Question about Saeco Vienna De Luxe Espresso Machine
Stuck vienna digital stays stuck on ventilate
  • 1,089 Answers
Hi If you can get water flowing by opening the steam knob, then check the tip of the wand for a plug. Remove the black tip by loosening the cap then pull the black cover off. If a paper clip can go all the way up the wand that should be clear. If that didn't solve it, you have a blockage in your flow meter.
Posted on Jun 16, 2009
How to decalcify and ventilate the machine
Use diluted CLR to remove calcium, and then fill the water reservoir with vinegar, let this sit for a couple hours and then run the machine. Immediately run it again with water. Let it sit and dry for a couple hours and run water through it a final time before making coffee.
Mar 06, 2011 | Saeco Vienna Digital Coffee Maker,...
CAN NOT MAKE A COFFEE DO NOT UNDERSRTAND THE MESSAGE I GET.
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
Apr 25, 2010 | Saeco Vienna De Luxe Espresso Machine
I've got a problem with my Saeco Vienna Digital. It says that I've got to fill the watertank and ventilate. But the watertank is filled, that little 'thing' in the corner of the watertank is still going up...
Check the end of the steam wand it might be blocked, if it is not, then remove the steam wand and check the top there is a small teflon insert (this part is in some models) remove insert and toss. If that does not solve problem then machine needs to be descaled.
Jan 12, 2010 | Saeco Vienna Digital Coffee Maker,...
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Stuck on ventilate
Try this, open steam wand, if it calls for ventilate pusi in steam knob, if that works then the tap rod on the steam valve needs to be replaced. To me it sounds like the machine is building up pressure and the discharge is not releasing through the water circuit.
Apr 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna is full of beans but the bean light stays on
the sensor may be stuck that tells the majer there are beens in it ..look in hopper feel around!
Nov 28, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Digital De Luxe Espresso Machine
sounds like there maybe a vapor lock problem... where there is a problem with the hosing... or vaccuum-like mechanics inside of the machine... Perhaps even there is "gunk" or milk stuck in the steam wand. you have a few options... get a milk pitcher that reaches almost to the top of the steam wand and fill it with ice and water. Allow it to soak for a period of time until, say, there is a decent amount of condensation that has gathered on the outside of the cup. then clean the inside with something that can reach and is non-abbrasive... *a straw may work* clean it out manually... then soak again. try opening the steam wand again and let it steam in the water... if it's not working... preform a cleaning cycle... and include a 'smigin' 1tsp. or 1 tbsp. of vinegar in the water resevior. and let it run all the water through the steam wand... if possible. if it is still posing a problem definantly contact warranty services... or seek a saeco tech in your neck of the woods!
hope this helped!
Dec 07, 2007 | Saeco Vienna De Luxe Espresso Machine
Machine Is Stuck on "VENTILATE" Command
Sounds like you all have the same problem. Your flow meter has been obstructed with a small chip of coffee bean that got into your water tank receptacle when your tank was off. You need to remove the top or back depending on your machine and remove the flow meter. It twist apart. The intake is a small opening and that is creates the jet of water that spins the flow meter. If it gets obstructed the meter doesn't spin and you will get the ventilate message.
Dec 05, 2007 | Saeco Vienna De Luxe Espresso Machine
I had this problem on my Saeco Vienna Digital a while back. I read somewhere just to keep on ventilating, even if it took 20 hoppers of water. Sure enough after about 16 cycles, I heard a change in the noise and looked to see the ventilate sign was gone.
Oct 24, 2007 | Saeco Vienna Digital Coffee Maker,...
Saeco Vienna De Luxe Espresso Machine Logo
131 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
