Question about Troy-Bilt Garden
I have a troy-built rear blade tiller. It starts fine but when the blades hit the ground they stop turning.
  • 22 Answers
Your belt is likely slipping. To adjust the belts, slide the block down that the roller on the forward/reverse lever uses to lock the tiller into forward. Use a 9/16" wrench to loosen the bolt on the backside of the block, then slide the block down a bit and retighten the bolt. If it's not the belt slipping, you've got transmission gear or bearing problems that could be costly to repair. I hope it's the simple adjustment.
Posted on Jun 16, 2009
Smoke pours from engine when blades are turned on. what is the likely problem?
Not much to go by in description. Could be clutch burnt out or something preventing blades from turning freely causing clutch to overheat. Really need more info to diagnose.
May 08, 2016 | Troy bilt Super Bronco Tiller 208cc
Troy built super bronco mower won't start and doesn't even make a sound
cheak all the safety switches blade switch and seat and cluch
May 18, 2013 | Garden
Blades wont rotate
Check for a broken pin or loose grub screw in the drive area of the box.
Mar 11, 2013 | Troy Bilt Tiller/Edger 26cc, Model No....
I own a 42" Troy Bilt zero turn. The PTO switch
What the problem is (im not sure if they are called this) but the deck pulley brakes are worn out.
Basically if you look under the rider frame side (on top of the deck). There are on each side for each spindle pulley a flat metal tab. On the underside of that is just like a brake on your car. So when you raise the deck the pulley brakes hit the top of the pulleys and stop them from spinning. Which cause the blades to stop spinnign. There are probably turning at 10% of there normal speed. If that sound like what its doing check the brakes.
They are a replaceable part. Sorry I just cant remember exactly what they are called. Over the years they just wear out like a set of brake pads on your car. And the mower cuts and just work fine. Thats where I would start. When they wear out, the friction material is gone. Best Reguards, Premium FixYa Support
Jul 26, 2011 | Troy Garden
Cutting grass and hit a stump started to smoke under the moer stopped it and restarted no smoke but the blades would not engage runs fine but blades want engage will turn by hand
I did the same thing last year and took it to a replace shop that I new was reliable. It turned out to be a bent crank shaft. It was cheaper to buy a Craftsman, which was on sale, than have the older one repaired.
Apr 01, 2010 | Garden
Can't start my Troy Built Tuffy tiller. I haven't used it for a year, but it started fine last season. I replaced the spark plug, changed the oil and air filter and filled it with fresh gas. When I pull...
First pull your spark plug out reconnect to the plug wire and ground tot he engine body
Pull the starter cord and see if you have a good clean spark that goes to the electrode and not to the side of the spark plug.
If no spark check your off/on switch
Mar 31, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have a troy pony 17.5 that cuts off when you engage the blade and the choke is on. what can i do to fix the problem. thank you for any help to fix this problem
does it run ok off choke with blade not engaged can you rev it up ? if not it sounds like the carbs got issues ? if it does check the second wire coming off the igntion coil too the safety switch may be grounding /shorting causing engine to shut off kinda like the handle on your push mower when you walk away and let go of the handle the zone control cable stops the spark and flywheel ? carb rebuilds at your local shop are under $100 well worth it unless youve done it before kit costs like $15
Aug 25, 2009 | Troy-Bilt Pony Garden Tiller
Troy Built Ride-on, stalls when blade is engaged.
You may have a short in one of your safety switches. There is usually one on the seat that shuts it off if you try to get up and one on reverse if you try to back it up. I would look there to see if somehow they are grounding out
If you can get it where you can grab the blades, check and see if they float easy. You could have a seized bearing on one of your blades that is stalling out the motor as well.
Hope this helps
Aug 20, 2009 | Garden
Troy Bilt tiller dies when I engage the tines.
Bogging down may indicate debris or old gas in the carb. Try doing a carb cleaning, and add a small amount of Seafoam gas additive to your gas.
Mar 21, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
280 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
