Question about Mitsubishi WD-52525 52" Rear Projection HDTV
The key pad is lock and i have no remote to unlock it
How do i unlock the key pad with no remote
    President:
  • Mitsubishi Master
  • 3,433 Answers
Pick up a universal remote and enter the beand codr to pair it. Should work
Posted on Jun 15, 2009
Doors will not open by using remote key pad
both RKE keys dead.? car came with 2 , lost one?
replace the battery in RKE fob yet, why not, its like $1 fix.
Aug 02, 2014 | 2005 Jeep Liberty
How do i unlock my videocon AC remote???i see a key symbol on the top right corner of the remote screen.
When not in a setting mode, pressing and holding UP & DOWN keys for 3 seconds,
the key pad is locked. After setting it, the LOCK icon will be displayed on LCD to
indicate that key pad has been locked and all the keys are disabled. At that case,
the remote won't send out any codes. The LOCK icon on the LCD flash 3 times,
0.5 seconds for ON, 0.5 seconds for OFF, and press & hold UP & DOWN keys for
3 seconds, the remote is un-locked.
Jun 26, 2011 | Heating & Cooling
My keyless entry pad stopped working replaced the battery and still will not work. I have a 2001 ford taurus ses. how do i resolve this problem by reprogramming the keyless entry pad? I tried the code lock...
Try it with a new remote pad, turn the key back and forth untill the locks jump up and down.. do it slowly , when they jump make sure to leave the key in the on position while pressing both lock and unlock buttons on the remote, they should then jump again telling you that the remote is now programed.
Apr 14, 2011 | Ford Taurus Cars & Trucks
Hi, my old remote key pad used to lock itself so if I bumped it in my pocket it wouldnt start. I bought a new 2 way recently but the key pad stays unlocked. How do I get it lock?
Press and hold the "f" for 8 seconds to access the remote programming features. The remote will emit one long beep and the LEDs will illuminate. Press the unlock button to access the remote programming features. Two transmit LEDs will flashes and two beeps indicate the remote programming features are accessed. Press the lock button on the remote( LED on indicates auto locking on, LED off indicates auto locking off). Press and release "f" button to exit programming.
Apr 12, 2011 | 872 Responder LE keyless entry security...
How do you re-program the security code on a 2007
FORD KEY PADS
  • Enter permanent factory code
  • Press the 1/2 button within 5 seconds to enter programming mode
  • Within 5 seconds enter new code, doors will lock, unlock to verify code, this erases previous codes remotes will also need to be programmed. (MAYBE)
KEY PADS/REMOTES
  • Insert key, turn ignition off-to- on eight times in succession, ending with key in on position doors will lock, unlock to verify in programming mode
  • Press any button on new remote, doors will lock, unlock to verify
  • Do the previous step with the second remote, doors will lock unlock to verify.
  • Turn ignition off. Doors will again lock, unlock to verify.
NOTE-Some vehicles use 5 turns of the key instead of 8
Jun 05, 2010 | 2007 Ford Explorer Eddie Bauer
How can i program my door lock code or find out what it is. on my 2000 limited edition explorer
FORD KEY PADS
FORD KEY PADS/REMOTES
NOTE-I found that some Explorer/Mountaineers enter program mode after 5 times-not 8.
Here is the link for further info.
http://www.2carpros.com/how_to/how_to_reprogram_key_remote_fob.htm
Your factory code is on a card in the owners manual. If that is lost, access the control module in the cargo area behind the left cover panel.
You MIGHT be able to see the code printed on it, or you might need to pull it out in order to see it.
May 27, 2010 | 2002 Ford Explorer
How to program remote key of mercury mystique 2000
I am assuming this is the factory key fob.
Read all instructions before attempting.
Dec 23, 2009 | Mercury Vehicle Parts & Accessories
Drivers power lock will not unlock with remote.
the door lock actuator is defective, they get really hard to move when they go bad, that is why the difficulty with the key.
Mar 31, 2009 | 2000 Ford Explorer
Locked key pad
The procedure to unlock the key pad is to hold down the MENU button for 15 seconds. If that doesn't do it you have a problem.
Dec 29, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Unlock Hyundai TV
motimoti 's solution worked. Thanks.
By the way, how do you find the solution ?
Apr 21, 2008 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
