Has no electrical power and transmission will not shift into neutral or park
My guess is the trans won't shift because of no power. There is a safety switch that is activated by the brake lights...no power means no lights and no lights means no shifting. Solve the power issue and you should have the trans working again.
For power it's time to get a probe and start at square 1. Battery? Have you tested it? Cables solid and CLEAN? These get overlooked a lot. Electrical is a hard one to solve over the net. But they are not hard to solve...just can be time consuming.
?ā¬Ā¢
The ignition switch is turned to the RUN or the START position.
When the ignition switch is in the RUN or the START position, the current flows from the B/U Lamp fuse located in the underhood bussed electrical center (UBEC) through CKT 839 (PNK) to the park/neutral position switch. The park/neutral position switch also feeds the backup lamps portion of the switch. With the transmission in the PARK position, the current flows to the BTSI fuse located in the underhood bussed electrical center (UBEC) through CKT 275 (LT GRN). The current then flows to the TCC/stoplamp switch through CKT 584 (LT GRN/BLK). The current continues to the BTSI solenoid through CKT 1135 (DK GRN/WHT). The ground path is provided through CKT 1850 (BLK) to G207. When the brake pedal is depressed, the normally closed contacts in the TCC/stoplamp switch open and the current flow is interrupted. When the current flow is interrupted, the BTSI solenoid de-energizes. The transmission may then shift to another gear. When the transmission shifts to another gear (except PARK), the contacts in the park/neutral position switch open. This condition stops the current flow to energize the solenoid when the brake pedal releases.
Whic
?ā¬Ā¢
The automatic transmission shift lock control switch.
?ā¬Ā¢
The park/neutral safety switch.
With the ignition in the ON position, battery positive voltage is supplied to the automatic transmission shift lock control switch. The circuit continues through the normally-closed switch to the automatic transmission shift lock control solenoid. The park/neutral safety switch provides a path to ground for the automatic transmission shift lock control solenoid in the PARK position. This energizes the automatic transmission shift lock control solenoid, mechanically locking the shift linkage in the PARK position. When the driver presses the brake pedal the contacts in the automatic transmission shift lock control switch open, causing the automatic transmission shift lock control solenoid to de-energize. This allows the shift lever to move from the PARK position. When the shift lever is out of the PARK position the contacts in the neutral safety switch open and the automatic transmission shift lock control solenoid is de-energized.
