Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Water is leaking from under the freezer into the refrigerator section, Is there an easy fix for this.
  • GE Master
  • 4,655 Answers
This is a common problem found with that model. Link below shows you how to solve it. It appears with what you said is the water is coming from the freezer compartment. If so then it can come from 2 things. A frozen defrost/cogged drain or your ice maker is leaking. Let me know how to refine your problem closer. Thanks, Sea Breeze
kitchenaid
-top-mount-refrigerators/">http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
http://appliancepartsandtechnicalservices.blogspot.com/
Posted on Jun 16, 2009
My refrigerator has water leaking from the freezer into the main refrigerator compartment. How can I stop that?
Ok, you have too sources of water in the freezer section. one from the ice maker if you have one, other is defrost. Either one can cause this, check the drain under the evaporator, most likely the drain is obstructed and the water has no where to exit so it builds up and drains into the lower section (gravity). Te drain can be found under the evaperator behind the false wall in the freezer section. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jan 15, 2015 | Whirlpool Refrigerators
Auto defrost works fine except for water accumlating in the bottom of unit under the bottom trays instead of in the water tray by the compressor. graywolf7499@yahoo.com
There is a leak or damage of the pipe leading from the evaporator downwards.The defrosted water is leaking out of the tubing to the bottom,replace this tubing or check the leak on the collecting tray under the evaporator.
Sep 30, 2010 | Whirlpool Refrigerators
Water is leaking really badly underneath my Whirlpool refigerator.
I had this problem. Check you water line leading to your ice maker. the plastic section of it running up into the freezer cracks and leaks. easy fix, replace the tubing if it's leaking.
Jul 12, 2009 | Whirlpool Refrigerators
Water leaking under freezer side
Hi, is the leak coming from the hinge on the freezer door? Do you have ice building up inside the freezer section?
Please let me know
Vic
May 31, 2009 | Refrigerators
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Kenmore Refrigerators
Water leaking inside the refrigerator
Hi
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 17, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice forming on bottom of freezer section. Water leaking in from back
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 07, 2008 | Maytag MSD2454G Side by Side Refrigerator
Refrigerator Water Leak from opening under Freezer
easy fix my man. couple of possibilities: 1) the fresh food gets cold air from the freezer via the vents where the water has been coming out. the water has frozen up in the vents and is blocking the airflow. the reason the water was coming out in the first place is a slow drain. open up the evaporator cover inside the freezer. get all the ice out of there and clear the drain. a little bleach will kill the gunk that made the drain flow slowly.
2) you have a defrost issue and the coil is loaded up with frost causing no airflow to the fresh food section. check the defrost heater limit and timer. none of these repairs should be over 150. but thats in lawton ok. if you live in L.A. or NYC get the wty.
May 07, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Internal water leak Amana AT5518SW
King, you probably have a defrost drain port that is frozen over. When the unit goes into defrost it's running through the air damper instead of going out the drain line. Therefore you get water into the refrigerator section. You can verify this by removing the evaporator cover in the freezer and checking the drain hole. You can clear it by running hot water into it. You will have to remove all the built up ice from water that did not drain in that area...Catriver..post back.
Nov 13, 2006 | Amana ATB2135HR Top Freezer Refrigerator
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
275 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
