Question about Dryers
Dryer will not rotate, timer engages, belt is fine, and motor will rotate
  • Dryers Master
  • 8,220 Answers
You probably have a bad glide or roller. Check this out GUIDE: how do I get into my dryer?
Posted on Jun 15, 2009
Dryer timer wont rotate dries just fine
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 21, 2011 | Dryers
Dryer has electricity but the drum will not spin
Hello there:
If your dryer doesn't tumble, check these:
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Sep 27, 2010 | Whirlpool LER4634J Electric Dryer
My dryer won't start. it will heat and timer
Check your motor to see if it is faulty.
Good Luck.
Rate me please
May 12, 2010 | Dryers
The dryer does not turn, but will turn by hand, how do you unlock heller cd55 dryer?
It won't tumble If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dec 31, 2009 | Dryers
I have a Kenmore 80 series and the motor is not running but the heating coil comes on, what can be the problem? I have traced all wires and they appear to be OK
You could have a faulty motor, or possibly a faulty timer switch.
Try this:
Unplug the dryer, reach inside and try to rotate the drum 1/4-1/2 turn.
Plug the dryer back in and push the start button and see if it starts to rotate.
Sometimes motors get dead zones in them and this will help rotate the motor out of the dead zone.
If this does not solve the problem then the thing I would check is the motor.
Again unplug your dryer from the electric. Remove the box on top of the dryer that contains the timer switch, start switch, etc.
Be real careful not to knock any wires loose off of the timer switch.
Remove the top of the dryer, then remove the front of the dryer to expose the drum and belt, remove the drum and belt to expose the idler arm with pulley and motor. Now is a good time to check the condition of the belt and the drum rollers also. I will suggest that you oil the drum rollers at the shaft with a good grade of machine oil such as 3 in One oil. This will save a problem of a squeaky roller in the future. If the drum rollers have flat spots on them they will have to be replaced.
Then check your motor.
Note: Make sure you note how the belt route is, this will come in handy when you go to put everything back together.
If the motor checks out ok, then I would think it is the timer switch, you will have to replace the timer switch as they are not repairable.
I will include a couple of websites that have parts and live chat assistance:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Good Luck,
I hope this helps.
Oct 19, 2009 | Kenmore Dryers
Kenmore Dryer (Model #11073952101) starts, but WON'T stay ON
your motor maybe going out. theres a switch on the motor that starts it . on most models the start switch is built into the motor. however some models the switch can be replaced by itself.
Aug 30, 2009 | Kenmore 73952 Gas Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Dryer wont spin
If dryer does not spin it is usually a problem with the belt or the motor. Check also door switch.
See also following indications from Repairclinic:
Belt
Motor
Door switch
Click here for a belt installation diagram.
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
Aug 27, 2008 | Dryers
Kenmore electric dryer
Belt
Motor
Door switch
  • Remove the belt.
My dryer will not start. It is not locked. I've turned it off and unplugged it for 30 minutes. All the buttons work fine, but the timer just flashes when I push the start button. Help!
Belt
Motor
Door switch
  • Remove the belt.
Aug 27, 2008 | Whirlpool Dryers
Dryers Logo
47 people viewed this question
Top Dryers Experts
