Question about Dynex DX-SC5.1 Sound Card
Stereo is working but not the 5.1 channels
The card is working but only the left and right channel are outputting anything. I have it set at the 5.1 channel mode and when I do the audio test in the Dynex control panel the speakers will all work seperately just fine. Anyone have any advice?
    Problem Solver:
  • 18 Answers
Download the realtek audio manager and install it, that should fix the problem
Posted on Jun 15, 2009
No volume on all left side speakers
Determining the Cause of the Problem Let's assume our system has a head unit, a crossover, a two channel amplifier and two door speakers with only the right speaker working (the left speaker is not working). If the door speakers are behind the door panels then we want to make sure the speaker is the problem before removing the panel. We'll work backwards starting with the amplifier and ending at the head unit. Testing for a Speaker Problem With the vehicle and the stereo turned off disconnect the speaker wires for both the left and right speakers at the amplifier. Now connect the left speaker to the right amplifier output (which we know works). Turn on the stereo system and make sure the balance is set to the middle position.If the speaker still doesn't work then the problem is somewhere between the amplifier and the speaker Testing for an Amplifier Problem Now we'll need to see if the amplifier channel is bad. Put the left speaker back on the left amplifier channel and the right speaker on the right amplifier channel. This returns the speaker wiring to its original configuration. Again, with the vehicle and stereo off unplug the RCA cables from the amplifier's input and switch them so the left cable is in the right input and vice versa. Turn on the stereo system. Testing for an RCA Cable Problem For any intermediate components between the amplifier and the head unit follow these steps for each one. We only have a crossover so we'll just do this once. Begin by testing the RCA cables between the intermediate component and the amplifier. Unplug both RCA cables from the intermediate component's output. Now plug the working channel's RCA cable into the non-working side of the crossover. In our case the working channel is the right so plug the right RCA cable from the amplifier into the left side of the crossover. Turn on the stereo system.
If the right channel continues to work then you know the problem is in the RCA cables between the amp and the crossover. esting for a Crossover or Equalizer Problem At the input of the intermediate component (in our case the crossover) flip the RCA cables around (left to right input and vice versa). Turn on the stereo system.
If the right channel continues to work and the left channel continues to not work then you know the problem is in the intermediate component. Replace or repair this component.
If the problem is now in the right speaker and the left speaker works then the problem lies before the crossover. Turn off the stereo system and return the RCA cables to their normal places.
Testing for a Head Unit or RCA Cable Problem Pull out the head unit from the dash so you can access the RCA cables. Unplug both RCA cables from the head unit. Do not disconnect any other wiring. Plug the right RCA cable into the left channel of the head unit. Turn on the stereo system.
Sep 29, 2016 | Cars & Trucks
No stereo sound
first this needs to know if set has internal left and right speakers
Aug 31, 2012 | byD sign Televison & Video
Hi my amp left channel does not work. the speaker relee works at both channels and the amp works fine at the right side.it goes not in protect what do u think is wrong ?
It could be a number of things. Try this test first though. Play some music and swing the balance control to the bad channel and turn up the volume all the way if needs be. If you hear any music breaking in the pre-amp is ok. If not it could be dead. Again if you hear faint music it's the power amp that's not working.
Next have a look inside. You should be able to identify the channels by following the wires from the speakers. Remember that stereo amps are just two mono amps joined. So the Right Channel will act as a guide to what the left should look like. Plus if you are any good with a volt meter provide the correct voltage indications. Any burnt/damaged parts on the left and not on the right is an indication of the fault area. If you have no output from the above test pay close attention to those parts on the heat-sink for the affected channel.
Ignore the power supply parts are anything that is on it's own, unless it's an IC with both channels going into it. As they can go faulty on one channel, but not the other sometimes.
If you can't find anything it might be an idea to replace the left output device(s).
May 19, 2011 | NAD 218THX 2-Channel Amplifier
I have the xp 300 and in stereo mode it only works on one channel or the other, not as 2 seperate channels
If you are saying that it only works on say the left channel in stereo mode, but both channels come on in mono, then there's a fault in the amplifier's pre-amp. These days they are an IC, it can be traced by following the input wires to the point on the PC Board and then looking around for an IC with all inputs going in. If you are lucky there might be two! One for each channel. Replace the one on the dead channel. You can test it, either the single IC or both, touching it's pins with an insulated tool while the amp is on. It will buzz on the channel. Stereo amps have two sets of identical parts, except when an IC is involved. But even then that will have two halves (inside it). You just need to touch the pins of the IC, with the tool, but don't short the pins together! You should hear at least 4 buzzers. One at the right input, one at the left input, one each at the left and right output. If you only get the left an right output buzz, plus the good channel input buzz, you know it's the IC that's gone.
Mar 29, 2011 | Gem Sound GemSound PA-585 2-Channel...
Hi I have a mackie sr series 24.4.2.b bus miximg console in for repair,most of it is working except that the right channel output is misssing on on sub outputs 1 and 5 and 3 and 7,i do not think its...
Remember that the subs are each MONO outputs. They do not have stereo outs. They can be used as pairs like 1-2 for stereo and those should PAN with the pan control at each channel assigned to a sub.
For mono's, the left channel is the one used.
Refer to the signal flow diagram for the Mackie mixers to analyze this. It probably is on page 28 of your manual.
For the subs, you can pan AT THE CHANNELS ASSIGNED between for instance sub1 and sub2. Note these work together as odds and evens.
Jul 14, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
No Left Output
check stereo settings after that if it still persists your left channel is goin out
May 21, 2009 | Audio Players & Recorders
I need speakers for my Onkyo A-911M integrated amp
A+B speakers = 4 channels 2 right 2 left
100 watts/4 = 25 watts per channel
RMS watts / channel = 25 x .707 = 18 watts/channel which is your average consumer stereo system
I would use 8 or 16 ohm speakers (not 4 ohm) -- almost any set of stereo speakers will "work" -- these will be 8 ohm and about 5 watt minimum / 40 watt max thereabouts
May 07, 2009 | Onkyo Audio Players & Recorders
No stereo signal out from yamaha p 2500 s
It's unclear what type of connectors are on the end of the cables(s) coming from your computer.
This amp only works with mono 1/4" TRS and XLR connectors, not standard RCA connectors.
Did you try the Right one in the Left Channel to see if the Left Channel worked?
Refer to the following manual and read up on the connectors (page 7) and the use of the Stereo/Parallel/Bridge Switch (page 8). When it is NOT in Stereo Mode the unit only uses the Right Channel controls and input.
http://img3.musiciansfriend.com/dbase/pdf/man/m_480824.pdf
STEREO/PARALLEL/BRIDGE switch
Use this switch to select the operating mode.
• STEREO mode
Channels A and B operate independently (as with a conventional
stereo amplifier). The Channel A input goes to the Channel
A output jacks, and the Channel B input goes to the
Channel B output jacks.
• PARALLEL mode
The Channel A input signal is output through both the Channel
A and Channel B output jacks. The Channel B input jacks do
not function. Channel A and B volumes can be independently
adjusted.
• BRIDGE mode
The Channel A input signal is output from the BRIDGE output
jacks. To adjust the volume, you must use the Channel A volume
control knob.
Apr 03, 2009 | Yamaha P-2500 Amplifier
How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
Dec 16, 2008 | Marantz PM7200 2-Channel Amplifier
No audio in/out right channel
you need to check the sound is card is 4:1 or 5:1 or 2:1 set.
Aug 05, 2008 | ASUS A8N-SLI Premium Motherboard
Dynex DX-SC5.1 Sound Card Logo
325 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Mike
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
