Question about Dell Dimension 4500 PC Desktop
I have a wireless card in my Dell Dimension
I have a wireless card in my Dell 4500 Dimension desktop computer, but when I go to the device manager popup, no wireless card is listed or shown. I'am unable to connect to my router.
    President:
  • 3,278 Answers
The first thing I would try would be to reset the card, by removing the cover (if you are comfortable), removing the card from the slot and reinserting in the slot or moving the card to another slot (if there is an identical slot). If that doesn't work, replace the wireless card either with another wireless card or a USB wireless network adapter (external adapter that connects to a USB port). Good luck.
Posted on Jun 15, 2009
  • NinaE Jul 02, 2009
    Was this helpful ??? Resolve your problem ?? Thanks.
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
Install d-link wireless card into a dell 4550 desktop
try to manually install it through device manager in control panel. or simply try to install the drivers.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 18, 2012 | Dell Dimension 4550 PC Desktop
I have a Dell Dimension 4500 and want to connect it to the Internet with an Ethernet card. Which card should I use?
I would say any card that gives you the speed you require and importantly is compaitble with your OS.
Jan 31, 2011 | Dell Dimension 4500 PC Desktop
Hi everyone, my dell 4500 wont connect to the internet. says it cannot find a network drive card. what should I check?
1. check and make sure your network cable is connected.
2. check to make sure the network card shows up in the device manager.
3. If it does not, remove and replace it and try again.
4. check and make sure that the drivers for the nic are installed.
5. Of course, always check for viruses/spyware etc.
good luck and let me know.
Aug 13, 2010 | Dell Dimension 4500 PC Desktop
How to I determine what type network card I have?
The most common types of network card adapters are for the wired and wireless connections.
Here is the picture of the wired network interface card.
Here's an example of a pci wireless adapter. There are also usb types.
http://www.pcarenahungary.com/pricelist/oriaskep/pci-wireless-adapter-380.jpg
If you want to know the manufacturer and model, right click the My Computer icon, click Manage, and then click Devices. You should see the list of devices installed on your computer.
Mar 13, 2010 | Dell Dimension 2400 PC Desktop
Dose the dell dimension modem have a wireless router card in it or do i have to installe a device to it to connect with the router
If you go into your control panel, under the heading performance and maintenance, there is a section called "Device Manager" open this and every component in your computer is listed. Look particularly at the "Modems" section. If your infrared card is not listed than it is not there. Thank You, Dana
Jan 17, 2010 | Dell Dimension C521 PC Desktop
I do not have the sound card driver - Dell dimension 4500.
Here is all the drivers for your computer, Audio is the sound drivers.
click here for page
Nov 30, 2009 | Dell Dimension 4500 PC Desktop
Wireless router with dimension 3000
It seems that you have Dell Desktop computer, unless you requested a wireless card to be put into the computer, it would not come with one. Just like stang_1 mentioned, you should check your network adapters to see if your wireless card is listed. Also since it is a desktop, you can check the back of it to see if you have an Antenna sticking out of it. That would indicate that you have a wireless card on the PCI slot. And if that is the case and you do not see it listed in the network connections, check the Device Manager and make sure that the drivers are installed properly.
Apr 14, 2009 | Dell Dimension 3000 PC Desktop
Add wireless card
You can add one via a USB port like THESE
Or you can add one to an empty PCI slot on your motherboard if you have one available. Like This One
Mar 01, 2009 | Dell Dimension 4500 PC Desktop
Dell Dimension 4500
connect this cable to socket, which is in left right corner of motherboard (its on the left side of the bottom pci)
Feb 26, 2008 | Dell Dimension 4500 PC Desktop
Dell Dimension 4500 PC Desktop Logo
198 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
