Question about Lexmark Wheelwriter 6 Series II Typewriter
IBM wheelwriter 6 Series II
The typewriter will not return.  You can start typing and when you go to hit the return it will not return.  It acts like it is stuck.  Can you help with this??
  • 418 Answers
Re: IBM wheelwriter 6 Series II
Try turning the machine off put a SMALL amount of oil on the large round rod running across the typewriter manually push the print head left and right a few times to see if it will loosen up. The problem is usually caused be drying oil you may consider having it serviced by a pro.
Posted on Nov 01, 2007
How do i change the font from 10 to 15 on Lexmark IBM Personal Wheelwriter
Posted on Aug 12, 2008
I wish to purchase a wheelwriter for IBM Personal Wheelwriter 2
Arnold Cochran
Posted on Mar 16, 2008
  • 73 Answers
SOURCE: Typewriter won't return carriage
If cleaning and oiling the shaft doesn't work, the carrier motor is probably bad. Is there any noise when you hit return?
Posted on Jul 31, 2008
0 characters
3 Points
Turn the sound off of IBM Wheelwriter 3.0 Series II
The only sound you can turn off is the optional spell check feature which is done by holding down the code button (left of the spacebar) and then hitting the number 1. Any other beeps cannot be turned off.
May 08, 2014 | Lexmark Wheelwriter 6 Series II Typewriter
IBM Wheelwriter 6 typewriter. The print wheel does not move when typing and acts as if in stencil mode
From your posting it sounds like you have cracked plastic print solenoid cap. We sell them for 20.00 with instructions.
Apr 29, 2014 | IBM Wheelwriter 6 Typewriter
Ibm wheelwriter 6 Series II
Your print solenoid probably has a broken cap. There are some companies that sell the "kit" with instructions on how to replace the cap.
Apr 28, 2014 | IBM Lexmark Wheelwriter 6 Series II
Where is the TYPEWRITER SOLENOID on a IBM Wheelwriter 6 Series II
The "print" solenoid is what hits the hammer that hits the printwheel and makes it type on your paper. If you remove the ribbon and look straight down in the carrier on the left side you can see the solenoid. It is below the blue piece of rubber that sits on the hammer arm. The end of the solenoid is supposed to have a cap on the end of the plunger. This cap gives a specific clearance so when it is activated, it hits the hammer arm to propel it forward to strike the printwheel.
Apr 28, 2014 | IBM Wheelwriter 6 Typewriter
How to solve a problem with an IBM Wheelwriter 10 Series ll Model 6783
It is most likely a bad keyboard. You can try my fix under WW1000 or contact Geo. Beyers Co. for a rebuild.
Feb 28, 2013 | Swintec Ibm Wheelwriter 10 Series Ii...
Wheelwriter series II when I hit return the
The silver shaft that the carrier slide on needs a little lube WD40 works well. Also check for any deprid under the carrier that could interfere with its movement.
Dec 26, 2009 | IBM Typewriters
Need to reset all the margins on IBM Wheelwriter 10 Series II. The margin release button will not release the left margin.
The problem may be that the carrier is binding on return, put some light lube (WD40 works well) on the silver shaft that the carrier slides on.
Jan 15, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
Try a little light oil on the printer shaft. WD40 works well.
May 13, 2008 | Lexmark Wheelwriter 10 Series II...
Lexmark Wheelwriter 6 Series II Typewriter Logo
935 people viewed this question
Top Lexmark Typewriters Experts
James Cagle
James Cagle
john archer
Ron Dufek
Ron Dufek
Are you a Lexmark Typewriter Expert? Answer questions, earn points and help others
