Question about Sony Playstation 3 (PS3) Console
Playstation 3 system plays some games but not others and says that the system is corrupted
  • 24 Answers
Wow that is the worst thing ur ps3 can say my second ps3 sed and it never worked for 1-2 long weeks so i called sony and told them my prob they couldnt fix it for me but i did get a new ps3 because i was luckly on warinty .
hope i helped
Posted on Aug 06, 2009
    Problem Solver:
  • 12 Answers
You need to reinstall your os. There is a place in the xm bar to restore OS to original factory settings.
Posted on Aug 05, 2009
Corrupted files, how do you repair?
Can you still play the game ok? If the game you are trying to play wont start up, then the disk could be damaged. If it is downloaded content, then the file could be corrupt and require a more stable connection to install.You may have to delete everything about the said game including offline files to reinstall. Good luck, and I hope this helps.
Jul 07, 2015 | Sony Playstation 3 (PS3) Console
Playstation 3 hard disk files corrupted???
hey ash,
ps3 Hard drive needs to be manually reformatted and checked for bad sectors.
as what youve said, you already formatted it and yet it still says there is a corrupt system file.
when i say "manually formatted" you have to clearly take the hard drive out and format it using another pc or ps3.
Jun 03, 2008 | Sony Playstation 3 (PS3) Console
OmI have a game that wont play anymore I went and brought the same game new and it wont play either
If you have not tried playing other games since this problem started, you should do that now. Also, clean the PS3 laser lens in the disk drive just to be sure this is not the problem (in many cases it is). Also, if this is a game you have already played and have data files for, they may have been corrupted, but if you delete the corrupted data then it should work fine. If this does not help, it still is most likely a problem with your system; a sign that there are some malfunctions within the hardware. If this continues (or gets worse), contact Sony and they should provide you with a refurbished system.
May 02, 2011 | Sony Playstation 3 (PS3) Console
My playstation 3, which i bought this christmas, new, is crashing alot. Alot more every day. we play call of duty black ops but it does it on a couple other games as well
Usually heat or bad sectors/ corrupt sectors on the hard drive will cause this issue.
I'd recommend getting two cans of compressed air, taking it outside and clearing out the dust, then when you play cod run a mini fan directly onto the unit.
COD runs heavy on the graphics hence it happening more with that game than others ;)
Mar 06, 2011 | Sony Playstation 3 (PS3) Console
Will not play any ps3 games or movies
The PS3 has a special Recovery Menu, which you can access in the following way:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
Thank you
Jun 04, 2010 | Sony Playstation 3 (PS3) Console
Playstation 2 will not save "corrupt file"
some times the memory card are not compatible whit some games try another memory card
Jul 19, 2009 | Sony Gran Turismo 3 A-spec for PlayStation...
Playstation 2 memory card will not save ''corrupt file''
well if while its saving you turn off the system it will go corrupt just delete the file and restart
Ps3 will not play any games
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 07, 2009 | Sony PlayStation® 3 (60 GB) Console
Play station 3
my play station 3 said the hard disks file sistem is corrupted
Aug 27, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3 wont read some cds or play downloaded demos.
I'm also having this problem as well, it has to do with the OS and it is corrupted. It seems like the "Game mode" has been corrupted preventing us from playing games on the hard drive or reading games.
Apr 09, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
