Question about Sewing Machines
Elna threading and reverse instructions
I dont know where my reverse is located, and I dont know how to properly thread the tension roller on the lever.   This is an Elna Primula 410.
Thanks in advance.
  • 2 more comments
  • Anonymous Feb 23, 2008
    recieved my inlaws elna primula 410 no manual can't figure out how to thread it. help please
  • Anonymous Mar 26, 2014
    How to take off tension assembly on elna SU star series 62
    Thread tension assembly removal
  • Anonymous Mar 30, 2014
    machine is squeaks like it needs oil. Where are the places I put oil into.
Threading an Elna Primula 410 - put the thread on the top rear spindle - then through the open metal guide at the back of the top (avoiding the tensioned bit on top as this is for the bobbin winding), then down through the tension wheels (making sure foot is up) - under metal loop at bottom, back up through metal loop at top - down again with thread running over top of two metal bars - then through loop on top of needle & then thread needle!
Hope this helps...
Posted on Mar 11, 2008
I have a Primula 310
The reverse is located in the middle of the stitch length dial, you press in the button whilst you reverse.
When threading up any sewing machine make sure the foot is 'up' as this opens the tension disks and the thread goes between. when you lower the foot the discs close around the thread and add the tension.
Hope this helps
Posted on Nov 01, 2007
What settings should my elna 410 be on for thick fabric such as canvas
You may want to change the tension slightly to make sure the top & bobbin threads meet in the middle of the fabric. Use a heavier needle and thread. Increase the stitch length. And possibly change the presser foot pressure or use a walking foot, roller foot, or teflon foot. If the pressure is too heavy, the presser foot may "push: the top layer of fabric in front of it so the top fabric is slightly stretched or puckered.
Jan 04, 2018 | Elna Sewing Machines
Need threading instructions for Elna SPECIAL not Super circa 1969-71
Sewing machines basically thread in the same manner--from the spool through a thread guide or two, then through the tension disk, up and over the take-up lever, then down through guides to the needle.. Just be sure to ALWAYS RAISE the presser foot when threading the top thread so the thread will seat fully in the tension disk.
May 08, 2017 | Elna Sewing Machines
How do you adjust the tension control on an Elna lotus SP
The tension dial is on the front of the machine right above the needle. The higher the number, the tighter the tension is applied to the top thread. HINT: When threading the top thread, ALWAYS RAISE the presser foot throughout the entire threading process. This allows the thread to seat completely in the tension disk. Tension is correct when the top and bobbin threads meet in the middle of the fabric.
Elna Lotus Instruction Booklet
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
Elna SP ST SU sewing machine repair tips (I use liquid Tri-Flow Synthetic Lube or silicone spray to loosen parts seized from old oil. Do NOT use WD-40, cooking oil, motor oil...)
Apr 29, 2017 | Elna Sewing Machines
How do i adjust the tension on elna 2003?
Not quite sure what you are asking. The upper tension is governed by the tension disk. Higher number is tighter, lower number is looser. Usually, the mid-range is a good place to start. Tension is correct when upper and bobbin threads meet in the middle of the fabric.
NOTE--ALWAYS RAISE the presser foot when threading so the thread will seat in the tension disk!
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
How to Adjust Sewing Machine Tension on Craftsy
Just FYI:
Why my Elna sewing machine is bad Or dont buy an Elna 2007
Dec 08, 2016 | Elna Sewing Machines
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
How to adjust the tension on ELna F4. I started out with the factory settings but the needle threads are very loose no matter how high I turn the tension.
Be sure to raise the presser foot BEFORE threading the upper thread so that the thread will seat properly in the tension disks.
Sep 18, 2015 | Elna Sewing Machines
I can not get the bobbin thread to catch, what should i do, elna primula 410
try a new needle--one for the fabric being sewed
rethread the machine--top and bobbin
make sure the bobbin is correctly inserted and turned the right way
also could be a timing problem, the machine may need to be checked
Mar 29, 2015 | Elna Sewing Machines
I have the Elna 320. The top thread is getting caught in the bobbin and creating a snarl. What's wrong?
probably the top thread is not under tension correctly, or the thread has not been placed into the take up lever, its generally a miss threading or lack of tension on the top thread that leads to it being pulled down into the bobbin area. Recheck your threading from scratch, always thread up the top with the presser foot raised as this opens up the top tension discs so the thread can properly seat into the tension device.
May 29, 2014 | Elna Sewing Machines
Standard tension setting
I can't see your model listed, only Elna Sewing machine, which may be one of the newer ones or could also be an older Swiss made. machine. So, can't tell if you've got a top loading bobbin where the bobbin case is integrated into the machine. Or some Elnas such as the Contessa and Primula were a front loading bobbin in a case, these are a bit different in setting the lower tension.
But generally, you shouln't need to mess with the lower tension, and top tension should be in the range of 5, sometimes 4-6 depending on what you are sewing. If you are having top thread issues its more likely to be a gunked up tension device or something missed in the threading path causing the issue. If you can add in your actual model I may be able to assist more specifically.
Aug 26, 2013 | Elna Sewing Machines
Sewing Machines Logo
1,032 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
