The barrel end of the ac power cord is ruined.What kind do I need
The barrel end of the ac power supply that plugs into the power port on my ibook G4 is ruined. I don't know what type I need. It has about a 1/4'' metal circle that surrounds the black plug that the metal prong in the power port on the ibook goes in to.
  • 57 Answers
You need to buy a new power supply from a mac distributor. Try this website:
http://www.ifixit.com/Products/G4-14-Inch-iBook/AC-Adapters/13/84
Posted on Jun 16, 2009
How to do a factory reset on ibook M6497
Warning: Resetting the Power Manager on any PowerBook or iBook will permanently remove a RAM disk, if present, and all of its contents.
  1. If the computer is on, turn it off.
  2. Disconnect the AC power adapter.
  3. Remove the battery.
  4. Press and release the reset button (shown here) located above the Audio/Video port on the left side of the iBook (Dual USB) computer by inserting the end of a paper clip into the small hole and gently pressing the switch once.
  5. Wait 5 seconds.
  6. Reconnect the AC power adapter.
  7. Put the battery back in the computer.
  8. Press the Power button to restart the iBook computer.
Jan 16, 2014 | Apple PowerBook G4 Mac Notebook
My ibook g4 won't power up but the power cord works,do i need a new battery?
I found this page at apple support about your problem, it seems to have helped a lot for many people. Apple Support
Mar 28, 2012 | Apple iBook 12 iBook G4 1.33GHz,...
I push the power and nothing happens on my ibook g4 14-inch
If you are not using the AC adapter (you are using only the battery), then the battery may be dead - simply replace the battery. If you are plugged into the wall, and the light on the power cord, where it meets the computer, is green, the unit is receiving power. If the unit is receiving power and it will not boot at all, then either the motherboard or the hard drive is most likely problem. You can replace the board, but it may end up being more expensive on an older G4 than it is worth. Once you are able to determine if the unit is receiving power, the only thing you can really do from there is take it to a repair shop and have them perform a test on the power supply, hard drive and/or the motherboard to see which one of those is causing the problem. If the hard drive is fine, you will most likely be able to recover your files.
Dec 26, 2010 | Apple iBook G4 Mac Notebook
My apple ibook g4 won.t turn on
cheak:
The power from AC
The power from Battery
Have you recently pulled apart your powerbook?
Dec 19, 2010 | Apple iBook G4 Mac Notebook
My iBook G4 will not turn on though it has a full battery & is connected to a plug socket also..
There are several models of iBook G4. The following sequence applies to the "14-inch Early 2004."
Remove all peripheral cables. Remove the battery. Reset the power manager by pressing the key combination Control-Option-Shift-
power. Then plug the iBook into AC power and attempt to start it with the power key.
If this procedure does not being it back, invasive diagnostics are required, in which case you should being it to an Apple-Certified tech for repair.
Jan 21, 2010 | Apple iBook G4 Mac Notebook
My powerbok g4 got the metal tip of the AC power cord jack broken inside of the DC port of the laptop. This caused some sparks to come out of the port when the cord was plugged in again, so had to charge...
You need this part replaced bud:
http://cgi.ebay.com/PowerBook-15-A1046-DC-Power-IN-Audio-USB-Port-Board_W0QQitemZ130356686920QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1e59dd3048
But you can't just buy this one. You have to buy the one that fits your model and processor speed.
Jan 09, 2010 | Apple PowerBook G4 Mac Notebook
Ibook g4 rebuild
Hi there.
Make sure you have the voltage and amperage right first before you try and power up the motherboard.
Most laptop motherboards run on 15, 19 or 20 volts and take a different amperage like 3.42A for example.
The power in will be displayed underneath the ibook so take a look there.
Don't plug a 24 volt power supply into it unless it specifies that because you could damage the board.
Good luck with project
May 25, 2009 | Apple HQRP Replacement Laptop AC Adapter /...
Can I repair a loose power port on my ibook g4? I am using a different computer to charge my battery. When it dies or is low, I take it out and charge it there. My power port will no longer charge. It was...
its posible but first make sure its not under warentee if so send it to apple thay will fix it if not then the only way to fix it is to order the charging port and resauter it to the board
Mar 27, 2009 | Apple iBook G4 Mac Notebook
Power cord tip broke off in iBook G4 port.
Here is a link to post on the exact same issue, with full DIY repair instructions. He doesn't exactly explain how he got the piece out but wrote it was not easily convinced to leave.
http://repair4laptop.org/contrib/apple_ibook/ibook_charger_plug_repair.html
Feb 11, 2009 | Apple iBook G4 Mac Notebook
Computers & Internet Logo
119 people viewed this question
Alun Cox
David Payne
David Payne
