Question about Hampton Bay 24750 Huntington III Ceiling Fan
Hampton Bay Garrison 52" fan stuck on high
3 mos old. Remote and receiver worked fine until this week. The fan is stuck on high. when you push medium or low on the remote, you hear a noise/pause like it is going to change speeds, but stays on high. I have reset the circuit breaker, unwired and rewired the wires in the box, to no avail.
  • 34 Answers
It seems like the 1uf capacitor is in parralel with 2uf capacitor..
Posted on Jul 09, 2010
  • 867 Answers
Nothing wrong with the power supply, or the remote, the speed switch in the fan is faulty, as it is more finiky than a manual speed change(like with a cable)
Posted on Jun 15, 2009
I have a 52 inch Hampton bay fan with remote control that will not work. model AC55200 SN002469B remote #G9P2BTAUC7052T. have put new batt in remote. will work light sometimes .No fan operation
This could be a defective receiver but if you are mixing wall switch operation with pull chain operation it may be getting confused. My local "big box" retailer sells complete Hampton Bay replacements for both remote control and receiver so ultimately that may be what's needed.
Dec 12, 2017 | Hampton Bay Dryers
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
My Hampton Bay ceiling fan runs only on high speed and the remote has stopped working even after changing the batteries. Does Hampton Bay have a life time warranty?
Yes, look up www.hamptonbay.com and get their contact number from them. It sounds like your transmitter (Remote) has failed. If it were the receiver the fan would most likely not work at all.
Jun 09, 2010 | Hampton Bay 52 In. White Redington...
Hampton Bay Deluxe Ceiling Fan SKU: 293972 Never got any but high speed. receiver # as-cf118??remote has 3 speeds. What is wrong?
you need a new remote and receiver. mine did the same thing after a few months an then it completely burntout in 2 yrs
Oct 03, 2009 | Hampton Bay 52 In. White Redington...
Model 740 154 Hampton bay Mediterranean ceiling fan
Make sure the switches in the remote and the receiver board inside the fan canopy are set to 3
Sep 06, 2009 | Hampton Bay 52 In. 5-Blade Ceiling Fan,...
Hampton bay ceiling fan (7030T) remote does not work.
This symptom is usually caused by either a bad receiver or bad transmitter. Install a new remote system (receiver & transmitter).
Apr 20, 2009 | Hampton Bay 52 In. White Redington...
No high speed on Hampton Bay Fan
The high speed motor winding may have opened. Not too common on Hampton Bay fans.
Jan 20, 2018 | Hampton Bay 52 In. Genoa II Fan, Crackle...
52" Romano Hampton Bay Fan
I have the same problem and I notice that the fan goes in reverse when I turn off and back on. I have not found the solution yet but I would say that the remote has factory defects.
Aug 18, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Dec 29, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay 24750 Huntington III Ceiling Fan Logo
626 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
