Question about Bose in-ear headphones - Black with black/white cord
Volume imbalance These headphones were great for the first six months but now I'm getting roughly one half the volume from one side (the right) as the other side. I had this problem a few months ago and cleaned the plastic connector with hydrogen peroxide - this fixed the problem then. I have the problem again, though, and cleaning the parts isn't helping. Both sides are definitely working, but just with a drastic volume difference.
SOURCE: Intermittent Crackling noise in the right headphone
Hello Rachel, I use my QC3 for 2.5 years Mon-Fri for 3 hours a day. I have the same problem when battery is weak and/or it is cold outside. The cracking nose stops for me if battery fully charged. This is known problem andBose put it in the manual.
Vlad
Posted on Oct 26, 2008
  • 93 Answers
SOURCE: My right earphone won't play
Sound not coming out of one side of the headphone is an indication of connection failure, so that means you have to see where its 'broken' from, either inside the headphone on on the wire somewhere. Usually it happens at the jack, especially if you use an ipod as it tends to get moved alot in pockets, etc..
If this is the case, you could try to cut the wire from where you suspect its broken, and get a 3.5mm (or whatever the original size is) replacement (Do-it-yourself) jack from Radio shack or electronics store.
THen you would have to cut the wire, strip the the rubber coating off, and then if applicable, carefully strip the very thin layer of further insulation thats on the wire it self. Otherwise you would directly connect the cables to the prongs/connections located on the replacement jack. And depending on the jack you would screw it in place or soldier it with soldier and soldiering gun.
If its broken in the headphone or at the headphone, thats much harder to do as you would have to open the head/earphone case and soldier it that way and get it back together in one piece.
Next time don't buy bose headphones and by something cheaper, bose isn't that great, skullcandy is pretty good too. Sennheiser is the best though in my opinion. albieit its expensive too..
Posted on Feb 27, 2009
  • 4 Answers
SOURCE: Less sound on one ear than the other
Yeah, based on all of your problems, i would safely say that you have a blown speaker. Call up Bose at 1-800-999-2673. If the headphones are under warranty (1 year) they will replace them for free. If now, they will charge you $100 for a replacement pair, which is quite a deal considering that the headphones cost $300.
Posted on May 15, 2009
SOURCE: sound from both ear phone
I had the same problem. The issue (if you confirm it is not the audio cable) is with the connection where the audio cable is plugged in. It is obviously not designed to withstand connecting and disconnecting the cable with each use. This is required so you can store the headphones in the provided case. I called Bose and they said they offered no repair but would replace the headphones for $100. My problem is that I have already spent $400 to buy the headphones and feel they should be designed to last longer than 2-3 years. I'm extremely disappointed and would advise anyone against buying Bose products if they are not going to offer any better service than that.
Posted on Dec 30, 2009
  • 62 Answers
SOURCE: The sound coming from my right bose on-ear headphones
the main problem is cut wire near the headphone...you need some tools to repair it..if you can repair by your self its cheaper than to buy a new one but if you bring it to electronic technician its quite expensive...
i will suggest to buy a new one than to repair...
Posted on May 26, 2010
Low volume
1)Make sure volume is at maximum level. check down right hand side of your desktop. 2)Make sure speakers(headphones) volume is at maximum. 3) If problem continues check your speaker( connect it to other pc), and headphone as well. 4) If problem continues try reinstalling audio driver.
Mar 28, 2011 | Computers & Internet
I have a 50" samsung plasma that was working fine now the volume just dissapeared & when i try to adjust the volume it shows the normal volume display with headphone icon in the display & when i...
You would need to replace the headphone socket then and if I am correct it should be mounted to a plug in board. I first need the model number of your Samsung to look up the part number. The model will be on a sticker on the side and will be something like HTP50***/XAA or something like that.
Sep 02, 2010 | Televison & Video
I'vs had my HP Pavilion Dv9000 laptop about 2 months now, and it has been great. recently however sounds have only been coming from the right sound channel. The left side just makes a starng buzzing noise...
There is a problem is the sound card. The HP laptop should be still under warranty, take it to the supplier to get it repaired under warranty. If you try to fix it yourself you most likely will void your warranty.
Oct 24, 2009 | HP Pavilion dv9000z Notebook
Not able to increse volume.The volume controller on my laptop automatically slides down even if I increase it while using the headphone.
your head phone volume controller /speaker/s has been short circuited so please replace /purchase new headphone
thank you
May 24, 2009 | Logitech ClearChat Pro USB Headset
Iphone volume
this part can be replaced, if you are a little tech savy you can try it yourself there are iphone repair manuals online and the part is on ebay.
Apr 30, 2009 | Apple iPhone 3G
Headset volume adjustment
if connected to a pc right click on the speaker icon on the right side of the main toolbar in windows then click on playback devices and adjust the volume there.
Jan 21, 2009 | Logitech Premium Stereo Consumer Headset
Cannot adjust the volume
same here. happened with in a week of getting mine. and worse, the side button stopped working within 2 days.
Nov 10, 2007 | Palm Treo 750 Smartphone
Logitech Freepulse headphones on Ipod only playing on one side
Seems like you have a faulty transmitter unit. Try contacting logitech.
Sep 13, 2007 | Logitech FreePulse Wireless Consumer...
Volume with Headphones
The unit probably has resistors or a limitor curcuit to limit the amount of audiop going out on the headphones. It could probably be modifyed but it would possiblt burn out the headphones as this is a 280watt peak power unit . Its there so you dont blow out your ears.you could use some wireless self powered headphones as that would solve your problem!! Good Luck
May 12, 2006 | Philips FWC788 CD Shelf System
Bose  in-ear headphones - Black with black/white cord Logo
123 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
