Question about Mattel 1:32 Scale Tyco Radio Controlled Disney's Pixar Cars Lightning Mcqueen Vehicle 27 Mhz
Car runs regardless of remote, it responds to change of direction, but you cannot control the car stopping or going. When you turn the car on, the wheels just start going.
  • 49 Answers
Cahng the baterries of the remote control for a brand new if the problem still you cant fix it contac tyco to see if they can check your car
Posted on Jun 17, 2009
How do i program the innovage jumbo universal remote
Jumbo universal remotes are essentially the same regardless of the name at the top. If you have a device you want to control, start by turning on that device. Press and hold CODE SEARCH until the red indicator stays on, then release the CODE SEARCH button. Press and quickly release the device button, e.g, TV. Point the remote directly at the device. Press the power button (in the upper right corner) repeatedly until the device responds, e.g., changes channel. Press ENTER and release to install the code. If no result, your Innovage jumbo remote may not have a suitable code available.
Oct 23, 2014 | Innovage Jumbo Universal Remote Control
How to program
Jumbo remotes are basically the same, regardless of the name on them. Assuming you do not have a copy of the code list, begin by turning ON the device you want to control. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button. Press and immediately release the desired mode (device) button. The red indicator will blink once. Aim the remote directly at the device you wish to control and press the ON/OFF button repeatedly (up to 300 times!) until the device changes channel. The red indicator blinks off with each button press. When the device changes channel, press the ENTER button. Programming is much easier using direct entry of the code.
Oct 02, 2014 | Innovage Jumbo Remote Control
The remote to my RCA DVD Player, Model DRC220N, has stopped working. I've tried new batteries, hitting the DVD button 1st, etc. Nothing works. The player itself still seems to work as the buttons...
You could try a universal remote (if one is available which will provide most functions to your player, such as STOP/PLAY etc.).
You can try a simple test on your existing RCA remote to see if it provides a 'frequency pulse'. Turn a radio on, select a black section of the AM band (not FM) turn volume up halfway, place remote near it, listen for pips and noises from the speaker(s) - if this occurs, the remote itself is OK. This is the cheapest idea to try first before going out and buying a new remote.
* If the unit does not respond to the universal (regardless of whether a remote code is required or not) then the IRD within the unit itself and its associated controller circuit may have failed (hence why the remote does not work). Repair of this requires a qualified workshop technician (because of the many surface-mounted components in the IRD controller circuit). *
But try the original remote-to-AM-radio test and/or purchase a universal remote or similar if necessary.
May 12, 2011 | RCA DRC220N DVD Player
My samsung tv is not responding to my remote control, actually even when I go and attempt to change the channel from pressing the up/down buttons on the tv it won't respons, some menu screen would come on...
your turning section is not responding to any input, hence needs to be checked by a technician. every thing you have mentioned are controlled by one ic, with its respective voltages.
Mar 21, 2009 | Samsung Remote Control
Keys on dreambox dm 500c remote not responding
my 500 dream box just stopped receiving a signal,the green light is just blinking.
how do I get it to work,not tech savy.
Nov 09, 2008 | Televison & Video
Issues program the remote.
go and buy another remote as this is the most useless waste of time when you keep getting the run around and no answers.what does it take to post a page with all the remote numbers on it they all come with the same page.
Sep 30, 2008 | RCA RCR311B Remote Control
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
May 14, 2008 | Televison & Video
Remote problems
Take the remote to your local Radio Shack and have it tested.. They used to carry IR cards and now have a pen-like tester that can tell if the remote is operating properly. Then, if you're sure the code is correct, you probably will have to have the IR detector in the Tv replaced...
Bill
Nov 20, 2007 | RCA RCU300WBL Remote Control
Mattel 1:32 Scale Tyco Radio Controlled Disney's Pixar Cars Lightning Mcqueen Vehicle 27 Mhz Logo
187 people viewed this question
Top Mattel Toys Experts
Nikki  Mclean
Nikki Mclean
ray gallant
Are you a Mattel Toy Expert? Answer questions, earn points and help others
