Question about American Standard Home
American Standard Champion toilet keeps running
The float on the flush valve sticks. What can I do, short of replacing the entire flush valve?
    President:
  • 3,433 Answers
Readjust the float. the longer it is the more leverage the fill water will have on it. good luck. The fill valve does come apart and cleaned if there is debri in it. Turn the water off first:)
Posted on Jun 20, 2009
American Standard Carlyle Series toilet is refilling about 10 percent of the water in the tank every 20 minutes. Do I need to replace the flapper or the entire flush valve?
Start with the flapper. They tend to dry up especially with water that contains chlorine. Purchase the American Standard flapper if available for that toilet. Works better than generics.
Sep 20, 2013 | American Standard 2004.014 - Champion...
When I flush thenwater fills to the fill line and slowly keeps on dripping over the top of the flush valve tube.
I would ckeck to see where water fill line is inside toilet tank and then adjust flush valve to try to get it to shut off at this point. Not knowing whether your toilet still has original flush valve it is hard to tell you how to fix it. If it has float mounted on rod to flush valve there is usually a set screw on the top of the flush valve in the center. Turn this screw clockwise to make valve shut off sooner. Try to set it so that water shuts off when it is at fill mark. If float is mounted on brass float rod you can support rod closest to flush valve with left hand and carefully bend rod down a little with your right. This will cause flush valve to shut off sooner. If the seat is worn to badly in flush valve you will need to replace it.
Nov 18, 2010 | American Standard 2004.014.178 Champion 4...
Problem: water tank running water and refilling itself
probably the flapper valve is not seating correctly over the outlet. you can fix it by reaching in and twisting the valve one way or the other till it seats properly and the leak will stop.
May 08, 2010 | American Standard 2004.014 - Champion...
Toilets are refilling between flushes
Replace the flappers, and clean around the flapper seat.
Make sure the water level is 1/2 " below the large vertical tube by either bending the float rod down or adjust the skinny silver rod on a Fluidmaster unit.
Dec 12, 2009 | American Standard 2002.014 - Champion4...
Toilet keeps flushing
you need to replace the flapper, it's allowing water to seep thru
Jul 09, 2009 | American Standard 2002.014 - Champion4...
What is square box (float) attached to flush valve inside tank
The foam block does a few things: It helps with noise level, helps prevent condensation and also takes up space in the tank to lessen water usage with each flush.
Keep an eye on the outside of the tank and if you don't ever notice any moisture on the outside of the tank then I wouldn't worry about it all!!
Mar 24, 2009 | American Standard 2004.014 - Champion...
American standard toilet
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Nov 09, 2008 | American Standard 2002.014 - Champion4...
Home Logo
2,299 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
