Question about Oregon Scientific Complete Carburetor for Stihl 4122 Brush Cutter and 4226HS Hedge Trimmer
Cuts out on acceleration
Stihl hs80 hedgecutter. starts ticks-over splutters badly on acceleration
new carb kit, fuel pipes. clean filter.apparently no spark arrestor on this
model
  • 1 more comment
  • anthonybusse Jun 17, 2009
    panilling9
    borrowed working carburettor---my machine ran perfectly. The
    cutting out on acceleration problem is definitely a carb issue
    panilling9
  • panilling9
    panilling9 May 11, 2010
    try another spark plug stihl likes theirs set at .020 see what happens
  • 26 Answers
If you have over 200 hours on this FS 80 then you may need a valve adjustment(yes this 2-stroke has valves). if you wanna try to do it yourself it should be set @ 0.1mm @TopDeadCenter. my advice is take it to any stihl dealer and let them do it. its scheduled maintenance
Posted on Feb 27, 2010
Stilt fs85 cannot start, what may be the cause of it?
First check your muffler's spark arrestor to see if it is clogged.
If not clogged try adding a little fuel mix introduced into the carburetor throat. If starts then you have carb problems.
If it don't start then you may either a compression problem or ignition problem.
Dec 26, 2014 | Stihl Fs80 Fs85 Fc85 Hs80 Ing Coil Assy...
Stihl chainsaw problems
Your dealer is right. Gas is not a carbs best friend. every time you fuel dirt gets in the fuel tank from the air. This eventually blocks air and fuel passages and check valves inside the carb. That is the reason. Carbs wear out like anything else. Check the price of a carb compared to a kit. Some Stihl carbs are reasonable.
Jul 21, 2014 | Stihl Garden
Stihl TS400 stone cutter not working (no compression) so replaced piston rings, new gasket kit and clean for carb new spark plug (good spark when engin turned over) cleaned all air filters, replaced all...
You did not indicate whether or not you have compression now that you have changed out the gaskets and piston rings. If not, it seems to me that the problem could be a) cracked head or block, b) bad valve(s) or even c) a warped head.
Sorry for the bad news (if I am right).
Apr 23, 2014 | Stihl Ts400 Cut Off Saw Carb Carburetor...
I can't get my blower to accelerate. It will only idol on full choke. If you pull trigger it bogs down. I replaced the fuel line and sprayed carb out.
Check the following, and then clean or replace:
  • Fuel Filter - Located INSIDE the Fuel Tank
  • Spark Plug
  • Spark Arrestor - at muffler
  • Carburetor - May need a rebuild kit
Watch this as well...
and...
Oct 18, 2013 | Stihl Bg 55
Stihl weedeater
I'd put my money on it being the actual carb body. The carb body its self contains a couple of small valves which can get blocked or damaged and are practically impossible to replace. Look for a second hand OEM carb and if needed use your rebuild kit on it. That would be the cheapest route
Jun 02, 2013 | Garden
Blower bogs down and kills at full throttle
Check the following, then clean or replace:
  • Fuel Filter - Located IN the fuel tank
  • Spark Plug
  • Spark Arrestor - at muffler port, creates resistance of exhaust flow, engine then bogs
  • Carburetor - may need a rebuild kit
Then watch this...
and...
Mar 31, 2013 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
Ryobi weed eater stalls when giving it gas
check air filter and spark plug if good carb adjustment is needed or carb may be loose. could be bad fuel water in gas will cause this
Aug 26, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Her chee fun 50 scooter. when trying to accelerate the engine "dies". have had a new ecu and magneto fitted, carb stripped and cleaned, fuel tank drained and cleaned then filled with fresh fuel. when the...
Assuming everything is back toether properly and was not the problem the frst place, remove the exhaust pipe to expose the exhaust ports to ensure they are not carbon block. Also check the exhaust it self for a spark arrestor screen that could hve been carbon fouled and clogged. Cannot free flow because of the problems noted above, you will not be able to run a two-stroke engine reliably.
Sep 29, 2010 | Poulan 2-Stroke Engine Oil - 24 Pack
Running bad with oil leaking out the muffler crimps. Too much oil in the mix? Cleaned the air filters already and checked the spark plug. Looks good, maybe the carb?
Check the spark arrestor screen and see if the screen has carbon deposits on it. If it does then you need to clean the spark arrestor screen and re install it in the muffler. You can clean it by burning off the carbon. The air filters on the TS 700 Cut Off Saw do not need to be cleaned, they only need to be replaced when the unit starts running poorly. The carburetor could have something in it that is keeping the needle from closing and flooding out the unit. I would suggest taking this unit to a Stihl dealer that has a Gold Certified Technician. You can use the dealer locator on the the Stihl USA website. I have included a link HERE. You can type in your zip code and it will tell you where the closest dealer is and what level of technician they have.
May 14, 2010 | Stihl Ts 700 Cut Off Saw Model Name Plate...
Oregon Scientific Complete Carburetor for Stihl 4122 Brush Cutter and 4226HS Hedge Trimmer Logo
1,709 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
