Question about Husqvarna Viking 1
Problems with lower thread tension
I have an older Husqvarna Viking 990 sewing machine. The last time I was using it, I struck a safety pin that was underneath the project that I had fogotten to take out. The sewing machine needle was bent. I replaced the needle and now the tension is off. No matter what I try, the thread bunches up on the bottom of what I'm sewing. I've tried several new needles, cleaned out the bobbin case, taken the needle plate off and cleaned in there, used several different types of thread, new bobbins, etc. I don't think the timing is off because when I manually turn the wheel, I can see the upper thread take up the lower thread. Can you help??
    New Friend:
  • 26 Answers
Try setting the bobbin tension correctly. This is important as it affects everything else:
https://www.youtube.com/watch?v=W4ErwP6LNcI
The try sewing and see if the stitches lock properly. Adjust the top tension as needed.
Posted on Feb 25, 2015
    Problem Solver:
  • 6 Answers
Did you bend the throat plate? I have done that and it was a nightmare. I took it off and gently hit it from the backside with a towel over it to bend it back the way it was. It worked fine.
Posted on Jun 18, 2009
How do I turn off thread portioning on Husqvarna Ruby De Luxe. I don't want to adjust the settings but need to turn this off. Thank you
FWIW, I was unable to find any information for turning off the thread portioning function. Unfortunately, this appears to be the thread tensioning system, so disabling the thread portioning would be disabling the thread tensioning--something that is critical to sewing. It appears this model may have some issues and perhaps this one is particular to your machine. It may be best to take it for service.
Perhaps this will help:
Husqvarna Viking Designer Ruby 25 Tension Thread Portioning Deluxe Stitch...
Husqvarna Viking Designer Ruby 22 Bobbin Thread Sensor
Husqvarna Viking Designer Ruby Review Sewing Insight
Jul 01, 2016 | Husqvarna Sewing Machines
My viking emerald 118 machine just started breaking needles and the bobbin thread will not hold. YOu can pull the bobbin stitch out by pulling the thread.
Check the upper tension by lowering the presser foot and pulling on the thread through the needle. You should feel resistance. If not, take a stiff brush and clean out the tension disks/dials removing any loose threads or lint. If upper tension is ok, check bobbin tension by pulling thread through needle plate opening. You should feel resistance. If not, remove bobbin case and brush any loose threads or lint from the case, especially in the tension spring where the thread is snapped into place. You may need to use a sharp needle to dig in between the spring but be careful that you don't damage it.
Jun 17, 2014 | Husqvarna Viking Emerald 116 Sewing...
Husqvarna viking sewing machine..bobbin thread comes loose out of the groove. . How do I fix this?
There is nothing one can do about the lower thread. However, you can loosen the top thread to match tension of the lower one. From the tensioner nut you can do it.
Oct 10, 2010 | Husqvarna Sewing Machines
How do I adjust the lower (bobin) tension on a Viking 190
I do not recomend that you try to adjust the bottom tension at all, that will cause you alot of problems usually. If your having trouble with the stitches, have you tried an new needle, re-thread and make sure that the thread is seated in both thop and bottom tensions
Aug 20, 2010 | Husqvarna Viking 1
Unbalanced lower looper thread wraps aaround the
Loosen the upper tension looper thread by turning the dial to a lower number. The upper tension looper is to tight and pulling the lower looper thread up. Also might want to loosen or tighten the left or right needle tensions depending on the results you get. It will be a trial and error exercise to get the correct adjustment between the loopers and needle thread tensions. Otherwise, you might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Oct 02, 2009 | Husqvarna Huskylock Computerized 910
My 5 year old Huskystar 216 sewing machine is
Sounds like the hook/needle timing. To check do the following:
With the power off!!
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding in the right direction.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to get a good stitch, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 26, 2009 | Husqvarna Sewing Machines
Thread ball up
Check your bobbin area. Make sure you have put the bobbin in the case with the H logo up and the thread pulls off the spool in a counter clockwise motion. Make sure the bobbin is sitting in the case and threaded through the "catch" on the bobbin case. Then leave a long piece of thread from the bottom, holding the end of the top thread, lower the needle for one revolution using the handwheel. Does the top thread catch the bobbin thread and pull it to the top? This is done without fabric. Your checking to determine if the top thread catches the bobbin thread and pulls it to the top. IIf it does not, it is most likely hook/needle timing. f it does, gently pull on the bobbin thread and determine if it pulls through with a little resistence (checking bobbin tension). Make sure you are using correct needle -- Schmitz or Inspira needles are recommended (Universal size 80 is standard). Make sure you are using Husqvarna Viking made for your machine -- original ones were green but there are some new colored ones but all have the Husqvarna logo on them. Otherwise take it to an authorized Husqvarna Viking dealer. You can find your closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck
Sep 24, 2009 | Husqvarna Designer I
As Iam quilting with my macine the top stitches are ok, but back of quilt the thread is all boggled up-Tension ??
yes, this is a tension issue. Check your bobbin area. Make sure you have put the bobbin in the case with the H logo up and the thread pulls off the spool in a counter clockwise motion. Make sure the bobbin is sitting in the case and threaded through the "catch" on the bobbin case. Then leave a long piece of thread from the bottom, holding the end of the top thread, lower the needle for one revolution using the handwheel. Does the top thread catch the bobbin thread and pull it to the top? This is done without fabric. Your checking to determine if the top thread catches the bobbin thread and pulls it to the top. IIf it does not, it is most likely hook/needle timing. f it does, gently pull on the bobbin thread and determine if it pulls through with a little resistence (checking bobbin tension). Make sure you are using correct needle -- Schmitz or Inspira needles are recommended (Universal size 80 is standard). Make sure you are using Husqvarna Viking made for your machine -- original ones were green but there are some new colored ones but all have the Husqvarna logo on them. Otherwise take it to an authorized Husqvarna Viking dealer. You can find your closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck
Sep 23, 2009 | Husqvarna Viking 1
Sewing Machines Logo
321 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
