Question about Cyberhome CH-DVD 300 DVD Player
I get no picture on TV
I simply have the combined red,white & yellow cables plugged in from the DVD player to the video in on the Toshiba TV.  I hit play on the remote and NOTHING!  What am I doing wrong?
  • 80 Answers
Dear friends,
Press and hold STOP button on front panel of the player more than 5 sec. The player reset after 5 sec.
Posted on Mar 25, 2009
I have a coby dvd 224 player connected to Emerson tv, and all I see on screen word video and no picture.
if you're using RCA video cables red white and yellow plug the yellow wire from the DVD player into the green input on the TV and then plug the two audio cables red and white into the same input red and white on the TV it's the green one that carries the video signal this is generally call the component input because it breaks down the colors into their components most DVD players do not have component outputs but if you hook the green and the yellow from the DVD player you should get a picture
Jan 28, 2015 | Coby Televison & Video
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
I am trying to hook the dvd player up to my old tv and am only getting sound, I am using the red, white and yellow cord.
I hope this will clarify things, you have 3 connections on each end.
  • Yellow Cable goes on Video Out (Yellow)
  • White Cable goes on Left Audio Out (White)
  • Red Cable goes on Right Audio Out (Red)
  • Yellow Cable goes on Video IN (Yellow)
  • White Cable goes on Left Audio IN (White)
  • Red Cable goes on Right Audio IN (Red)
the coaxial audio connection does NOT need to be connected.
I hope this helps,
Mar 10, 2011 | Toshiba SD4990 DVD Player
How can I connect my dvd player to a Philips 32PFL5605H/05 32-inch Widescreen Full HD LED TV ? It is of the type which has one red, one yellow, and one white connector but i do not see any sockets that...
The included cable with the red, yellow and white RCA connectors is a composite A/V cable. To connect this cable to the TV, you need a SCART-cinch adapter. Then use one of the SCART connections on the TV. Note: the SCART connection does not handle HD signal.
You will get a much better picture if you buy a different cable. Depending on your DVD player, get either an HDMI cable or a pair of cables - a component video and audio cable. (Both component and the audio cable will have RCA plugs at each end. The component video has 3 plugs - red, blue and green. The audio will have 2 plugs - white and red.) Both of these will carry HD signals. Most DVD players will have at least component video and composite video jacks; some have the HDMI output. Most DVD/VCR combinations will need the composite video for the VCR and the component video is optional for the DVD signal.
I hope this helps.
Dec 24, 2010 | Philips Televison & Video
I have a 1994 zennith TV/VCR COMBO I am trying to connect a dvd player to. I have one yellow video cord and one double stranded audio red/white cord. I can not get a picture. Vcr player does still work.
Connect yellow from DVD to TV. Connect white and red cables from DVD to TV. Yellow to yellow, white to white etc. Then select on the TV using the remote, the proper input (where the DVD is connected) Press PLAY on the DVD player.
Aug 19, 2010 | Zenith Televison & Video
When i connect my dvd player to TV i only hear sound but no picture
hi there
your dvd player got three cable one red two white
three yellow ok here i go dvd player input plug in the yellow cable in the yellow in put @ the back of your dvd dvd player
the white cable and red cable is your sound the yellow cabe is your picture see that you have a yellow input @ the back of you tv and plug in the yellow in it then it will work
Dec 14, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
I simply don't understand how to hook up the DVD
OK simple mind maybe this will help. Cable bos to DVD and DVD to TV. A set of red and white cables are for hearing (audio) ( red is general right and white is left) the holes that you plug them into should also be color coded the only real trick is that they are flowing in the correct direction. They should go out from the cable box in to the DVD and then a set should go out from the DVD and into the TV. The Yellow is for video on some units. Not all units need the yellow. Since it is cable there should be a cable connection from the wall to the cable and the only place that might need the yellow is from the DVD to the TV depending on your model of TV. Mine for example, uses an HDMI cable instead of the yellow plug ins. Hope this helps!!
Jun 15, 2009 | Supersonic SDAT SC-25 DVD/Karaoke Player
Cannot get DVD's to play on our TV.
It depends on what kind of inputs your TV has; here are a few of the most common, all of which your DVD player supports (best quality first):
1) COMPONENT VIDEO (Red, Green, Blue)
If your TV has three inputs for video colored red, green, and blue, this is your best bet for quality video from your DVD player. You may need to buy a component video cable from the store (somewhat pricey, but great quality) which consists of three cables (again, red, green, and blue) stuck together. Just plug the red/green/blue cables into their correspondingly-colored ports on both the DVD player and the TV.
That covers your video. To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the red/green/blue cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
If your TV has a yellow input for video, just use a regular yellow RCA cable. Plug it into the yellow video-out jack on the DVD player, then plug the other end into the yellow video-in jack on the TV.
To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the yellow cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
3) COAXIAL JACK (Antenna port)
If your TV only has a coaxial jack that you currently plug your antenna or cable line into, you'll need to buy an RF modulater and a short length of coaxial cable (you can find these anwhere: Walmart, Radio Shack, etc).
Plug the RF modulater into an electrical outlet, then plug your antenna/cable line into the "antenna in" jack on the RF modulater. Take the coaxial cable that you just bought and plug it into the "antenna out" jack on the RF modulater, then plug the other end into the antenna/cable jack on the TV. The RF modulater should have a switch on it somewhere that sets either the number 3 or 4; depending on which number you pick, that's the channel that your TV has to be switched to to view the DVD player.
Now you're all set to connect to your DVD player. Just follow the instructions in section (2), only now you're going to plug your cables in the RF modulater instead of the TV.
(I hope this wasn't too confusing; it really is a lot simpler in practice than it is in explanation...)
May 04, 2009 | Televison & Video
I am trying to connect an akai dvd player to directv, please help
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
Jan 31, 2009 | Akai DVD-3850S DVD Player
KS3102 Koss DVD player hookup to Toshiba how??
I have an owner's manual for that system and would be glad to copy the diagrams for you. Additionally, I think that you need red, blue and green wires from the back of the Koss to the inputs on the TV.
Oct 02, 2007 | Koss KS3102 System
Cyberhome CH-DVD 300 DVD Player Logo
54 people viewed this question
Top Cyberhome Televison & Video Experts
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
