Sharp had a standard VGA socket on it?, with an adaptor for connecting
Component to it (via unused pins). but presumably you simply connect via a VGA lead and select
the PC input on the menu
ure HD is cool on a computer monitor, but it's nothing like a huge HDTV.
How
you do this will depend primarily on your PC and your HDTV. Lucky for
us that they both share some common interfaces. The most common
interface is DVI for computers and component for HDTVs. You have a few
options here. S-Video and Composite won't work because they only carry
SD signals and what fun would that be?
Before we get started I want to mention that all TV's are subjective to some
overscan,
yes all, but some more than others. At the very least 2% and at the
very most 10%. Normally you don't notice, but when displaying your
desktop on your HDTV even a small amount of overscan is noticeable. If
you plan to watch movies and other videos it won't bother you. If you
are planning to surf the web or play video games it can be more
intrusive.
If you are one of the lucky ones who have a DVI port on your computer and a DVI or HDMI port on your HDTV. You can buy a
cable and set your computers output resolution to one that is supported by your HDTV.
That is
This seems pretty simple, but unfortunately it isn't always that
simple. HDTVs and computer monitors don't always support the same
resolutions. All the video standards are covered in this image. It is
confusing but useful. The main thing to pick up from the image is that
PC's don't use the same native resolution as HDTVs. Some HDTVs can
accept standard PC resolutions like my Sharp AQUOS. To see which
resolutions your HDTV supports check out the manual. Most companies
have their manuals online so if you don't have yours head over to the
manufacturer's website to look it up.
As you can see from the
grid my HDTV supports most resolutions, the other great thing about
this TV, is that there is no overscan at PC resolutions, but there is
at normal HDTV resolutions. Unfortunately this is not the norm, but if
you are one of the lucky few then you can grab a cable and connect it.
You
can use VGA, component , DVI or HDMI to carry HD signals. Since digital
is generally preferred you should use either DVI or HDMI. If your HDTV
has a HDMI and since
no computers have HDMI yet you will need to use an
adapter from DVI to HDMI. Lucky for us, HDMI uses the same signaling technology as DVI.
Before
you plug in your DVI cable from your PC to your HDTV be sure to set the
resolution to one that is compatible with your HDTV. If your computer
monitor and your HDTV only share one common resolution, set it to that
until after you get a picture on the HDTV, then change it to the
desired resolution. When possible always try to use the displays native
resolution. For example my Sharp AQUOS's native resolution is 1280x768.
If the desired resolution isn't available from the display controls of your PC then you will need to add it. You can use a
great piece of software called
Powerstrip
to do this. Install it and then add the desired resolutions. To add a
custom From here you can add a preset or user defined resolution. If
your TV only accepts 1080i then use "1920x1080i 60hz". resolution to
PowerStrip go into display profiles, then "Advanced timing options",
then choose "Custom Resolutions". User defined resolutions are beyond
the scope of this guide. The best article I have ever read on how to do
this, is at the
AVSForum.
So check it out, but keep in mind that Powerstrip includes most of the
HD resolutions for you, so you don't have to copy and paste the timings
in yourself as described in the article. If you are a Mac user look for
DisplayConfigX. Linux users need to add the custom resolution to their xorg.conf, you can find help
here.
Unfortunately
for most of us, it isn't this easy. Most HDTVs only accept a few
resolutions and some only have component input. Since most PCs don't
have component output, it can be a bit more difficult. Your best bet is
to either buy a video card that supports component output like a
Radeon X600, or to buy a
VGA to component converter.
Since the convert costs as much as a good video card, it usually makes
sense to go with the new Video card. When shopping for a video card
keep in mind that sometimes the adapter doesn't come with the card,
even though the card supports it. My Radeon 9700 required me to buy an
additional $29.99 adapter to unlock the component functionality.
Luckily most of the newer Radeon cards now come with the cable. As
always when using a cutting edge video card be sure to use the latest
driver. But don't be scared to roll back a few versions if you have
problems. The latest Radeon drivers have HDTV resolutions built right
in, so there is no need for Powerstrip. You can still use it to tweak
your setup if you want, not to mention the other 100 things it is good
at. If you end up using the VGA to component adapter, then you will
need Powerstrip to setup the correct resolution. Don't be afraid to try
different resolutions to find the best one. I find that because all
HDTVs have overscan, non standard HDTV resolutions can help to
eliminate the overscan.
It is important to keep in mind that it is possible to break your TV by sending it the wrong resolution.
So make sure you understand what you are doing before you start to
experiment too much. I wouldn't use any resolutions that is not preset
without first reading the thread over at AVS.
Try it ..All the best
