Question about BoxWave Corporation Apple iPhone 2G Designio Leather Case
I put my iphone on charge, and after 5 min. i needed to make a phone call, i clicked on the menu button, then slide to unlock, tried to type my passcode but u cant click on them they just wont work, and i cant even turn it off..
    Sergeant:
    Champion:
  • 240 Answers
This is because your battery is so flat it doesnt even have the power to turn off properly,and the program does often get "stuck" when this happens. Remove the battery, recharge the phone and it should be ok.
Posted on Jun 15, 2009
My new iphone is not showing anything on screen except itunes sirgn,how i start it, the battery was fully charged
First try the easiest solution,
turn your phone off, take out battery,leave for about 5 min.
put back together, then turn back on.
If this does not fix your problem then it my have locked you out.
this download will unlock it for you.
It will unlock iphones that were locked due to an update in itunes.
You will be free to use ANY SIMS card from ANY network.
Have your iphone unlocked in minutes not days. (about 5 min.)
It's very easy to use and there is a 30 day 100% money back guarantee !!!
http://tinyurl.com/Debbie38133
Aug 05, 2011 | Apple iPhone Smartphone
My iphoneshows on screen a green poison logo. can not open, can not charge the battery and can not reset even i pressed simulteniously or same time the switch button and the home button
Hi, First try the easiest solution,
If this does not fix your problem then it may have locked you out.
Let me know if this helps you,
Thanks, Debbie
My iphone screen is frozen. When I tried to reset the phone by powering it off, It wont allow me to slide and poweroff. the touch part is not working at all
All you need to do is to force restart/reboot it. To do that, you must press both the POWER and HOME buttons together for around 3 to 5 seconds or until the Apple logo shows up.
For more iPhone / iPad / iPod touch tips like jailbreaking and unlocking, CLICK HERE.
Apr 15, 2011 | Apple iPhone 3G
I forgot my iPhone Passcode. What can I do to unlock it?
iPhone setting:*
- Auto-Lock: 1 Minute;*
- Passcode Lock: On, require passcode immediately, after 15 min or 4 hours etc;*
- Network: Turn 3G Off
Scenario 1: Home screen is active with screen on*
1. Press power button for seconds until asked to '"slide to power off"
2. Slide to power off
3. press power button to turn on iPhone
4.*When asked to enter passcode, touch the "Cancel" key, then slide to unlock
5. bypassed passcode
Scenario 2:*
1. On the screen of being asked to enter passcode, press power button for seconds until asked to '"slide to power off"
2.*Slide to power off
4.*When asked to enter passcode, DO NOT touch any key on the screen, press power button for seconds until asked to '"slide to power off"
5. Slide to power off
6. press power button to turn on iPhone
7.*When asked to enter passcode, touch the "Cancel" key on the right bottom corner, then slide to unlock
8. bypassed passcode
Notes:
1. When Network setting changes to Enable 3G: ON, "3G" signal shows up, passcode CANNOT be passed through
Go to a underground parking lot or a lift where 3G signal is weak, when 3G signal switches to "E" (Edge), passcode CAN be passed through following above steps
2. When no 3G or Edge signal, above steps don't work
Conclusion:
Seems passcode security is related to network status
Possible security hole under Edge
Jan 15, 2011 | Apple iPhone 3G
How will i unlock a password on an iphone with knowing the phone number
If you are faces with a password protected iPhone, you can still unlock and access iPhone favorites, address book, dial keypad, and voice mail. This trick is not a high tech technique, but just a simple unlocking steps to do. This simple steps can be done because iPhone has the security flaw. Gizmogo posted this steps like the followings:
Try to slide to unlock, tap emergency call, after that, double tap the home button.
Whoola, you will find yourself in iPhone favorites. From there, you could access other menu like address book, dial keypad, and voice mail.
If you are the owner and wants to avoid this security flaw, you could do the following.
1. In the iPhone home, go to Settings.
2. Click on General.
3. Click on Home Button.
4. Click on either "Home" or "iPod".
By doing this, when someone is doing double tap, he/she will be redirected to the unlock screen (if you choose HOME). Good luck.
Dec 19, 2010 | Apple iPhone 3G
If iphone was stolen but password protected. How many attempts do they have to try to get in before iphone is disabled. Also, if they try to restore via computer and don't have same computer I have, will...
This only works if you have the older versio of software installed. This trick is not a high tech technique, but just a simple unlocking steps to do. This simple steps can be done because iPhone a flaw. Try to slide to unlock, tap emergency call, after that, double tap the home button, you will find yourself in iPhone favorites. From there, you could access other menu like address book, dial keypad, and voice mail.
4. Click on either “Home” or “iPod”.
OR TRY THIS
U can get rid of the password by putting the iphone in restore mode. Once in the restore mode, you can connect your iphone to itunes and phone in restore mode menu will pop up. Click ok, and hit restore . This will reset your iphone and all of your contents and the iphone will be back to its original factory settings.
You can put the iphone in restore mode by holding the home and power button at the same time (sometimes it only works if u hold the power button at first and then hold on to home button)
Nov 24, 2009 | Apple iPhone 3G
Need instructions and code to unlock Sciphone i9+ please.
for mobile unlock related problem or query/code whatever it might be
visit further to get assistance http://www.mobileunlockguide.com/
Jun 13, 2009 | Cell Phones
IPhone won't do anything!
Before you connect your iPhone or iTouch to iTunes.
Try and put the device into DFU Mode.
Plug your USB cord into your Device and Not into your computer.
Turn the Phone all the way off by holding the power button until the Red Bar appears and Slide it off..
Hold the "Home" Button Down for 5 seconds.
Then Push and Hold the "Power" Button while still holding the "Home" button and count to 7
Let go of the "Power" button while still holding the "Home" Button and Hold the Home button for approx 26 seconds.
The screen may or may not go blank with lines. No Worries!! now plug the USB into the computer with iTunes open. If the iphone is in DFU mode, iTunes will come up with a popup that says, "Itunes has detected an iPhone that is in recovery mode. Your must restore it"
Once this occurs, you can restore your device with any firmware by pressing "SHIFT" on your keyboard and "Clicking" Restore with your Mouse. Restore your device and let it mount to itunes.
If you are unlocking the device, I would suggest using "QuickPwn" you can get it HERE
You can download Apple iPhone Firmware HERE, when using quickpwn you will need to upgrade your firmware to 1,2_ 2.2_5G77...NOT 2.2.1
(TIP: Don't restore your iphone with custom firmware in iTunes. Restore with the original Firmware and Unlock or Jailbreak letting Quickpwn make the custom firmware....Also if you have a 3G do not ungrade in itunes to the 2.2.1 firmware, it changes the phone modem baseband and renders it "NOT" unlockable)
Feb 28, 2009 | Apple iPhone Smartphone
Dead iPhone?
I had a blank screen and couldn\'t do anything. I just held the Home and On/Off button together for about 6-10 seconds and the Apple logo appeared, after that it was all sweet :)
It is a pity this happens. Oh well, at least it was simple to reset the phone and fix my problem. Good job Apple :P
Aug 01, 2007 | Apple iPhone Smartphone
BoxWave Corporation Apple iPhone 2G Designio Leather Case  Logo
149 people viewed this question
Top BoxWave Corporation Cell Phones Experts
Andrew Taylor
Andrew Taylor
richie46
Bill Boyd
Are you a BoxWave Corporation Cell Phone Expert? Answer questions, earn points and help others
