Question about JVC Televison & Video
Can't get old jVC tv to select Ch 3
Have universal remote programmed to scanned stations. Remote won't select menu. Can't get TV to select or register CH 3 even manually. There are controls on the front of the TV (model C-1455US) for presetting and selecting channels but I can't figure out how to make them work. I can't work my converter box and thus no TV at all without the CH 3 option. Please help.
  • 99 Answers
SOURCE: panasonic tv channel reset
Unplug your tv for 24 hours and replug. This should set your tv back to ch 3
good luck----------------tomtaso
Posted on Nov 27, 2007
SOURCE: AV input selection without a remote
I had the same problem. I hooked up the DVD player and then got into the set up. I used the add/erase feature to go through all of the channels. At channel 91, I saw the logo for the dvd player. I added that channel and now the dvd player works.
Posted on Mar 13, 2009
SOURCE: Can't get CH. 3 or 4 on older Magnavox TV to hook in convert. box
HAVE YOU TRIED GOING BACK TO YOUR MENU AND SELECTING AUTO CHANNEL SEARCH LIKE YOU DO WHEN YOU PROGRAM YOUR TV FOR THE FIRST TIME TO GET THE CHANNELS IN YOUR SERVICE AREA? IT SHOULD PULL IN CHANNELS 3 & 4 (PARDON THE CAPS)
Posted on May 10, 2009
  • 1348 Answers
SOURCE: Programming a channel without the remote
autoprogram,or use channel 3 from the vcr.,and run the dvd into the vcr which can be set on channel 4 on the back on alot of them
Posted on Aug 22, 2009
  • 197 Answers
SOURCE: can not programe old portable tv have universal remote
http://www.fixya.com/support/p221852-philips_pr0930x_9_in_portable/manual-10032/page-5
I can't take credit for this it was already on this site!
Posted on Sep 22, 2009
How can i scan supersonic tv without a remote
Many universal remotes have a code database that you can use to access at least the basic tv functions. I'm assuming you are asking how to program a universal remote when you do not have the original remote. If you are asking how to program stations via buttons on the TV, there is probably a menu button to get in the main menu, then use the channel up/down and volume up/down buttons to navigate the menu.
Dec 16, 2017 | Supersonic Televison & Video
I have a toshiba tv 39al900a which was won in a raffle. When you turn it on it says please scan channels.t.
The first step is to make sure you have good batteries in the remote. The ones included tends to be cheap and you have no idea how old they are.
Here is the manual, page 12 explains how to use the remote and the next few pages cover the initial setup and scanning of channels.
http://www.mytoshiba.com.au/file/download/resource/file/23089/39al900a%20owner's%20manual.pdf
If the remote is still not working, get a universal remote to replace it. This link gets you the codes to program the universal to work with your TV. http://codesforuniversalremotes.com/universal-remote-control-codes-toshiba-tvs/
Feb 05, 2017 | Toshiba Televison & Video
How do I switch from catv to antenna on model mwc13d6
First make sure that the TV/DVD player is on TV by pressing the Channel Up. (The channel up/down will rotate through AUX and any programmed channels.) You'll need the original remote or an universal remote that matches the Set-up function. Then press Set-up on the remote; it's to the left of Mute above Play.
Use the Up/Down arrows to navigate to Channel Setup. Press Enter to access the Channel Setup menu. Use the Up and Down arrows to select Auto Ch Programming and press Enter. Wait for the TV to scan all available channels. Afterwards, you can go back to the Channel Setup menu and choose Add/Delete channels. Press Set-Up again to exit the On-screen menu system.
Unless you have a set-top Digital-to-Analog converter attached to the TV, you will only get one of the few remaining low power analog stations, if you are close to the transmitter. This set only has an NTSC tuner. Most set-top boxes can be attached to the Antenna input and be set to Channel 3 or 4 or connected to the Aux input.
The Magnavox MWC13D6 was manufactured by Funai and the manual is available here: http://www.funai-corp.com/support/manuals.aspx . The direct link to the manual is MWC13D6 is http://www.funai-corp.com/support/om/MWC13D6.pdf .
I hope this helps.
Mar 24, 2015 | Televison & Video
I have a TruFlat RCA model # 27F520T have lost original remote and FPA lock is on how do I unlock without original remote? Dish universal remote not working to unlock tv, it will pull up menu but cannot...
Try this -
  1. Press menu for main menu.
  2. Press CH + or CH - to highlight preferences.
  3. Press "OK" to enter preferences submenu.
  4. Press CH + or CH - to high light "FPA"
  5. Press VOL + or VOL - to turn the FPA on or off.
  6. Press MENU repeatedly to exit.
  7. Back to normal
  • FPA stands for Front Panel Lock. It makes it so kids don't push all the buttons on the front of your TV. The power button on the TV will still work and the remote will still function as normal.
Regards, Tony
Apr 30, 2011 | RCA TruFlat 27F520T 27" TV
I do not know how to do a channel scan, can you help me please? I seriously thought that I could find anything online but I have not been able to find how to channel scan this tv.
What brand/model TV do you have? If the TV has several input options, make sure that the TV is set to the TV mode. (Use the Input or Source button on the remote, some TVs have this on the TV as well but not always)
Some can only do a channel scan with the original remote. My old Emerson CRT (~20 years old) launched a channel scan when I pressed the Add and Delete Channel buttons together on the remote. Fortunately even when most of the buttons failed on that remote, the channel scan still launched.
Other TVs from that time frame have an channel scan button in the control panel. Often these are hidden behind a panel to avoid accidental resets.
More modern TVs usually have the scan as part of the menu. Depending on the TV, press Menu on the remote (or if available on the TV (sometimes can be done by pressing Ch+/Ch- together)). Then look for a Setup option or a TV icon. If you have a Setup menu, you will then need to go to the TV submenu. Then find the option for setting the input signal (TV/cable) and then you should be able to launch a channel scan. (Usually the Ch+/Ch- (up/down) and Vol+/Vol- (left/right) buttons will navigate through the menus.)
Unfortunately, without the make and model, I can't give you any more help. Please write back with your brand of TV and I'll check if I have the manual in my stack.
(low end universal remotes do not always include the menu or source button. If your TV doesn't have them, you may need a different remote. The ones that can be programmed via a USB connection are the easiest to set up.)
Apr 29, 2011 | Televison & Video
NEED TO PROGRAM MY RCA TV WITH A HUGHES HRMC-13 REMOTE
Hello
Codes for RCA tv with Hughes remote are:
160 161 156 165 065 070 004 023 024
056 074 081 152 167 145
Code Entry
Use the REMOTE pane under the System Setup menu tab to program your
HRMC-11, HRMC-12, or HRMC-13 remote control to operate your TV, VCR,
SAT, AUX device, or DVD (HRMC-11 and HRMC-12 only). The AUX menu
button can be used to control a CATV box or other type of device. Use the menu
buttons to choose the desired type of device and display a brand name menu list
from which you can select the manufacturer of your device.
Code scanning
To use the Code Scanning method:
1. Repeatedly tap the top part of the CHANNEL (CH) button.
2. Continue to step through the codes until the component turns off, indicating
you have found the correct component code. If you accidentally pass a code
that responds or realize you may not have been aiming the remote control at
the component, tap the lower part of the CHANNEL (CH) button to step
backward through the codes.
3. Press the remote control POWER button to verify the proper code by
turning the device on and off.
4. Press the device button (in this example, TV) again to lock in the code.
OK
Feb 20, 2011 | Televison & Video
I do not have the manual for my JVC TV. Having problems setting the proper channel number to get my Directv stations
Use a generic universal remote. Program the remote to your JVC tv. Use the newly programmed remote to put your JVC tv on channel 3 (or 4) or the appropriate channel for Direct TV.
Aug 13, 2009 | Televison & Video
Magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Jun 14, 2008 | Philips Magnavox 27MS343S 27" TV
Need updated codes for RCA RCR860 remote control
I have a Phillips TV and need the code for that. I have the manual but it only lists RCA, Sony, JVC, Panasonic, Toshiba, and Sharp.
Jan 22, 2008 | Motorola Mobility DRC800 Universal Remote...
Televison & Video Logo
74 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
