Question about New Braunfels Cattleman Smoker 99204805
I have a New Braunfels Heavy duty "Oklahoma Joe" wood fired meat smoker. The ash collector trey is rusted out. I need a new ash collector trey. The model number is 04201003
  • Dan Webster
    Dan Webster May 11, 2010
    I have one too and i sure wish me and you could get us another one.
  • 867 Answers
Inexpensive solution is to go to any hardware store, buy some sheet metal (thin gauge) and make it yourself, even if you have to buy sheetmetal snips
Posted on Jun 15, 2009
How to slow cook food on a char-broil smoker, model CBBA-2750. (what temperature and length of time as well as instructions on how to cook)
Hi hcf6886...
To use your Brinkman Smoker or Other Smokers
1... Marinate or place a rub on the meat you will be smoking, and let it sit for a few hours or overnight in the refrigerator.
2...Cover your wood chips with water(and if you wish you can add some Jim Beam Whisky or other flavorfull liquids in a bowl with the water, 1 inch above the wood chips and use a flat peice of metal (pie pan,etc.)to weigh the wood chips down underwater.
You will do the wood chips at least 24 hrs before you plan to start smoking this gives the wood time to soak in the flavorfull liquids.
3...Start a fire in the smoker having the fire below the meat, but do not put the meat on yet, wait till the flames die down first.
Once they are coated with gray ash, you can place the meat on the racks and add your soaked chips to the smoker.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat if you are not using a water pan in that position.
4...Place the meat in the smoker on the grilling surface, and place the wood chips over the charcoal and hardwood in the main grilling area Close the lid and do not open it unless you must add wood chips during the cooking process.
5...Continue adding wood chips to the tray as needed during the time you are cooking.
If you have a Brinkmann or other smoker with one chamber for placing the wood chips and the meat, add wood chips only once per hour.
6...Apply your sauce to the meat one hour before the meat should be done.
Test your meat with a thermometer for for an internal tempreture of 160 degrees for medium and 170-180 degrees for medium well to well
Note: Apply the sauce quickly to avoid loosing the heat in your smoker if you leave it open too long it will allow the heat and smoke to escape, increasing the cooking time.
Close the lid if it needs to continue cooking till you reach the right internal tempreture
7...Test your meat with a meat thermometer after a few hours of cooking time.
Make sure your meat is at least 160 degrees internal tempreture for medium and more than 170 degrees for medium to well.
Close the lid and maintain your heat if it needs to continue cooking.
Please take time to rate me.
Sep 18, 2011 | Grilling
How to use a char-broil smoker (charcoal) with wood chips smoking briskit. ( what temature should the grill be at ?)
Hi hcf6886...
There are not directions on how to use the smoker. Do you have have any instructions on using the masterbuilt smoker model 20020611
Hi dan480volts...
Maybe this will help you
Sep 16, 2011 | Masterbuilt 20050106 Propane Smoker
How long and at what temp do i smoke rims with the masterbuild smoker
Hi todd649...
3...Start a fire in the smoker having the fire below the meat, use hardwood or charcoal,
Once they are coated with gray ash, you can place the meat on the racks.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat.
Sep 05, 2011 | Masterbuilt 20070106 Electric Smoker
I have never had a smoker before is the water pan the bottom one or is that the wood chip pan?
Hi
3...Start a fire in the smoker having the fire below the meat, but wait to put the meat on till the flames (if any) subside.
Use the water pan below the meat (if you use one) to catch the juices from the meat...it will be above the pan with the charcoal in it.
Use hardwood or charcoal for your fire/smoke,
Once the charcoal/wood are coated with gray ash, you can place the meat on the racks.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat, if you do not use a water pan.
Monitor the tempreture
Sep 04, 2011 | Grilling
I do not have manual for using brinkman gourmet charcoal smoker
Hi tsanelli...
I could not find your user manual on the net, but I have this..
1... Marinate or place a rub on the meat you will be smoking, and let it sit for a few hours or over night in the refrigerator.
Aug 27, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
I need instructions on using my big chief smoker as I haven't used it in a couple of years and lost the original instructions - basicly I am set to start smoking Salmon and need the preparation...
Hi jmcomber..
To use your Brinkman,Luhr Jensen Smoker or Other Smokers
Aug 05, 2011 | Luhr Jensen Big Chief 9890
I have purchased a used upright New Braunfels Smoker and need an instruction manual on how to use it, ie. how much charcoal, cooking times, etc.
fill it almost half way spread it evenly and make sure the coal is fully fired before you but any meat in. If charcoal still burning not fully fire and red do not put any meat in the grill. Cooking will depend on what you cooked and quantity of meat. The more the meat the longer it will take. My suggestion is to keep your eyes on what your cooking and if need to pull the meat out and test it if needs to. By testing the meat here and there paying attention with hands on will give you and idea how your grill works. everyone cook or smoke differently, some like it juicy and other like it juicy/dry or fully cooked. Buying a grill is like having a new girlfriend, you have to get the feel to know that person. Smoking will take a bit longer than standard grilling. Hope that help some..enjoy!
Jul 10, 2009 | New Braunfels Cattleman Smoker 99204805
Need an instruction manual
It sounds like you have an "offset smoker". The fire goes in in the firebox (the small offset box). If you have a rack that fits in the firebox, you can put that in there too and use it to grill.
Go to www.charbroil.com and click on "instruction manuals" and find the manual for the one that looks the most like yours. Char-Broil took over New Braunfels a few years ago.
Once you have it assembled, there are huge resources on the web on how to use it.
Personally I rarely use charcoal, I prefer the taste of cooking with Pecan wood - if you live in Texas you can buy a 50lb bag at Academy for about 10 bucks.
I grill over the firebox part directly (although I often close all the dampers and let the meat smoke a little while cooking). A few times a year I'll smoke a turkey or other meat in the main chamber, keeping the fire in teh firebox.
Apr 09, 2009 | New Braunfels Black Diamond Smoker...
New Braunfels Bandera Smoker instructions for use
i have that same smoker. it is very easy to use u just have the fire box waterpan,smokehouse,racks and air vents. i start out with a little pile of wood(apple,cherry,oak,hickory,mesquite)and some newspaper to get the fire started. then u fill your water pan about a third of the way. close it up and get it to the right temp depending on what u r cooking. the key is getting good ventilation to make sure your meat is not over smoked. then just monitor your temp till your meat is done. anymore questions email me at rvguy22@yahoo.com
Oct 23, 2007 | New Braunfels Bandera 99205600
Grilling Logo
209 people viewed this question
Top New Braunfels Grilling Experts
Rob Sinbad
Rob Sinbad
Mike Squire
Vernon Taylor
Are you a New Braunfels Grilling Expert? Answer questions, earn points and help others
