,s
May 10, 2014 | Canon PIXMA iP1200 Photo Printer
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
The printer's lying to me
The printer requires both cartridges to have ink before the printer will initialize and operational. Even if you are only printing black and white both cartridge have to contain ink or the printer will error out. This is standard on all ink jet printers from every manufacturer. You will have to get ink before you can print.
Apr 28, 2013 | Canon Pixma MX410 All-In-One Printer
Printer screen reads "ink system has failed. unable to print. refer to printer documentation. error: 0xc18a0301. turn power off and then on again." i have tried turning it off and on repeatedly and every...
jusr solved this off an article. the *,#,123 thing only gets you a r0046 support answer no sytem configuration menu, so.........hit cancel the hold down canel, ok black and color buttons at teh same time, error message continues, keep holding all 4 and the power off with on botton, let sit for a few seconds, my have to restart a few times but maintenaince is done and volla-fit it. up your hp-let keep em honest. andy fecteau
Aug 26, 2010 | Office Equipment & Supplies
My black ink is empty can i just get my printer to use availbale colour ink so i can keep printing?
you cannot print only using color ink, you will be able to print again if you have your ink refill or replace, its a default setting to printer not to print if the black cartridge is emptry, you will continue to recieve messages regarding this black ink cartridge
Nov 24, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printing B&W on a Pixma MP800 with empty color cartridges
no you cant print with emapty colour catridges you have to install the other full catridges.
Nov 23, 2009 | Canon Pixma MP800 All-In-One InkJet...
Pixma mx310: error message check ink u163 will not delete after replacing colour inkn cartridge cl 41. unable to use printer.
Ink has run out. Replace the ink cartridge and close the Scanning Unit (Printer Cover). If printing is in progress and you want to continue printing,press the Stop/Reset button for at least 5 seconds with the inkcartridge installed. Then printing can continue under the ink outcondition. The function for detecting the remaining ink level will be disabled. Replace the empty ink cartridge immediately after the printing.The resulting print quality is not satisfactory, if printing iscontinued under the ink out condition.
Thanks for using Fixya
source : http://support-au.canon.com.au/contents/AU/EN/8200172900.html#6
SAM ANDERSON
Sep 26, 2008 | Canon Office Equipment & Supplies
Black Printer cartridge
It will tell you the colour is low, regardless of the format in which you are printing. I don't believe Canon provide a way for you to disable this for their printer range, so you'll need to put in the new colour cartridge to get rid of this error. (you should however, be able to print whilst receiving this message)
Jun 19, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
217 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
