Question about Kenmore 22422 Top Load Washer
I have a 7 or 8 year old sears washer model #22442100 that the belt has came of the shaft.i can't find another shaft that it goes to,only just 1.can i fina a diagram of this model so i can see how this belt goes and how to unbolt the shaft to take the belt off and put it back on. any info would be appreciated. thanks charlie.!!
  • 867 Answers
The shaft should not need to be removed, just pull in the spring loaded moter
Posted on Jun 15, 2009
12 year old kenmore elite topload washer - replaced the coupler - works fine except makes horrible noise in any spining cycle- seems to be a rubber belt or gasket around the tub drive area but can't see...
ok lets see if i can help you out,, first the model number ( on most models) is on the inside of the lid, or raise the lid and look on the rim of the washer under the lid,, if its not there it may be on the back of the unit,, or in some cases its gone, fell off , wore out, ect.. second,, if the motor coupler went out then it may be a issue with your trans,, ive seen alot of these where the trans starts to lock up, or the bearings on your shaft start to seize, break the coupler
Jan 19, 2011 | Kenmore Washing Machines
Sears gave me an estimate of $1439.65 to repair machine by replacing the following: 1 SUB TUB-OUTE - 213.82 1 GASKET - 12.16 1 SUB TUB-OUTE - 411.91 1 SUB BASKET - 492.69 1 BELT ...
Check your warranty. We just had that problem, with the exact same parts replaced, but the outer tub has a ten year warranty, and the basket a lifetime warranty. We just paid labor and for one belt. Our washer is also almost eight years old.
Oct 09, 2010 | Whirlpool GHW9100L Front Load Washer
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Washing Machine doesn't spin/drain.
Did he overload the unit
The belt may be moving but are the pulleys still locked to the shafts
Use a dab of white out, paint, colored marker and then watch the shafts to see if they are moving.
Could have broken a shaft key.
Feb 28, 2010 | Maytag Atlantis MAV6000 Top Load Washer
MY KENMORE WASHING MACHINE IS NOT SPINNING. THOUGHT IT WAS THE BELT AND CALLED THE REPAIRMAN AND HE SAYS THAT IT DOESN'T HAVE A BELT ON IT. DOES ANYONE KNOW IF MODEL #110.91110100 HAS A BELT?
Hello, Yes, the repair tech is correct. This model washer does NOT have a drive belt. It uses a gearbox driven directly by the electric motor. It is likely that the gearbox has a stripped gear or a broken drive wheel.
I've attached a link to the Sears parts web site so you can look at all the line drawings and parts diagrams for your washer model. You can click on each link to see the various components and also get a replacement parts list, which shows the prices (if you buy them thru Sear's site) to give you a better idea of the anticipated cost to replace the gearbox, etc.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.91110100&=part+number
Just click on the link titled, "BRAKE, CLUTCH, GEARCASE, MOTOR AND PUMP " to get a good look at the parts that make the washer agitate and spin.
You might want to take a closer look to see if it a gearbox issue or maybe a motor drive shaft problem where the keyway has sheared off and is causing the washer not to spin. If, however, the washer agitates during the wash cycle, the problem is NOT a stripped keyway on the motor shaft, but rather is within the gearbox and you'll have to either repair or replace the gearbox to get the washer working properly again.
The decision to undertake the repairs or purchase a new washer is yours to make, but I can offer the following to help you decide. If the parts (and labor costs, if you don't do the repair yourself) exceeds 60% of the cost of a new, comparable machine AND the machine is over 8-10 years old, AND you've got rust starting to appear inside the wash tub, etc. you might wish to seriously consider replacing your washer with a new one. Otherwise, go ahead and make the repairs and keep it working for (hopefully) many more years to come.
I hope you find this Very Helpful and best regards!
Nov 11, 2009 | Kenmore Washing Machines
I have a 21 year old Kenmore washing maching (model 82873800). It is leaking when it is filling up. The water is not coming from the hoses or the center shaft. When I lean the washer over, I can reach...
I'd go to the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.82873800%29
and check the sub-components lists for a gasket or part under the tub that keeps the water from leaking.
With a 21 year old washer, it's likely that one of the rubber or plastic gaskets has finally worn.
Sep 20, 2009 | Kenmore Washing Machines
Belt replacement on kenmore washer
One of the transmission bolts has to be removed to be able to remove the 1" spacer . You also have to turn the pulley which moves the wig-wag to move the glide foreward to drop the shaft of the drive. Very difficult unless you've done it before .
Jul 07, 2009 | Kenmore 24032\24036 Top Load Washer
I have a front load washer model #44832. We had a
FREE??
The unit is not under warranty.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 05, 2009 | Kenmore Washing Machines
Terrible noise on spin cycle, stainless drum is loose inside plastic tub, wore the front half of the plastic tub down due to friction. Took washer completely apart, found the spider arms cracked. It...
Just had the same problem 1 month ago. My Whirlpool Duet front load made that terrible noise. 2 of the 3 spider arms were cracked. I hade a new hole tub with the spider arm and the shaft , because it is 10 years limited waranty . But if it is not under waranty it costs about 270$ for that tub you can buy it from many appliance parts web sites on the net. Good luck, huge job to all remove that thing
Dec 03, 2008 | Washing Machines
Frontloader pumps water out but won't spin
You need to replace your drive coupler. You can get the drive coupler at sears online or your local parts store. After you get the part go to sears online, Put in your model number and it will bring up a diagram to show you exactly where it is. The drive coupler goes between the motor and the transmission, It makes it spin and agitate.
Nov 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 22422 Top Load Washer Logo
75 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
