Question about Toshiba REGZA 26HL47 TV
50hz not supported on Regza 26HL47?
My Regza cannot display 50hz signals properly (in this case from the wii). When i used the regular av setup to connect it to the television it came up black and white, the after purchasing a 720p cable for it, it is unchangeably zoomed in and cuts out about a quarter of the bottom half of the screen. Some games an't display in 60hz or 720p, hence why this is a problem. Can someone help me out with this? Greatly appreciated.
    President:
  • 1,284 Answers
You should have no problem displaying a 60hz 720 format as that is what this TV is based upon or a maximum of a 1080i 60hz picture. The TV will not support a 1080p or anything trying to feed it a 24 fps picture such as a blue ray player set for that mode. If you connected a standard video signal to a component connection on the TV, yes it will work but as you saw it will be in black and white. With the correct component connector for the Wii I believe the maximum it can be set for is 480p (DVD quality) which is much better than 480i (standard TV). If the picture is stretched out too much check the TV setting by using the FORMAT button on the Toshiba remote to change aspect ratios IE: WIDE, ZOOM, STANDARD etc..The other settings you want to check is in the Wii control panel. It probably asks you the type of television you are connected to such as 4:3 or a 16:9. You will want to set it for 16:9 wide-screen and if the setting is there you want to set it for 480p or 720p if the Wiii has that capability.
Posted on Nov 14, 2009
I found what looks like a card reader and an headphone input on the back of my t.v. (Toshiba REGZA 26HL47)by the power-cord and it was covered up by the manufacture... i was wondering if i up-grade the...
Miner modification design adjustment for a mass products productions fixes.99% of the LCD or plasma tvs out in sale for the consumers in the markets are never have to be upgraded or reinstall main frame firmware software at all,if u don't mess around in the main tv Tuner signal bard all.The main frame firmware software are alway and never suppose to be mess around for the tv entire life time anyway.
May 14, 2011 | Toshiba REGZA 26HL47 TV
I have a toshiba 26hl47 with a lighted screan but no pic
Just bought one used on ebay. Seller said pic was ok. Has no pic but backlite when turned on. Horiz. lines at top gradually creep down. Try banging on the back and top of the cabinet and see if the pic comes in. Mine has a bad,cold solder joint on the board with the audio ckts (upper right as you face the unit. I haven't found it yet. Very frustrating,it worked for 5 days ok but came back. Curious to know if yours is the same. PS: I am an electronics eng/tech.
Feb 05, 2011 | Toshiba REGZA 26HL47 TV
I have just purchased a used Wii system and every thing works fine except that it is in black and white help.
Hi Anne,
It could be due to the wii's current video settings, the previous owner would have had a TV that ran on different viewing options. The black and white picture is caused by having the Wii settings output at PAL 60Hz and the TV input at PAL 50Hz or vice versa (or NTSC). Try going to the wii settings menu and try a couple of different video settings until the colour comes :). If this does not work can you please post what connection you are using for ex. AV or composite.
Regards,
Omeil
Jan 30, 2011 | Nintendo Wii Console
Yellow blinking light and it wont turn on
It can have bad power supply or it is detecting shorted circuits so it goes into startup/shutdown mode, thus blinking light.
Please read my guides first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 06, 2011 | Toshiba REGZA 26HL47 TV
Colours on tv screen have gone green in colour
If you have used the red, green and blue video cables, the your red is either damaged or loose. If yuo used the regular red, white and yellow AV cables, the yellow is loose or damaged, In either case, if the cable is not loose, you'll need a new set of AV cables
Nov 27, 2009 | Nintendo Wii Console
Stuck on blue screen
THIS HAPPEND TO ME BEFORE MAKE SURE ALL OF YOUR LIKE SKY CABLES OR DVD SCART LEADS ARE FULLY CONNECTED TO THE TV ANF HAVE NO TEARS OR RIPS ON THE CABLE AND ALSO MAKE SURE THAT THE TV IS ON THE RIGHT AV CHANNEL BECAUSE YOU COULD HAVE CHANGED THE AV REALLY EASILY BY MISTAKE
Oct 08, 2009 | Sanyo DP26746 26 in. LCD Television
Wont turn on ,however the light is blinking for "disc".It is a tv/dvd combo regza 26"
another case of getting burnt out. your warentee should cover it dont worry. can be fixed.
Jun 30, 2009 | Toshiba REGZA 26HL47 TV
2 dvds stuck in dvd player
TAKE THE TOP CASING OFF, (UNPLUG FIRST TAKE PLUG OUT OF THE WALL ) YOU SHOULD SEE THE DVD PLAYER CASING ON BOTH SIDES THERE SHOULD BE SOME SCREWS UNDO THEM SLOWLY, BOTH SIDES UNTILL THE COVER HAS CLEARANCE, BE CAREFUL NOT TO BANG,, TOUCH, THE DOOR EJECT SYSTEM , REMOVE 1 DVD . RETIGHTEN SCREWS (DO NOT OVER TIGHTEN THESE , ) MAKE SURE THAT DVD IN THE DRIVE SPINS FREELY. PUT CASING BACK ON , PLUG IN IT SHOULD BE FINE .
Mar 24, 2009 | Toshiba REGZA 26HL47 TV
Wii Guitar Hero - No Guitar Sound
if the audio works for regular tv
check to see if the av cable is in properly
or if the red and white leads are plugged in
a470eb6.jpgRed and White leads
21fdb44.gifScart
Dec 17, 2008 | Nintendo Guitar Hero Wireless Guitar - Wii...
Toshiba REGZA 26HL47 TV Logo
316 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
