Question about Whirlpool GHW9250M Front Load Washer
We are getting an F02 code indicating a drainage problem. It is draining properly but it is like it thinks there is still water in the tub, it's dry.
  • 6,784 Answers
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Posted on Jun 15, 2009
Try the easy stuff first. Make sure there is no blockage in the filter or that there is nothing stuck in the drain pump.
If all good there, take a look at the CCU. It is a tan colored, rectangular box at the top and back of the washer. Pull all connectors and remove the box. Gently open the top (8 tabs hold it in place) and inspect TR6 for damage. Not sure which part number you have (should be printed on TR6).
Posted on Dec 15, 2009
He4t error sud and f2
Hi, "F02" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system somewhere. In most cases this means there is a clog in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean.
The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Jun 16, 2011 | Kenmore Elite 45986 Front Load Washer
Keep getting f02 code and check all drain hoses and the pump for debris and the filter and still keeps getting the code and the pumps sounds like it is runnning or just humming
unplug the machine f02 is something is caught in your hose or your pump or your drain line F02" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system somewhere. In most cases this means there is a clog in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced once again please message me back if you have any further questions and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Dec 12, 2010 | Kenmore Elite 45986 Front Load Washer
F02 code
If this is a Kenmore Elite series front loader, "F02" is a Long Drain error. This is usually an indication of an obstruction somewhere in the drainage system. In most cases, the drain pump reservoir needs to be cleaned out. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you check the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, as well, and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage this small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Apr 25, 2010 | Kenmore Elite 45986 Front Load Washer
Our Kenmore HE4T frontload washer is displaying an F02 troubleshooting code. What does that mean?
"F02" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. Most commonly, there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608545-f02_error_code
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Dec 17, 2009 | Kenmore Elite 45986 Front Load Washer
110.42926200 HE3T, F02 Error
"F02" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system somewhere. In most cases this means there is a clog in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
Nov 26, 2009 | Kenmore Elite 45986 Front Load Washer
Has code f2 will not start up,or reset when u un plug it
check that the water supply lines are not kinked or clogged, and that water is coming to the washer
Nov 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting an F 02 error close to the end of the cycle (rinse/spin) Not sure what the 'white plug out' described by a previous user is can anyone help
"F02" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. In most cases this means there is a clog in the drain pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Code F2 appears and water won't pump out
"F02" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. In most cases this means there is a clog in the drain pump. The following link explains:
Oct 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting error message f 02 which is a drainage problem but there is no drainage problem??????
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4THUMBS rating is appreciated for answering your FREE question.
Sep 23, 2009 | Whirlpool Washing Machines
Front loader f02 code
Check the entire length of the drain hose as well. This is from the bottom of the wash tub, to where it connects to the drain pump, to where it exits the washer to the standpipe. The two error codes can be directly related to each other. "F02" usually indicates a clog or failure of the drainage system. "Sud" can be caused from using too much, or improper detergent. It can also be caused when the drain pump is not functioning properly and is pumping air. If you have tried the "Rinse & Spin" option to clear the error, and you have verified all of your drainage system and still have a problem. It is recommended that you replace the drain pump. It may be running, but the impeller may be damaged and it is not pumping water properly. The following links may be of assistance to you:
http://www.fixya.com/support/r629564-suds_error_whirlpool_kenmore_front
You may have already viewed this information, but posted it just in case you may have overlooked anything.
If you determine you have a failed pump and which to replace it yourself, the following link explains how:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
If you require addtional assistance, please let me know. I hope you find this information helpful.
Aug 17, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool GHW9250M Front Load Washer Logo
144 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
