Question about Ricoh Aficio 1035 Copier
Service code sc546 what do we need to do to fix this problem?
  • Ricoh Expert
  • 1,326 Answers
Try to go into service mode to reset the code...
Clear yellow botton
7
then press and hold the red stop botton till the display changes and then turn the main Power switch Off then back ON... You do not have to do any thing in service mode, just get to that display.... Don't change anything unless you know what you are doing. sc546 has to do with the fixing unit. You may be able to reset it.
Posted on Jun 16, 2009
  • mehdi
    mehdi Aug 10, 2014
    thanks a lot, it work's
    New Friend:
THERMAL FUSE LOCATION
Posted on Feb 24, 2013
    Scholar:
  • 175 Answers
In addition to what cogz said, sc546 is a common code on those machines. Alot of times you can clear the code and you'll be set. Sometimes you have to replace thermistors or thermal fuses to correct problem.
Posted on Jun 28, 2009
2 Suggested Answers
  • 42 Answers
SOURCE: help with code sc546
need model.but in most it's a fuser prob.
Posted on Jul 05, 2008
What is the code SC546 mean?
search error code . Brother MFC-8860DN Printer
Jul 10, 2014 | Brother MFC-8860DN Printer
How do I clear error sc546 on a Ricoh Aficio 2035
replace thermostat in heating section or u yuor tirmistor is directly touching the heat roller
Feb 13, 2012 | Ricoh Aficio 2022 Black and White Copier
Service code SC546 on Model 5627
SC546 is universal in Ricoh, Lanier and Savin. It is indicating that the machine does not see the fuser.
Apr 26, 2011 | Lanier UNKNOWN
I have Gestetner DSM622 SP, Iam getting Errer code SC546, can someone explain me thanks
sc546 is a fuser temperature detect error. One or both of the thermistors most likely need to be cleaned or replaced, but you will have to go into service mode to reset the code once you do that. You should contact your local service technician or Gestetner dealer, as they can easily fix that problem.
May 13, 2010 | Gestetner DSm622sp Digital Imaging System
Lanier copier ld145 locked up, code is sc546
Fuser warm up problem. Cause needs to be fixed and then code can be reset in service mode by a tech.
Jul 29, 2009 | Lanier Office Equipment & Supplies
SC546
SC541 - SC-555
These codes mean you are having a problem with your fusing unit. The section of your copy machine that has to heat up before you can make copies. It runs at a pretty high temp because it has to melt the toner and press it into the paper as the copy moves through the machine. Depending on the code, your machine is either taking too long to warm up or it is overheating.
The most common reason is a build up of hard crusty toner on the temperature sensors. This tricks the machine into not seeing your fuser warm up fast enough. Most of the time you can reset this and continue to use the machine but expect the code to come back down the road. You can also get codes if the room the copy machine is in is too cold when you start up the machine. Either a cold winter day or even a summer day in a room too cold from air conditioning.
Some machines require you to enter a service code to reset a fuser/fixing unit error. Some only require you to enter the service mode, then turn the machine off / on using the main power switch. The main power switch is the one you have to rock to the off and rock back on, not the little button you press for power to come on.
To enter the service mode press the following keys in order:
Clear modes
7
then press and hold the stop key
You will see the display screen change. At this point turn the machine off / on to reset the code.
If your machine does not have an LCD display screen you should have seen the copy quantity
display change to a flashing zero.
Some machines will need to add a step to the above instructions.
Once the LCD screen changes, select the "SP Mode" selection from the touch screen.
Enter 5810
This is the Service Program (SP) that resets Service Codes (SC-###)
You will either have to select 1 to accept or select the touch screen button to activate this SP.
After you do, turn the main power off / on to reset the code.
If you try this and the code still comes back on, you have an electrical or mechanical problem that you will need to call a service company to repair. The reason for making this code so hard to reset is a safety issue. If there is a short in your fuser unit it can cause your machine to over heat and possibly cause a fire. There are thermistors (temperature sensors) and thermostats (temperature fuses) that will keep your fuser from overheating. If either of these devices are worn out, you will not be able to reset the code and will need to have your fuser serviced.
Jun 19, 2009 | Office Equipment & Supplies
I have a machine it has a code SC546 and dont letme do anything please help me. thank you
fuser warm up error. Code can only be reset in service mode after the problem is fixed.
Jun 05, 2009 | Ricoh Aficio 1035 Copier
Help with code sc546
Jul 05, 2008 | Gestetner DSm645 Digital Imaging System
Service code SC546 on a Ricoh Aficio 1045
Clear yellow botton
7
Jun 03, 2008 | Computers & Internet
Ricoh Aficio 1035 Copier Logo
1,702 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
