Question about Whirlpool AD70USS Dehumidifier
White westinghouse dehumidifier freezing up
Have used this dehumidifier for 4 or 5 years with no problem. Now I plugged it in because the basement seems damp and it freezes up on me. Is there anything that I can do, or do I have to take it in.
Thank you
  • pstrohmeier Jun 16, 2009
    Tried the float, it still froze up. It freezes within 5 minutes of turning it on.
    my model # is MDH25HW1 on the white-westinghouse that freezes up.
I have had that problem for a while, on mine the Evaporator turns into a solid block of Ice, at first it seemed like like the room was to cold because raising the temp helped to keep it from freezing but then I found out that it has a Thermistor mounted on the evaporator, a Thermistor is a Resistor that becomes less resistive as temperature drops, when the evaporator temp gets low enough to freeze up, the Thermistor tells the control box to shut off the compressor until the evaporator temp goes back up above freezing.
I tested the Thermistor and control box on mine (hopeing I just needed a new thermistor which should be available I would think for less than $5 at a electronics supply store) by cutting replacing the thermistor with an adjutable resistor from a broken Guitar, I turned on the Dehumidifier, waited for the compressor to turn on, then adjusted the resistor from 27,000 ohms to 0 ohms and the ol'compressor just kept on'a runnin :(
So mine has a problem with the control box. If yours is just starting to freeze up then shutting off the compressor automaticaly and letting the fan run to thaw the evaporator like it should, I would try raising the temp in the room. Raising the temp of its opperating environment will directly raise the opperating temp of the evaporator and condenser and in turn help keep it from freezing up. The paperwork that came with it should give you a minimum working temp so check that too. I am going to see if I can buy a replacement control box or rigging up another temp sensor and transistor between the compressor relay and conrol box. They should have included a thermostaticaly controlled presure regulator in the system as a backup like the A/C system in some cars have.
Posted on Jan 06, 2010
  • 867 Answers
Hopefully its not the coolant pump seizing. the only simple thing that goes wrong with those is the water full switch, which turns off every thing. try playing with the float thing in the tank, you shoud here clicking of the switch on and off
Posted on Jun 15, 2009
Your problem is,the room is too cool and too damp. Shut down the unit and let it thaw.Place the unit on a sturdy table or stand.(warmer temp off the floor)Place a small fan where unit draws air (most units draw from the rear) this will keep it from freezing the coils. After the humidity level drops after a day or so,you should be able to stop using the fan.
Posted on Jan 03, 2010
Whirlpool Basement Dehumidifer is freezing up about l/3 from the bottom. Compressor will not turn off. Coils were cleaned and cleaned fan is running freely. Sitting in well ventilated area and temp...
IIt may very well be that the the air intake filter needs to be removed and cleaned. But, before doing this, turn the unit OFF & unplug it. Allow the unit to completely thaw, before removing the filter.Never operate the unit without the filter in place, As this could damage the unit.
Hope this helps you & thanks for choosing FixYa.
Sep 11, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
The unit still makes a running noise but seems to collect no water. this unit is about 4 years old but stopped collecting water about 2 years after purchase
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 30, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have a customer who has a model 1700 dehumidifier Connected to ductwork with a/c only air handler. Not Sure why this is needed or correct way to wire. Also There is no remote humidifier & unit is...
I have to agree with you. I don't see the need for the dehumidifier either. As the AC unit alone, does have some dehumidifying capability.
Your customer would be better served using an independent Low Temp dehumidifier in the basement. If that's the area they are trying to dehumidify because of dampness in the basement.. It certainly would be less costly to operate. But, any unit that is not a Low Temp unit won't work well in a basement.
I hope this helps and good luck convincing your customer of this.
Thanks for choosing FixYa.
Aug 24, 2011 | Aprilaire 1700 Dehumidifier
MY unit keeps on freezing up no problem with the filter dirty it gave me a problem after 3 months of use . i set it for 60% 50% it freezes up all the time i shut it off let it defrost and same thing all...
I think a part of the problem is that you have the humidity extraction level set to high. 50 to 60% is pretty much the humidity level throughout most of the year. Lowering it to 35%m should make a difference.
If you are using this in a basement application, the temperature at floor level can be 10 degrees cooler than at shoulder level. Most dehumidifiers don't work well at temperatures between 40 & 60 degrees F. Unless, they are Low Temp models designed for basement applications. Raising the unit up off the floor onto a sturdy table, counter top, etc. That can handle the weight of the unit, plus a full tank of water can resolve this problem.
If you can access the cooling coils, they may be dirty and need wiping off with a damp rag. Then flow with a dry clean rag to dry them. A light coating of WD40 helps to preserve the coils.
I hope this helps you to further troubleshoot and solve the problem. Thanks for choosing FixYa.
Jul 26, 2011 | Maytag M7DH45B2A Dehumidifier
Dehumidifier freezes up
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Jul 01, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Whirlpool dehumidifier in basement has stopped taking water into
how warm is the basement,if the temp of the basement is lower than say 70 degrees,the unit will not function,true dirty coils can have this effect also and a refrigerant leak on these will cause the same result,if the temp is low,use a fan to move the air and this will help with your humidity problem too
Apr 02, 2010 | Whirlpool AD35USS Dehumidifier
Whirlpool AD70USS Dehumidifier Logo
1,950 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Mike
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
