Question about HP Photosmart C6180 All-In-One InkJet Printer
Poor print quality
I have an HP Photosmart C-6180 All-in-One that has worked great for a couple of years. Recently my copies started to come out weak in appearance and seem to have a "greenish" tint. When I check the ink gauges they are all filled up and none are low on ink. What do you think? Thanks, Carlos
    Problem Solver:
  • 18 Answers
You might want to check the resolution settings by right clicking your printer in control panel/printers and select a higher resolution or if it is Draft Mode move it to normal, if this doesn't correct the problem, you may have a faulty printer head, meaning you'll need to buy a new printer cartridge.
Posted on Jun 15, 2009
HP 6180 Print Problem: I'm getting horizontal streaks when printing either in colour or black, Have cleaned the heads through the printers tool box and ued both levels of cleaning. Also aligned the pr
Fill an old black cartridge with hot water and scan and copy something with a lot of black on it. cleaned out my black ink clog after about 12 copies. Put new ink in and it's working fine. Oh yeah, use a syring minus needle to fill lower o-ring on back of cartridge.
Dec 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
Poor print quality
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 17, 2010 | HP Photosmart Premium C309A All-In-One...
HP R927 says that the 4GB card i recently bought wrong format
ok ...see that into the side of the card( if its a SD) has a slide like button with 2 positions ...one of them is the unlocked one ...after that either format it into the camera if it has that feature...or just connect it to the computer and it will be found somewhere into the My computer as a removable drive ....just right click and format in Fat 32...this is the actual storage format fit for this cards..
Oct 30, 2009 | HP Photosmart R927 Digital Camera
Print Quality Poor - HP Photosmart 2575 All-in-One
You can download the manual from Software & Downloads here.
Then work through this article and see here to diagnose the printing problem. Make sure the print quality is set for photos in the print preferences or properties.
You might try cleaning the cartridge contacts as described here.
Make sure you are using a good quality paper, that it is feeding correctly,
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 30, 2009 | HP Photosmart 2575 All-In-One InkJet...
I have an HP 6180 that works fine except the colors are WAY off -- everything is muted and dull and the blacks are very weak. I've tried everything in the print dialogue box -- switching to application...
Bugger! HP wants your printer to work, so you buy more ink! Mine works beautiful
Scan a good photo and print it out or insert SD card and print photo on PHOTO paper GLOSSY SIDE DOWN Inkypete
Apr 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
Photosmart 6180 won't print black
Been ther and done all of the stuff Have pulled the ****** apart... wont go into detalis try copy black only sheet of text 12x20 times then run head clean I was getting white sheets output if no black run 25x3 times black only on copy then do head clean For me Voila! BLACK Inkypete
Jan 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
Poor color print quality HP Photosmart 2710 all-in-one
yes..do a clean heads and re calibrate..if you have print manager, it can be done from there.
might be able to get them through this printer driver link
Mar 09, 2008 | HP Photosmart 2710 All-In-One InkJet...
Poor photo printing
Have you manually cleaned the printheads. Bad clogs from different reasons sometimes cannot be removed by the printers own cleaning system. Use a good quality solution and thoroughly clean heads.
Jun 28, 2006 | HP PhotoSmart 7760 InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
129 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
