Question about Paragon Hardware & Accessories
PARAGON TIMER MODEL#4005-0S
I'M QUITE SURE THIS IS AN "OLDIE"  I NEED THE DIAL/TRIPPERS/PINS.  ARE THEY STILL AVAILABLE????? THANKS VALERIE
  • 1114 Answers
SOURCE: The Trippers on my Paragon Electric timer are
The following Web Site lists tripper pins for Paragon timers. I don't know if your model is listed, but give it a try.
I hope this helps!
http://www.icca.invensys.com/paragon/parts_accessories.htm
Posted on Aug 15, 2009
  • 52 Answers
SOURCE: I have a Paragon 7008-00 timer that has no trippers
Go to electricalexpeditors.com
Posted on Dec 30, 2009
Testimonial: "thank you very much for your responce. I had tryed the paragon website and it was very little help to me. I have found the correct trippers now."
  • 52 Answers
SOURCE: Need trippers for Paragon #4004-20
send inquiry to electricalexpeditors.com
we sell replacement parts
Posted on Feb 02, 2010
  • 52 Answers
SOURCE: I need to find Paragon timer model P101 parts ie.
call 1888 782 6086 www.electricalexpeditos.com
Posted on Jun 25, 2010
  • 760 Answers
SOURCE: I'm looking for trippers for a paragon timer for
Try this link, lots of good pictures
Posted on Jul 19, 2010
I need trippers for timer paragon 4001-00m
1) Paragon is no longer making X2772 trippers for the 4000 series timer.
Some places may still sell the X2772 tripper.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
2) I saw X2772 trippers for $60 spring 2011. And the ad did not say the trippers were new.
3) Buy replacement T101 Intermatic timer for less than that.
Example at Amazon showing T101 indoor timer: For outdoor timer, buy T101R.
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
4) Crossover wiring from Paragon 4001-00 to Intermatic T101:
Paragon terminal 1 goes to Intermatic 1
Paragon terminal 2 goes to Intermatic 2
Paragon terminal 3 goes to Intermatic A
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
5) Add a comment for more help
6) Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 14, 2011 | Hardware & Accessories
Moved time pointer on pool timer to set time than read instructions moved pointer back to original spot now timer does not click on or off when it passes pins
Timer brand and model number are not shown.
Brand and model appear on inside of timer door.
Moving stationary pointer will not affect on-off operation of timer. The pointer is just reference for setting current time.
Worn trippers can cause problem.
Trippers are softer metal and designed to wear down so timer mechanism lasts for decades.
Intermatic pool timers use set of 156T1978A trippers.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Tork timers use P47 tripper on 24-hour clock dial
http://www.frontierlighting.com/find.jsp?a=1&ID=,Photo.Cells...Time.Controls,Replacement.Trippers
Paragon 4000 series uses X2772 tripper. Paragon timers are discontinued and trippers hard to find.
Open following links for different timers:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Tork-timers-and-manuals.html
Aug 01, 2011 | Hardware & Accessories
My model 1015-00RS timer comes on when it's set to be off at certain times, I push big dial down and it goes off, but then the next day it does the same thing, is there ajustment for fine tuning the...
I might not understand the problem correctly.
Open following link to identify timer:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#1015
From your post, the large dial on your timer can be pushed up and down?
Or are the trippers popping up?
The dial is supposed to rotate clockwise during regular operation, and can be manually rotated either direction to set current time, but dial should not move in and out or up and down.
If the trippers are worn, then they are built in. The problem is that Paragon is no longer making parts and does not support 1015 timers.
It's possible the trippers might be getting pushed up if the on-off mechanism needs lubrication.
May 2011, Patriot stills sells the 1015-00RS for $187
http://www.patriot-supply.com/products/manufacturer_detail.cfm?manu_id=191
Intermatic 120Volt-480 Volt crossover product is T1975 (advantage is replaceable trippers, motor and switch)
Grainger sells T1975 for $126
http://www.grainger.com/Grainger/INTERMATIC-Indoor-Multi-Operation-Timer-6X761?cm_mmc=GoogleBase-_-Electrical-_-Timers-_-6X761&ci_src=14110944&ci_sku=6X761
Crossover wiring for 120Volt application:
All wires on Paragon 1 to Intermatic Clock
Paragon 2 to Intermatic Com
Paragon 5 to Intermatic NO
If there are wires on Paragon 6 to Intermatic NC
Upvote the help.
May 30, 2011 | Paragon 1015-00RS Indoor Multi Operation...
We have a Paragon Time, Model #4001-00, TD-1744-00 at our softball field to control bathroom lights. The 2 ears or shut-off and turn-on devices were lost during some electrical work and we cannot find...
Thank you for including model number.
1) Open following link to identify timer and download manual
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
2) 4001-00 series is heavy duty Nema 1 indoor 40 amp 120Volt mechanical timer with analog dial.
I don't recognize TD-1744-00
I'm not sure what you mean by 'ears'
3) Maybe you mean X2772 trippers?
Trippers are set on dial to control on-off switching.
If trippers are missing, Google search for X2772 tripper and some places still sell them.
4) If another part is missing, you might not be able to find that part, but you can photograph the problem and add a comment to this thread and include photograph so I can look at it.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
5) if you have to replace timer, some places still sell Paragon 4001-00, or replacement is Intermatic T101 or T103 timer
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Apr 01, 2011 | Paragon Hardware & Accessories
I need a tripper for my hot water heater timer... It is paragon model TC2 series A883-20. Can you advise?
I've read an expert here say that Paragon is out of *this* business now and that they are making defrost timers exclusively. I'm not so sure about this however. I would contact Paragon directly to learn if they have trippers available still for your timer.
If not - they may have suggestions for a direct replacement timer that would fit into your existing timer box. I have replaced several this way as it is preferable than removing cables, etc. when the exterior box itself is fine.
Mar 03, 2011 | Water Heaters
I have a Paragon 42013-20 timer, no longer manufactured. I need to find replacement trippers. Thanks for any assistance.
I cannot find a brochure showing specific paragon tripper numbers.
You have Paragon 42013-20 timer, DPST 10Amp 2Hp, Nema3 indoor-outdoor, 24 hour-timer with 48 trippers built into timer dial.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#42000
If trippers are worn out, you can possibly work-around by rotating dial 12 hours so fresh trippers can be accessed using same dial. The only difference is nighttime hours shown on clock face will now represent daytime hours.
Intermatic Cross reference shows replacement timer is T1976R
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
http://www.intermatic.com/~/media/files/intermatic/catalog/pages/014.ashx
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial%20with%20skipper.aspx
http://www.drillspot.com/products/648036/intermatic_t1976r_24_hour_electromechanical_timer
Difference between your paragon timer and suggested intermatic, it that Paragon throws both terminals at same time, while Intermatic has alternating NO NC terminals.
Add a comment for more free help.
For a price, expert works with you via e-mail or phone while you work on timer or any do-it-yourself project.
Feb 23, 2011 | Paragon 42013-20 Timer
Jst bought the house and there is a paragon 4100-0 light timer how do you reset the on-off times to approx. 5 pm on and 11 pm off ?
Paragon 4000 series timers are traditional electro-mechanical timers.
The dial rotates around like a clock as time passes
Black and silver tripper pins on attached to outer edge of dial.
Black tripper is Off
Silver tripper is ON
The tripper pins encounter a lever.
The On tripper pushes lever one direction, the Off tripper pushes lever opposite direction
Click manual override to switch lights by hand
To set current time, lift and rotate dial until current time lines up with black pointer.
Set your trippers on the dial next to the On and Off times you want.
Set silver tripper at 5:oo
Set black tripper at 11:oo
Minimum set time is 1 hour
e62b9e8.jpgParagon 4000 series
If this is not the correct timer, answer back with a description and I'll check my files
Oct 24, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
We have an AMF Paragon 4001 timer for the light outside our building. The light goes on lately at the wrong time. We want it to be on at 7:00pm and off and 5:00am but it goes on at 12:00 at noon.
To set paragon timer: Pull large round dial straight out towards you, then rotate dial until correct time is lined up with stationary 'pointer' on front of dial
Sep 08, 2010 | Paragon 4001-0G Defrost Timer
I'm trying to set the times on a paragon amf 7 day timer
There should be 2 trippers for each day, the trippers slide on the outside of the dial and would point to the time of day you want your lights on and off. The silver trippers may be gone on that aged time clock, but are easily obtainable.
Jan 14, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Hardware & Accessories Logo
178 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
