Question about RTO Atwood DSI-RV Water Heater-6 Gallon
I have an Attwood GE 16TE hot water tank with what a bad element,
I have an Attwood GE 16TE hot water tank with what I believe is a bad element. How to replace? It says on the outside access from other side, removed drawers, cover panel can't see element. Help?
Noot
  • 332 Answers
This is not a typical unit, you might want to consider calling the company for directions, go to there web site if they have one and look for elements and where they are located
Posted on Jun 23, 2009
MY Rheem 81SV40D Water Heater (47 gal) does not heat enough water. Approximately one bath worth.
You have dual-element 240Volt electric water heater.
Since you have some hot water, then we know upper element is good, and that circuit breaker and electricity to water heater are good.
Not enough hot water is probably bad lower element, and possibly sediment build-up in bottom of tank.
Test element:
http://waterheatertimer.org/How-to-test-water-heater-element.html
Replace 4500 watt element available at local hardware, and clean out bottom of tank:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Oct 07, 2012 | Rheem Tankless Hot Water Heater...
Reliant 40 gallon tall electric water heater replaced both thermostats upper and lower elements flushed tank hot water very hot temp turned down lowest possible keeps tripping reset button what else could...
Problem has to be bad element or bad thermostat.
Test elements for short to ground through metal tank wall:
Make sure factory-installed insulation and cover are re-installed over new thermostats so they do not misread tank temperature.
If problem does not show with elements, then replace thermostats again.
Oct 06, 2012 | Reliance & 40 Gal Electric Mobile Home...
Reliance 501 electric water heater with 4500 watt element. I believe I have a bad element (or both). I am losing my hot water temperature when bathing and washing dishes. Where can I find the elements and...
likely the elements are corroded you should turn off the power to the heater, then turn off the water supply to it and the exit shut off as well. Then drain the tank, remove the old elements take one with you to a local hardware store which should have replacement elements or will tell you where to get new ones.
once you have replaced the elements be sure to fill the tank and open the exit valve before turning the power back on.
Sep 21, 2011 | RELIANCE ELECTRIC WATER HEATER
After connecting a drain line to the pressure relief valve of my MR85245 water heater, I now have water leaking badly out of the heating element door.
Turn off the electricity.
Turn off the water valve going into tank.
Open a bathtub spout to let hot water pressure off the tank.
Check top of tank for any leaks.
Open the top access panel and see if element is leaking.
Open bottom access panel and see if lower element is leaking.
The reduced pressure on the tank will slow the leak.
If element is the problem, you can squeak by for a while by turning on the hot water heater only when you need hot water.
Order the 'Marathon MR85245 replacement element' online
http://www.gpconservation.com/rheem/marathon-sp213670-titanium-4500w-lower-element
These elements may be available locally, but they are not the same as 'ordinary' tank-type electric heater elements that you buy at the hardware store.
Buy more than 1 element because the Marathon elements have problems.
One of the reported problems with marathon elements is the high price of stainless steel replacement elements.
Drain tank.
Replace element.
Another resource for water heater information is:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Nov 04, 2010 | Water Heater Innovations MR85245 High...
My hot water will not get hot at all. Model SE40M12AA01 Stop getting hot over night. Breaker to heater was tripped, I reset it and still no hot water.
Your upper thermostat on the hot water tank may be shorting out causing your breaker to trip. Remove the outer panel door on the side of the hot water tank and test for power going to the elements. Also check for water as the tank may be leaking and causing the short
Feb 21, 2010 | General Electric GE SmartWater Household...
Hot water does not last long. Model 82vh40-2 mnf. 05/2005
If the lower heating element burns out the upper element will heat the top part of the tank then shutoff. homw depot/lowes etc should carry elements. 1 turn off breaker, remove element access cover (the 2 panels on the front of the heater) test for electricity at the reset button ( uppermost device in upper panel) to make sure power is off. 2 turn off water (I usually turn off the cold water main to stop water cross feeding into hot supply line back into heater) 3 disconnect the 2 wires on the lower element, test with continuity tester. shhould be no continuity between terminals and tank, but around 10 ohms between the 2 terminals. Check the thermostat for continuity if tank is cold thermostat should be closed ie zero ohms across the 2 terminals.
If stat is bad replace stat; disconnect wires push it up out of the spring clip insert new stat reconnect. If element is bad: drain tank. connect garden hose to tank drain valve, open tank drain valve turn water main on to clear rust sediment and get water flowing. Next remove filter screen from a hot water faucet then turn on ( a hot faucet upstairs or higher than tank drain). Now turn water main off, air will now go in through hot faucet and tank will drain, takes about an hour. Use a water heater element wrench about$10 to remove element(s) make sure no bits of rubber gasket are left in element opening- dig em out with a screwdriver if needed. Insert new element with its gasket and tighten. reconnect wires DO NOT TURN ON ELECTRICITY! BE SURE TO FILL WATER HEATER WITH WATER ! Turn water main back on -air will come out of the hot faucet for several minutes. When water runs without any air sputtering, turn off faucet and replace the faucet filter screen. check element(s) for leaks. turn breaker back on.
Feb 17, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The water gets too hot and trips the reset on the thermostat.
Two possibilities. 1 failed upper or lower Tstat 2 Shorted element
To test element: disconnect both wires to element terminals. use continuity tester to see if there is continuity through element (one probe on each element terminal) If no continuity element is bad. Then test for continuity between each element terminal and the water heater itself.( one probe on element terminal and one probe grounded on bare metal or inner tank.) If there is continuity from terminal to ground, element is bad and also can cause tank to continue heating even when thermostat shuts off. This is because the thermostat only shuts off one pole of the 220 and a shorted element can continue heating from the 2nd pole.
If both elements test OK and water heater heats the full tank( tank feels hot at bottom element access panel when no hot water for 2 hours) most likely the lower thermostat is bad.
Jan 25, 2010 | Reliance Water Heater #6-30-DORT 30GAL...
I have hot water for a minute then it goes to warm. I took off the 2 wires on each element and I have 15 ohms on the top and 5.5 on the bottom. Is my bottom element bad?
Sounds like bottom element may be bad but usually reads open circuit if bad. Also tan k would run about 8 gallons hot water then go cold. lots of warm water usually means bad dip tube.
Check if tank is hot at bottom element when not used for a while. If bottom element is still cold then bad element.
If bottom element is hot - (all water in tank is hot then you have a bad "dip tube" This is allowing incoming cold water to mix with outgoing hot water. The dip tube is usually A part of the cold water nipple or B located under the cold water inlet nipple.
Jan 18, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Hot water lasts half the time
How old is the heater?
It may be something as simple as just needing to flush the tank to remove any sedemints....and hopefully so because this is the easiest/cheapest thing to do.
If this is not the case go ahead and remove the heating elements and check for wear. Replace them if necessary. I would also replace the thermostats that accompany each of the elements.
Checking and replacing both of this requires you to drain the tank completely and should be close to $25 total....last time I checked.
Apr 27, 2009 | General Electric Water Heaters
Attwood RV Water heater model GC6AA-10E overloads breaker when
I would remove the heating element from the hot water tank. Take a look at it as it is probably fried from due to turning on the power to the tank when there was no water in the tank. If it looks ok still do a continuity test on it. I believe that is your culprit.
please mark this answer as a fixya!
Mar 09, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
RTO Atwood DSI-RV Water Heater-6 Gallon Logo
166 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Donni Steen
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
