SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
SOURCE: Printer KYOCERA FS-1030D not geting connected to my local Netwok.
I cannot remember the name of the utility but I know on the new drivers for the newer machine it is built into it it discovers the machine baised on its mac address and you can change / set the ip from there.Try some of the utilities from the kyocera support sitehttp://www.kyocerasupport.co.uk/index/download_center.html
SOURCE: kyocera fs-1920 printer fault
if the machine is starting up and you just replaced the toner cartridge make sure it is seated properly also did you shake the cartridge slightly before fitting sometimes the cartridge can compact the toner and it doesnt agitate to the dev unit properly. check also if the dev unit has been reset properly and the lever set in place..
SOURCE: Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green
light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
SOURCE: kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
