Question about Nokia N70 Cellular Phone
My phones battery was drained, so i charged it but when i tried to TURN IT ON, it is requiring lock code but i never had it locked. when i tried my SIM CARD to other phones, it opens. where do i get a lock code so i can open my phone?
Try the default code from your service provider or nokia default lock is 12345 try it if not it requires flashing...........
Posted on Apr 10, 2010
    Problem Solver:
  • 5 Answers
You have to buy another one she's worthless
Posted on Jul 01, 2009
When i switch my phone on it says phone lock and have to enter a code how can i do this?
Basically it will never ask for a phone lock unless somebody does.the default code for samsung is 00000000 (8 zero).If does not work, you need to go to a service center to retrieve your code,that is if you want to preserve your important files inside the phone.
But if you have a back up,you can format your phone by doing this.
* turn off your phone
* remove battery
* remove simcard and memory card
* put the battery back and be sure it is fully charged.
* turn on the phone the type *2767*3855# ,a process takes place,wait until its done.
(try *2767*688# if supported,this will only reset your phone lock and nothing will be erase)
Now your phone is in default settings and phone lock free.
Hope this solution helps...thank you and please come again.
Jul 24, 2011 | Samsung SGH-J750 Cell Phone
I forgot my lock code,my phone is second hand phone..i dont know what is the lock code..i wan to format my phone but cant.. -.- sorry for my bad english -.- ,need help..[nokia6680]
try this
turn your mobile off
remove sim card
put battery back in
hold green call key, 3 key and * key, while holding them down power on your mobile.
this will reset your mobile completely, but should also reset the security code.
only do it on a fully charged battery
you will lose everyth
Mar 27, 2011 | Nokia 6680 Cellular Phone
Battery power just seems to drain away very quickly
Please check the voltage on the terminals of the battery in the phone. If the voltage is good then check the voltage on the battery, if low the battery is faulty as it may not be retaining the required current factor. Best way to confirm is to swap with one of your friend's phone.
If adapter voltage output is low , try and check with another adapter before it can be changed.
Mar 03, 2011 | Cell Phones
I forgot the lock code of my n73..hw to reset it?
Backup all ur data like music, photos etca and fully charge ur cell phone and the turn it off. Now press Call button, Starec button (*) and Number 3 button.. Keep holding them and turn ur cell phone on and keep holding those keys until a screen saying formatting comes... Now ur cell phone is fully resetted, ur lock code and every thing else.... Be sure that ur battery is fully charged and battery does now get disconnected during this process... Thanks...
Feb 19, 2011 | Nokia N73 Cellular Phone
Nokia n97 input phone lock code
If the device asks for a PIN code or lock code, enter it, and select OK. The preset lock code is 12345. If you forget the code and your device is locked, your device will require service and additional charges may apply. For more information, contact a Nokia Care point or your device dealer.
Dec 15, 2010 | Nokia N97 Cell Phone
I forgot my phone lock and when i try to format my phone it requires the phone lock. How can i change the phone lock?
press call,*and 3 keys at he same time then power it on wait for your phone to fully start, make sure that the battery is full of charged before executing this.
Oct 15, 2010 | Nokia N70 Cellular Phone
Phone locked
WARNING: ALL CONTACTS AND OTHER SETTINGS MAY BE LOST DURING THIS PROCESS!!!
Method:
Before you start, make sure the battery is charged and all security codes or PIN codes or watever are disabled so we dont have any code prompts interfering with this method.
1. Turn off the mobile phone.
2. Insert a "Non-accepted" SIM card (sim card that wont work) half way in so that when you turn on the phone, it still says "Insert SIM".
3. Turn on the phone.
4. Enter the following code and wait patiently for phone to reset:
*2767*2878#
5. Once reset has completed, the phone will still say "Insert SIM". This is where you need to push the sim card all the way in. You can use a paperclip or a tiny object to push it in if you have difficulty. IT IS IMPORTANT THAT THE PHONE REMAINS ON AT THIS STAGE (TRY NOT TO LET BATTERY FALL OUT) IF BATTERY FALLS OUT, DO NOT PANIC, JUST START FROM STEP 2 AGAIN.
6. Enter the following code and wait patiently for phone to reset:
*2767*3855#
7. After reset is completed, SIM should work and also the reception. Don't get excited, its not unlocked yet.
8. Now we want to make it permanent. First check what locks need to be deactivated with the following code:
*#7465625#
a)
If Network Lock is "Active", put in the following code:
*7465625*638*00000000*00000000#
Message should be "Network Lock has been personalised" or similar.
Then:
#7465625*638*00000000#
Message should be "Network Lock deactivated" or similar.
b)
If Subset Lock is "Active", put in the following code:
*7465625*782*00000000*00000000#
Message should be "Subset Lock has been personalised" or similar.
Then:
#7465625*782*00000000#
Message should be "Subset Lock deactivated" or similar.
c)
If SP Lock is "Active", put in the following code:
*7465625*77*00000000*00000000#
Message should be "SP Lock has been personalised" or similar.
Then:
#7465625*77*00000000#
Message should be "SP Lock deactivated" or similar.
d)
If CP Lock is "Active", put in the following code:
*7465625*27*00000000*00000000#
Message should be "CP Lock has been personalised" or similar.
Then:
#7465625*27*00000000#
Message should be "CP Lock deactivated" or similar.
e)
If SIM Lock is "Active", put in the following code:
*7465625*746*00000000*00000000#
Message should be "SIM Lock has been personalised" or similar.
Then:
#7465625*746*00000000#
Message should be "SIM Lock deactivated" or similar.
Apr 29, 2009 | Samsung J700 Cellular Phone
Security lock code
There's no magic involved here you rated my reply as:
Rating Locked! (?) leezzy has rated this solution as Inappropriate I was trying to help, I gave you the Master code, that's the code required to reset your Security code.
If you think I'm giving you inappropriate info try a repair shop, then when they have solved your problem, come back to me and tell me I didn't know what I was talking about.
Mar 11, 2008 | Nokia N70 Cellular Phone
Phone locked!!!
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
install this software
this will show ur lock code
http://files.myopera.com/manujha/soft/UnlockMe.SIS
Feb 24, 2008 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
35 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
