Question about GE (PSS26MSRSS) Side by Side Refrigerator
PSS25SGNA GE Artica refrigerator a spring fell out
PSS25SGNA GE Profile Artica side by side refrigerator - a spring fell out on the floor from the bottom near the door hinge, and now the door will not stay shut. A small plastic roller/wheel piece also fell down; appears to be from the lever that is pressed when the door closes.
Do you have a diagram of parts for the lower section of this frig so that I can order and replace parts myself?
3 Suggested Answers
mgprice
  • 744 Answers
SOURCE: How do we adjust the door height on our GE Profile
Hello, Take the cover off the top hinge and then remove the top hinge and the door, the problem may be a worn hinge cam, if it is replace it. If the hinge is loose tighten the bolts. Once the door is off you will see how the lower hinge can be adjusted. Hope this helps! Mike
Posted on Dec 02, 2009
ltldab
  • 152 Answers
SOURCE: The lever at the bottom of the door on the hinge
IF YOU ARE NOT COMFORTABLE DOING IT GET SOMEONE ELSE. YOU WILL PROBABLE NEED TO REMOVE THE DOOR WHICH IS HEAVY AND AWKWARD.
Posted on Feb 26, 2010
Ge profile artica profile freezer on top -- refrigerator clicking and not cooling
Check compressor is working. If not, replace relay and check. If still compressor not working, you have to replace compressor.
Feb 12, 2011 | GE Profile Arctica 25.4 Cubic Feet...
Temperature in refrigerator will not stay set. It keeps getting colder. I have a GE Artica model PSS27SGMD. It is a side by side with ice through the door. It is +- 9 years old
GE Artica had problems with the "Motherboards" originally installed. They have since switched manufacturers so my educated guess that is the problem.
Jan 08, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ge profile artica refrigerator door will not close
clip on bottom of hinge is worn or broken had mine replaced. magnetic seals are not strong enough to hold the door closed on their own. Original problem was the magnets were too strong so the clip on the bottom hinge was added.
Sep 26, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE profile Artica, MDL# psc23mgnabb, ice maker won't make ice, plus refrigerator side is freezing the contents
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 27, 2010 | GE Profile PFS22 33" Artica French Door...
I have a GE Profile ARtica side by side. Ice maker is acting up
The dispensor door not closing completely . Replace the flap solenoid and plunger behind the dispensor controls .
Aug 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Artica side by side stainless steel wont get cold
The Profile and Artica are good refrigerators. the problem may be the defrost element, defrost thermostat or the mother board. Let me know if you want help on this one. Thanks Sea Breeze
Jun 18, 2009 | GE Profile Arctica Stainless Steel Top...
Ge profile artica side by side flooded my kitchen floor,seemed to come from freezer. Help please.
It's most likely a leak in the line feeding the icemaker -- or it may just be loose. Could be the valve, but less likely. It'll have to be removed to find out.
May 12, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile Artica refrig is freezing food
Replace the cold control
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
126 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
