Treadmill won't run. Message on Screen says Safety Key Lock. Inserting the Safety Key doesn't remove the message.
When in Demo Mode, the console will go through a repeating lighting pattern. This
mode will only become active when the treadmill is plugged in, the main on/off switch
is turned on, and the safety key is not inserted into the console.
The Demo Mode was added to attract attention to the treadmill while it is on display. By
default, all treadmills with Demo Mode will come with it turned on. Demo Mode can be
turned off at any time.
Method #1 to switch from the Demo Mode:Press and hold the STOP button while inserting the safety key to enter the user
information mode.
Look in the Calories window. When Demo Mode is active, the letter 'd' will
appear.
Press the SPEED DOWN button to toggle the mode on and off.
Once the mode is set as desired, remove the safety key.
The problem was resolved after calling Nautilus directly. It turns out that there is a safety button underneath the treadmill that is there to prevent the treadmill from motor and belt from running when in folded position. Although i don't fold the treadmill, the button must have been hit when I placed my power cord near it not knowing about the button. Simply folding and unfolding the treadmill then pressing the button solved the problem. I am posting this comment in case anyone else encounters this issue.
