Question about Ryobi Garden
I have a robi 31cc don't know how to put on new string has double head i can't put the string on
  • 1,041 Answers
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Posted on Jun 16, 2009
  • Jim Parker
    Jim Parker Jun 18, 2009
    Did this solution solve the problem?
    Jim
  • Jim Parker
    Thanks for the rating!
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
HOW TO REPLACE DUAL LINE ON GRASS TRIMMER
search google for "YARD MACHINE 31CC GAS TRIMMER Manual". the manual is there I have seen it. also check youtube.com
Hope this helps...
May 01, 2016 | Yard Machines Garden
I have no spark checked switch and replaced plug what else should I check
Check the coil. Pull the boot off of the plug. While holding the boot near a metal surface, darken the room and pull the starter rope. If you see a spark, the coil is good, if you don't, you just found your problem.
Sep 04, 2011 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
I was given a used 31cc trimmer but can't get the spool off to replace it. how do i do this?
A typical trimmer has a small bump knob, an inner spool with the plastic string wound on it and the housing for that which is the string head.To remove the small bump knob, hold string head firmly and turn the bump knob counterclockwise. To remove the head entirely, first remove the bump knob. Next, remove the inner spool with string. What should be left is the spring with the end of the gear shaft showing. Some heads are locked on and some just slip over the end of the shaft. Check the gear drive just above the string head for any holes in the collar. An object can be placed in one of the holes to lock the drive and twist the head off.Ryobi's use retaining clips on the shaft which have to be removed.
May 06, 2011 | Garden
Only used my trimmer 5 times since I had, trimmed my hedges 2 times last year & twice this year. After done doing my hedges, I put on my weed trimmer when finished & holding my trimmer in idle it...
Some disassembly may be required to get to the starter/recoil unit to fix this. The unit has Torx head fasteners and some level of mechanical skill is involved. Check your warranty?
Aug 13, 2010 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
I have a gas operated 31cc Craftsman model number 316.798221 weedwacker trimmer 17 I mixed fuel with 2 cycle engine oil using a 4 to 1 ratio. The trimmer no longer starts. It seems as if it is about to...
If you have mixed your gas and oil to a 4 to one mix you have way too much oil in your gasoline. Drain out your fuel tank and carburetor. ----------------------------------------------------------------------------- Remove the spark plug and clean if necessary. Mix your fuel in a fuel container at 40 to one. Some sites even recommend a 50 to one mixture. (50 to one mixture is one pint of oil to 6 gallons of gasoline) Refill your fuel tank on the trimmer and try to crank, if it does not want to crank within 4-5 pulls then you may want to give it a very small shot of starting ether in the carburetor intake and try to crank again. Good Luck, I hope this helped, Please rate me, Thanks
Dec 30, 2009 | Garden
I need to know how to load a two string trimmer head. This is on a ryobi weedeater model 700r, 31cc, 15 inch.
most of these use 2 wires coming out of 2 holes on opposite sides roll the firstwire clockwise, then the 2nd counterclockwise so that when the spool turns the string comes out its not hard
Aug 25, 2009 | Garden
Don't know how to install new string on Echo SRM 2400
Jim
Jun 29, 2009 | Echo Rapid Loader, Trimmer Head
Renewing the cutting line
This product is driving me nuts - if someone can't help then its going into the bin
Aug 28, 2008 | Poulan 25cc 2-Cycle Gas Powered String...
Garden Logo
236 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
